Základem je i moderátor,který by se o nově vytvořenou sekci průběžně postaral a udržoval sekci přehlednou.
      http://www.openboxforum.satdigitalne.cz
 Panasonic TX-50CX700E , Panasonic TX-P42G30E
Panasonic TX-50CX700E , Panasonic TX-P42G30E   Coolstream 4x DVB-S2 , Dreambox DM 900 UltraHD (1x dual DVB-S2) 1TB HDD , HD-BOX FS-9300 HD TWIN PVR  500GB HDD
Coolstream 4x DVB-S2 , Dreambox DM 900 UltraHD (1x dual DVB-S2) 1TB HDD , HD-BOX FS-9300 HD TWIN PVR  500GB HDD       Wave Frontier T-90 II generace , Gibertiny 85AL Motor SG-2100BS , Famaval 85AL multifokus 23E,19E,13E
Wave Frontier T-90 II generace , Gibertiny 85AL Motor SG-2100BS , Famaval 85AL multifokus 23E,19E,13E Finder Dreamsky TSC-90 TRIO , SatFinder Openbox SF 20
  Přístupové karty  SkyLink 0D96 , FreeSat 0D97
S kartami pre Skylink to už tiež majú za sebou takže asi to tu už niekto objednávalNew Firmware for Openbox X5 what new check below, with this you have small IPTV Channel List, more to come, tested by me works fine!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Build date: 11/01/2013 17:14:38
- Added IPTV function on Main MENU
- Added Danish OSD Language
- Added some cities of CZ/Slovakia for Google MAP/Weather
- Added replace.list/ignore.list for MGcamd. Note) CHid for irdeto is excluded due to system stability.
- Implemented Skylink EMM code (not verified)
- Bug fixed Irdeto(Raduga, 75E) smartcard for Raduga channels
- Bug fixed that system becomes slow when many channels(800, 4050 channels)
- Bug fixed cccam for some channels on 45E, 10E, and 95E satellites
- Bug fixed that it was displayed two highlights in OSD
- Chnaged SKcam's expired date to status of connection
- Removed "EYEBOX X5" from the startup picture and the information page the first two lines "Product" and "Technical support
- Fixed many other things
Note) This new s/w has a function that it checks STB's s/w whether it is old then it will do factory reset automatically. Please noted.
A februárový fw ponúka aj češtinuBuild date: 24/12/2012 14:10:36
- Fixed Youtube problem.
- Fixed Problem: Search (find ) channel when press Caps (red button )
- Add Skylink Irdeto card reading for Czech market.
Určite to kúpim, aby som vedel ako dobre alebo zle sa dnes robia lacné HD prijímačeBuild date: 07/02/2013
- Added more numbers of replace.list up to 300 (existed list will be removed)
- Added program type(tv+radio, tv, radio) on SCAN
- Added more language(Czech, Russia, etc)
- Added auto connection management module in background for sharing function(no connection message at bootup)
- Added latest Viaccess SoftCAM code
- Fixed GMT display problem when bootup
- Fixed bug for EPG
- Fixed bugs on MGcamd(Astra 19.2 11856V)
- Improved CCcam/Newcamd
- Fixed EPG display of daylight time on info banner
- Fixed network DNS issue(changed not allowable to edit DNS on DHCP)
- Fixed many other bugs
