Inštalácia pluginu OpenMultiboot-časť 2.
Rady a návody pro majitele přijímače Gigablue .
Moderátor: efendy55
makatch Slovakia
Příspěvek od makatch »
10,Po dokončení inštalácie sa nám spustí OMB Manager,kde vidíme svoje nainštalované image,ktoré môžme premenovať,alebo vymazať.
11,Teraz zavrieme OMB Manager tlačítko exit a dáme reštartovať prijímač.Po reštarte sa nám pred zavedením image spustí openMultiboot bootmenu,kde máme na výber čo chceme spustiť.
12,Po spustení systému image nájde nastavenia z flash pamäte,tieto sa však neodporúča používať,ale nastaviť si systém odznova
Celý videonávod TU
OpenMultiBoot - 1.0 2014/10/03
OpenMultiBoot will be donated to OE-Alliance by GigaBlue.
OpenMultiBoot can be modified or adapted to work with stb's from other vendors as long naming "openMultiBoot" is not changed and logos of openMultiBoot persists.
OpenMultiBoot uses boxbranding and informations from oe-alliance bitbake recipes. Due to that - ipk's are specific for each stb! Do not try to use OpenMultiBoot from stb A on stb B.
GigaBlue takes no responsibility for any potential damage openMultiBoot might cause on stb's from other vendors.
OpenMultiBoot requires some kernel-modules to work. They will be installed on installation of OpenMultiBoot.
ubifs - kernel-module-nandsim
jffs2 - kernel-module-nandsim kernel-module-block2mtd
(c) 2014 Impex-Sat GmbH & Co. KG - http://www.gigablue.de
Notes:
< device > has to be formated in ext4
< device > should be a fast usb-stick or ssd - not recommended to use a normal hdd as hdd would almost never stop spinning
Upload any zipped image to < device >/open-multiboot-upload or /omb/open-multiboot-upload
Zipped image needs regular folderstructure like flashing from usb-device
It is not recommended to re-use existing settings - do not blame us if problems occur
Check your recording path configuration and existing timers if you attach a new device
Do not use Flash-Online if you have not booted your regularly flashed image - use delete/install in OpenMultiBoot of regularly flashed image
Special thx goes to skaman, kajgan, captain, arn354 and all testers!
Prvá časť návodu TU
Gigablue HD QUAD PLUS OpenATV 5.1
HD-BOX FS-9105+ E2 OpenATV5.1
PANASONIC TX-42AS600E
Bond Slovakia
Re: Inštalácia pluginu OpenMultiboot-časť 2.
Příspěvek od Bond »
Len taka jedna otazocka ohladne OpenMultiBoot.
Moze sa na jedno USB nainstalovat aj viac Imagov a pri restarte si potom vyberiem jeden z nich?
Dakujem za odpopved.
salamander545 Slovakia
Příspěvek od salamander545 »
Ano dá sa ja som tam mal 5 naistalovanych
Bond Slovakia
Příspěvek od Bond »
salamander545 píše:Ano dá sa ja som tam mal 5 naistalovanych
Dakujem za odpoved. Asi nema zmysel dat si tieto Image na USB3, ked tento prijimac zial nepodporuje USB3.
Vidim, ze mas Open ATV 6, je velky rozdiel od Open Atv 5.3?
efendy55 Slovakia
Dal poděkování: 16 poděkování
Příspěvek od efendy55 »
na multiboot nepotrebuješ USB-3 . rozdiel medzi tými image som veru nepostrehol žiadny ....... :87:
Všetko4K,Linux E2
Bond Slovakia
Příspěvek od Bond »
Pokusam sa nainstalovat na USB cez OpenMultiboot image, ale neviem preco po stlaceni pluginu OpenMultiboot mi nevidi USB kluc. Pokusal som sa uz o vsetko ( inicializacia, mount USB), ale nic nepomohlo. Vyskusal som asi zo 5 ks klucov a stale to iste. Pred tym som tento problem nikdy nemal. Kde moze byt chyba?
bambule
Profík
Profík
Příspěvek od bambule »
Uz vis kde je chyba🤷‍♂️
Bond Slovakia
Příspěvek od Bond »
Už ani neviem ako sa mi to nakoniec podarilo, bolo to už dávno
Zpět na „Rady a návody“
