jak zjistit zapisy ?? (placena nabidka)
pedrodc Czech Republic
Příspěvek od pedrodc »
Daji se v něčem zjistit zapisy (multi hd ) Ice skylink,nejlepe v PC http:// ??? Pokud zadam http://ipazboxu otevře se azbox webcontrol. Ja chci cccam nebo oscam.Neplacene vyčtu pomoci cccam info 1.3 v azboxu.Když přidam port z [webif] ani tuk http://ipazboxu:8888
hakizu
Re: jak zjistit zapisy ?? (placena nabidka)
Příspěvek od hakizu »
IP boxu:port na ktorom ti bezi web rozhranie oscam alebo cccam. Hladaj entitlements. Tam najdes zapisy vsetky platene, neplatene, platne aj neplatne..
AzBox HD Elite, wavefrotier T90, DM500, Ariva 120C
Zadam http://80.00.00.00:8888/ a nic. Cccam jede http://80.00.00.00:16001
Mam 20 dni promo,po 7 dnech vypadly placene.Zapisy mam pouze pro free programy,takze mam 2 problemy, neprochazej zapisy a nejde mi weboscam.Cccaminfo jsem rozjel dopsanim Ip adresy v programu cccam info 1.3.Dekuji za jakekoliv info
oscamconf.
[global]
usrfile = /tmp/oscamuser.log
logfile = /tmp/oscam.log
cwlogdir = /tmp/oscam.cw
disablelog = 1
disableuserfile = 1
usrfileflag = 0
clienttimeout = 5000
fallbacktimeout = 2500
clientmaxidle = 120
failbantime = 0
bindwait = 120
netprio = 0
clientdyndns = 0
resolvedelay = 30
unlockparental = 0
nice = -10
serialreadertimeout = 1500
maxlogsize = 32
waitforcards = 0
preferlocalcards = 1
saveinithistory = 1
readerrestartseconds = 5
lb_mode = 0
lb_save = 0
lb_nbest_readers = 1
lb_nfb_readers = 1
lb_min_ecmcount = 5
lb_max_ecmcount = 500
lb_reopen_seconds = 900
[monitor]
port = 989
nocrypt = 127.0.0.1,0.0.0.0-192.168.1.255
aulow = 120
hideclient_to = 7
monlevel = 4
appendchaninfo = 1
[newcamd]
port = 15000@0D96:000004;15001@0D0F:000004,000008;15002@0D03:000004,000008
mgclient = 1
[cccam]
port = 8000
reshare = 1
version = 2.2.0
[dvbapi]
enabled = 1
au = 1
boxtype = azbox
user = root
pmt_mode = 0
priority = 0666,0D96,0D03,0D0F,0D70,0624,0D95
[webif]
httpport = 8888
httprefresh = 8
httpallowed =0.0.0.0-192.168.255.255,
httphideidleclients = 0
httpreadonly = 0
httpsavefullcfg = 0
po teto změně jsem se připojil na Oscam http://xx.xx.xx.xxx:8888 aleluja a ted ty zapisy rozjet!!
[global]
emmlogdir = /var/log/oscam/emm
disablelog = 1
disableuserfile = 1
usrfileflag = 0
clientmaxidle = 120
failbantime = 0
bindwait = 120
netprio = 0
clientdyndns = 0
resolvedelay = 30
unlockparental = 0
nice = -10
maxlogsize = 32
waitforcards = 0
saveinithistory = 1
lb_mode = 0
lb_save = 0
lb_nfb_readers = 1
lb_min_ecmcount = 5
[monitor]
port = 989
aulow = 120
hideclient_to = 7
monlevel = 4
appendchaninfo = 1
[newcamd]
mgclient = 1
[cccam]
port = 8000
reshare = 1
version = 2.2.0
[dvbapi]
enabled = 1
au = 1
boxtype = azbox
user = xxxx
pmt_mode = 0
[webif]
httpport = 8888
httprefresh = 8
httpuser = xxxx
httppwd = xxxx
httpallowed =0.0.0.0-192.168.255.255,xxx.xxx.xxx.xxx
httpreadonly = 0
httpsavefullcfg = 0
hakizu
MGcamd a oscam nastavit tak aby ti prechadzali zapisy, t.j. v oscame povolit clientovi zapisy a v mgcamd mg_cfg AU 01, nastavit link v cccamd.list alebo newcamd.list na oscam server.
