CCcam 2.3.0 Ide ICE karta!!
Diskuze E2
ftom
Re: CCcam 2.3.0 Ide ICE karta!!
Příspěvek od ftom »
Panove, dnes jsem zjistil, ze mam tmu a netusim jestli je to verzi FW (momentalne mam natazeno dnesni RSi). Nahodil jsem CAM standartnim postupem a je tma. Tak jsem nahodi CAM na popredi a jsou tam divne vypisy ktere se mi moc nelibi viz. poslednich 10 radku. A hlavne posledni 2, jsou cervene. Mohl by me nekdo prosim poucit co to znamená ?
CCcam -d -v -C /etc/CCcam.cfg
20:21:58.637 CCcam: ======================================================================
20:21:58.641 CCcam: starting CCcam 2.3.0 compiled on Dec 15 2011@23:38:08
20:21:58.642 CCcam: ======================================================================
20:21:58.643 CCcam: online using nodeId 2bf0d90259bf47fa
20:21:58.653 CCcam: dvb api3 detected
20:21:58.655 CCcam: DM7025 detected
20:21:58.656 CCcam: create 8 cam device(s)
20:21:59.009 CCcam: added 0 keys from /var/keys/SoftCam.Key
20:21:59.010 CCcam: added 0 keys from /var/keys/AutoRoll.Key
20:21:59.010 CCcam: static cw not found or bad
20:21:59.011 CCcam: parsed 0 entries from /var/etc/CCcam.prio
20:21:59.087 CCcam: added 869 provider names from /var/etc/CCcam.providers
20:21:59.097 CCcam: added 98 channel names from /var/etc/CCcam.channelinfo
20:21:59.099 CCcam: server started on port 12000
20:21:59.105 CCcam: found irdeto caid: 0x624 ecmpid: 0xeaa id: 0x0
20:21:59.106 CCcam: found cryptoworks caid: 0xd96 ecmpid: 0xeb4 id: 0x0
20:21:59.107 CCcam: cam[0] set PMT for sid=13b4
20:21:59.116 CCcam: start EMM
20:21:59.158 CCcam: EMM demux 1 set
20:21:59.158 CCcam: EMM: not interested in 0D03:000000
20:21:59.158 CCcam: EMM: not interested in 0D70:000000
20:21:59.159 CCcam: EMM: not interested in 0D96:000000
20:21:59.160 CCcam: EMM: start filter on irdeto emmpid: 0x68 caid: 0x624 id: 0x0
20:21:59.163 CCcam: EMM: start filter on irdeto emmpid: 0x69 caid: 0x666 id: 0x0
20:21:59.514 CCcam: chid 0000
20:21:59.515 CCcam: cam[0] ecm odd nok caid:0x624 id:0x0 pid:0xeaa Skylink/WDS (23E/19E/10E)
20:21:59.729 CCcam: cam[0] ecm odd nok caid:0xd96 id:0x0 pid:0xeb4 Skylink (23E)
Fishburn Czech Republic
Dal poděkování: 55 poděkování
Příspěvek od Fishburn »
Odstran staré keys z softcam.key.... od skylink
možná ti to pomůže :115:
Formuler F4 Turbo Combo hevc
ftom
Příspěvek od ftom »
Fishburn píše:Odstran staré keys z softcam.key.... od skylink
Asi ne, ten soubor je prázdnej viz. začátek logu :-(
ftom
Příspěvek od ftom »
Tak nic, vypadato ze dnesni RSi asi zavedlo novej kernel a maji domrdanej driver ctecky, tak jako je to na OpenPLI v aktualnich betach... jdu zkusit starsi image..
VTronik
Příspěvek od VTronik »
4 ftom
Proč si nedáš do prio souboru prioritizaci pro ICE 0D96?
Viz "20:21:59.011 CCcam: parsed 0 entries from /var/etc/CCcam.prio"
Asi takto:
P: 0D96:000004
I: 0D03
I: 0D07
I: 0D0F
I: 0624
I: 0666
Skylink ICE
ftom
Příspěvek od ftom »
Al jooo, klidne, ale to nezmeni nic na stavu, ze posledni RSi tak jako bety PLi nectou kartu (kernely 3.4.4)
Kdyz juknu do CAM webu, tak to hlasi ze karta neni zasunuta..
dedecek_
Příspěvek od dedecek_ »
Až poběží čtečka karet v kernelu 3.4.4 bude stačit pouze nainstalovat CCcam 2.3.0 a ICE karta poběží bez jakékoliv úpravy configu a všeho dalšího.
A co problém v názvu sci0 / dřive u RTi také došl k změně..........
možna je to kravina,,,. :89:
ftom
Příspěvek od ftom »
dedecek_ :
JJ. Ja vim, jen jsem se blbec nevsim, ze dnesni RSi natahnul 3.4.4
Ponauceni pro me: Nez napises do fora, udelej zakladni troubleshooting (jako treba viditelnost ctecky)
Fishburn: nazvem to neni.. je to ovladacem
hogo
Příspěvek od hogo »
Viete mi nikdo poradit, kde je problem?
V sobotu som vymenil staru CW Skylink kartu za novu IRDETO a zatial sa to este nerozbehlo. Stale je len tma.
Skusal som reautorizaciu 4 krat, urobil som reset Pinu a stale nic.
CCam neukazuje ziadne info, karta je spravne vlozena.
Moja konfiguracia:
Premium HD
RTi 1.7
TSPanel 6.4
CCCam 2.3.0
ps: nemam moznost to skusit reautorizovat v inom prijimaci:(
anfro11 Slovakia
Příspěvek od anfro11 »
Mas tam na tom cccam-e povolene zapisy?
anfro11 Slovakia
Ak si mal v ETC a tam CCcam.cfg v riadku myslim nieco ako B: /dev/sci0 07 (blokuje zapisy) tak to prepis na #B: /dev/sci0 07 (zapisy povolene). A restart cccam a potom prepni na CT1 a reautorizacia karty , chvilu pockaj a mal by ist obraz.
visper
Příspěvek od visper »
@hogo Pokud je to čisté Irdeto (ne ICE), tak ti v CCcamu nepůjde.
Steiner
Příspěvek od Steiner »
hogo píše:....som vymenil staru CW Skylink kartu za novu I-deto ...
visper píše:@hogo Pokud je to čisté I-deto (ne ICE), tak ti v CCcamu nepůjde.
ak robil výmenu tak to asi čisté I-deto nebude
„Cross of Iron“
vikino Ukraine
Dal poděkování: 9 poděkování
Příspěvek od vikino »
Mohol ju vymenit aj inak ako officialne, takze to moze byt aj ciste Ir.deto... mal by sa vyjadrit aku kartu vlastne ma... :idea: :D
Zpět na „AZ HD Diskuze E2“
