CCcam 2.3.0 Ide ICE karta!!
- ftom
Re: CCcam 2.3.0 Ide ICE karta!!
Panove, dnes jsem zjistil, ze mam tmu a netusim jestli je to verzi FW (momentalne mam natazeno dnesni RSi). Nahodil jsem CAM standartnim postupem a je tma. Tak jsem nahodi CAM na popredi a jsou tam divne vypisy ktere se mi moc nelibi viz. poslednich 10 radku. A hlavne posledni 2, jsou cervene. Mohl by me nekdo prosim poucit co to znamená ?
CCcam -d -v -C /etc/CCcam.cfg
20:21:58.637 CCcam: ======================================================================
20:21:58.641 CCcam: starting CCcam 2.3.0 compiled on Dec 15 2011@23:38:08
20:21:58.642 CCcam: ======================================================================
20:21:58.643 CCcam: online using nodeId 2bf0d90259bf47fa
20:21:58.653 CCcam: dvb api3 detected
20:21:58.655 CCcam: DM7025 detected
20:21:58.656 CCcam: create 8 cam device(s)
20:21:59.009 CCcam: added 0 keys from /var/keys/SoftCam.Key
20:21:59.010 CCcam: added 0 keys from /var/keys/AutoRoll.Key
20:21:59.010 CCcam: static cw not found or bad
20:21:59.011 CCcam: parsed 0 entries from /var/etc/CCcam.prio
20:21:59.087 CCcam: added 869 provider names from /var/etc/CCcam.providers
20:21:59.097 CCcam: added 98 channel names from /var/etc/CCcam.channelinfo
20:21:59.099 CCcam: server started on port 12000
20:21:59.105 CCcam: found irdeto caid: 0x624 ecmpid: 0xeaa id: 0x0
20:21:59.106 CCcam: found cryptoworks caid: 0xd96 ecmpid: 0xeb4 id: 0x0
20:21:59.107 CCcam: cam[0] set PMT for sid=13b4
20:21:59.116 CCcam: start EMM
20:21:59.158 CCcam: EMM demux 1 set
20:21:59.158 CCcam: EMM: not interested in 0D03:000000
20:21:59.158 CCcam: EMM: not interested in 0D70:000000
20:21:59.159 CCcam: EMM: not interested in 0D96:000000
20:21:59.160 CCcam: EMM: start filter on irdeto emmpid: 0x68 caid: 0x624 id: 0x0
20:21:59.163 CCcam: EMM: start filter on irdeto emmpid: 0x69 caid: 0x666 id: 0x0
20:21:59.514 CCcam: chid 0000
20:21:59.515 CCcam: cam[0] ecm odd nok caid:0x624 id:0x0 pid:0xeaa Skylink/WDS (23E/19E/10E)
20:21:59.729 CCcam: cam[0] ecm odd nok caid:0xd96 id:0x0 pid:0xeb4 Skylink (23E)
Fishburn
Odstran staré keys z softcam.key.... od skylink
možná ti to pomůže
možná ti to pomůže
Formuler F4 Turbo Combo hevc
- ftom
Asi ne, ten soubor je prázdnej viz. začátek logu :-(Fishburn píše:Odstran staré keys z softcam.key.... od skylink
možná ti to pomůže
- ftom
Tak nic, vypadato ze dnesni RSi asi zavedlo novej kernel a maji domrdanej driver ctecky, tak jako je to na OpenPLI v aktualnich betach... jdu zkusit starsi image..
- VTronik
4 ftom
Proč si nedáš do prio souboru prioritizaci pro ICE 0D96?
Viz "20:21:59.011 CCcam: parsed 0 entries from /var/etc/CCcam.prio"
Asi takto:
P: 0D96:000004
I: 0D03
I: 0D07
I: 0D0F
I: 0624
I: 0666
Asi takto:
P: 0D96:000004
I: 0D03
I: 0D07
I: 0D0F
I: 0624
I: 0666
Skylink ICE
Skylink ICE
- ftom
Al jooo, klidne, ale to nezmeni nic na stavu, ze posledni RSi tak jako bety PLi nectou kartu (kernely 3.4.4)
Kdyz juknu do CAM webu, tak to hlasi ze karta neni zasunuta..
Až poběží čtečka karet v kernelu 3.4.4 bude stačit pouze nainstalovat CCcam 2.3.0 a ICE karta poběží bez jakékoliv úpravy configu a všeho dalšího.
Fishburn
A co problém v názvu sci0 / dřive u RTi také došl k změně..........
možna je to kravina,,,.
- ftom
dedecek_ :
JJ. Ja vim, jen jsem se blbec nevsim, ze dnesni RSi natahnul 3.4.4
Ponauceni pro me: Nez napises do fora, udelej zakladni troubleshooting (jako treba viditelnost ctecky)
Fishburn: nazvem to neni.. je to ovladacem
Viete mi nikdo poradit, kde je problem?
V sobotu som vymenil staru CW Skylink kartu za novu IRDETO a zatial sa to este nerozbehlo. Stale je len tma.
Skusal som reautorizaciu 4 krat, urobil som reset Pinu a stale nic.
CCam neukazuje ziadne info, karta je spravne vlozena.
Moja konfiguracia:
Premium HD
RTi 1.7
TSPanel 6.4
CCCam 2.3.0
ps: nemam moznost to skusit reautorizovat v inom prijimaci:(
Moja konfiguracia:
Premium HD
RTi 1.7
TSPanel 6.4
CCCam 2.3.0
Mas tam na tom cccam-e povolene zapisy?
Ak si mal v ETC a tam CCcam.cfg v riadku myslim nieco ako B: /dev/sci0 07 (blokuje zapisy) tak to prepis na #B: /dev/sci0 07 (zapisy povolene). A restart cccam a potom prepni na CT1 a reautorizacia karty , chvilu pockaj a mal by ist obraz.
- visper
@hogo Pokud je to čisté Irdeto (ne ICE), tak ti v CCcamu nepůjde.
- Steiner
hogo píše:....som vymenil staru CW Skylink kartu za novu I-deto ...
ak robil výmenu tak to asi čisté I-deto nebudevisper píše:@hogo Pokud je to čisté I-deto (ne ICE), tak ti v CCcamu nepůjde.
„Cross of Iron“
vikino
Mohol ju vymenit aj inak ako officialne, takze to moze byt aj ciste Ir.deto... mal by sa vyjadrit aku kartu vlastne ma...