Zapisy cez oscam - cccam neprechadzaju, resp. nie tie co potrebujes.
obsah mg_cfg
# EMM messages
# 00 don't show any EMMs (default)
# 01 show only valid EMMs
# 02 show valid and bad EMMs with complete data display
M: { 01 }
# ECM messages
# 00 don't show anything about ecm
# 01 normal mode, show pids processed, decoded ecm and cw
# 02 verbose mode, show valid and bad ECMs with data
C: { 01 }
# AU
# 00 disable, no emm pids processed
# 01 enable, emm pids always processed for soft-au and shared cards
# 02 auto, emm started only if channel cant be decoded
# 03 process emm pids for network cards update only
A: { 01 }
# key update (sum 01 or 02 with 04)
# 01 update only new keys, default setting
# 02 update all keys (used for valid PMK checking)
# 04 enable TPS au
# + tps SID, which pmt pid contains au pid
U: { 01 } 0x12c0
# config files folder (softcam, autoroll, ignore/priority)
# 00 files in /var/keys
# 01 files in /tmp
T: { 00 }
# network mode, use summ for several clients
# 00 no network (default)
# 01 newcamd netclient
# 02 radegast netclient
# 04 camd3 netclient
# 08 gbox netclient
# 32 cccamd netclient, card list saved as /tmp/cccamd.info
# (ECM only, supported server version up to 2.1.1, later not work)
G: { 33 }
# network retry, use summ for several options
# 00 disable
# 01 retry every new ecm
# 02 try to connect to offline shares every Q: seconds
# 04 try to detect and fast reconnect to lost (and not used atm) server
# + XX messages number and YY seconds to reconnect
# mg will reconnect to server, if no answer to last XX ecm/keepalive or
# if no answer for last ecm or keepalive sent for YY seconds
# set to 0 to disable
N: { 07 } 5 30
# network ecm timeout in seconds
K: { 05 }
# newcamd dead routes connect retry, sec
Q: { 600 }
# network shares priority
# 00 gbox, newcamd, cccamd, radegast, camd3 (default)
# 01 camd3, radegast, cccamd, gbox, newcamd
# 02 cccamd, newcamd, camd3, gbox, radegast
P: { 02 }
# on screen display type
# 00 No OSD (default)
# 01 neutrino
# 02 enigma
# 03 relook
# + user password for http auth
O: { 00 } username password
# on screen display Options, summ of:
# 01 show emu ecm
# 02 show network shares messages
# 04 show decoding failed / fta
# 08 show emm keys update
# + web port to use for osd
S: { 03 } 80
# Log option, summ of:
# 00 off
# 01 network udp log
# 02 log to console
# 04 file, appended ! delete it by yourself, before it eat all your hdd
# + IP udp-port log-file-name
L: { 02 }
# keep ecm cache, seconds
# every cache entry takes 28 bytes, so 24h cache will take *only* 240-400kb of memory,
# for openbox/elanvision users with remote shares make sense to set it higher than default value,
# to not hammer cards while timeshifting or playing crypted recordings.
E: { 15 }
# cache option, summ of:
# 00 Off (default)
# 01 Ecm pids cache, store pids used to decode in /tmp/ca_cache.list at exit, load at startup, same syntax as restore.list
# 02 Ecm data cache, remember CW for (E time
# 04 Emm cache for network cards, do not resend the same emm twice, cache not cleared until restart
H: { 07 }
# reread files, summ of:
# 00 No (default)
# 01 reread config file on channel change (including priority and ignore, but not replace/cache)
# 02 reread SoftCam.Key on channel change
# 04 reread SoftCam.Key if file changed
R: { 00 }
# debug, summ of
# 00 off (default)
# 01 debug ecm
# 02 debug emm
# 04 debug network ecm
# 08 debug network emm
# 16 debug network login
# 32 show mem/cpu stats every 1 min
# 64 add timestamp to log messages
D: { 00 }
# box type
# 00 autodetect, change only if you think wrong type detected.
# 01 dbox2
# 02 dreambox
# 03 triple-dragon
# 04 relook
# 05 openbox
# 06 dreambox/mips
# 08 stapi/kathrein
# 09 stapi/ipbox
# 11 stapi/openbox
B: { 06 }
# map all 180x nagra caids to 1801
# default is 01
F: { 00 }
Ja osobne to mam takto a ked potrebujem povolit zapisy spustim si mgcamd. Kartu mam v dm500 v oscame, slape to super.
pojde ti aj obraz. pouzi mgcamd 1.35 a novsi.
Je to tu rozoberane treba hladat. Alebo si tam hod cccam 2.3.0 povol zapisy v nom ak nie su a prejdu ti aj tam.
