11,Teraz zavrieme OMB Manager tlačítko exit a dáme reštartovať prijímač.Po reštarte sa nám pred zavedením image spustí openMultiboot bootmenu,kde máme na výber čo chceme spustiť.
12,Po spustení systému image nájde nastavenia z flash pamäte,tieto sa však neodporúča používať,ale nastaviť si systém odznova
Celý videonávod TU
OpenMultiBoot - 1.0 2014/10/03
OpenMultiBoot will be donated to OE-Alliance by GigaBlue.
OpenMultiBoot can be modified or adapted to work with stb's from other vendors as long naming "openMultiBoot" is not changed and logos of openMultiBoot persists.
OpenMultiBoot uses boxbranding and informations from oe-alliance bitbake recipes. Due to that - ipk's are specific for each stb! Do not try to use OpenMultiBoot from stb A on stb B.
GigaBlue takes no responsibility for any potential damage openMultiBoot might cause on stb's from other vendors.
OpenMultiBoot requires some kernel-modules to work. They will be installed on installation of OpenMultiBoot.
ubifs - kernel-module-nandsim
jffs2 - kernel-module-nandsim kernel-module-block2mtd
(c) 2014 Impex-Sat GmbH & Co. KG - http://www.gigablue.de
Notes:
< device > has to be formated in ext4
< device > should be a fast usb-stick or ssd - not recommended to use a normal hdd as hdd would almost never stop spinning
Upload any zipped image to < device >/open-multiboot-upload or /omb/open-multiboot-upload
Zipped image needs regular folderstructure like flashing from usb-device
It is not recommended to re-use existing settings - do not blame us if problems occur
Check your recording path configuration and existing timers if you attach a new device
Do not use Flash-Online if you have not booted your regularly flashed image - use delete/install in OpenMultiBoot of regularly flashed image
Special thx goes to skaman, kajgan, captain, arn354 and all testers!
