After a long time we can finally say, here's the new SPAZE 2.0. The last few weeks we have found problems with the new kernel and finally we decided to go back to the old. This has caused one of the new features we had prepared for the SPAZE not be incorporated because it is only supported by the new kernel, when the kernel problems are solved we release a new version with Led Support.
To finally see the drivers have not put those in the Core RTi 1.3 entirely that many people pass the HDMI signal long enough becomes inaccessible and you have to restart again. Does this mean that people will work well for the Standby Premium will be without him?. Not at all by the firm goes one. Ipk install the fix that will allow for the Premium Standby, we have done so because we believe it is the best globally.
As you can see the wizard will not choose between HDMI and DVI, as well as resolution and refresh. This is because we've found that people who have connected mode AZBox Components in these windows have the black screen to configure this. That's why we have omitted these windows so that all outputs operate correctly. Once all the wizard you can configure the refresh and resolution settings A/V
Due to the many changes in the new Spaze, only incorporates Spanish and English languages. In the download server is to download the Italian language (thank Doctor Who) and Catalan (thank Pe.Tardo). The other languages we hope for your collaboration to be attached to the server.
Spaze 2.0 brings functionality for those with a higher DOM than the original capacity to take advantage of this space to install plugins, skins, picons, etc ...
If you use a different keymap that brings the SPAZE is very likely that in certain menu command does not work as they really should, so please keep in mind this and if you change the keymap is under your responsibility.
RAW audio is problematic. We don´t recomend for now use this configuration.
The last and the most important: We are very grateful with all betatesters for his collaboration detecting and fixing bugs, very hard work.... sergiri your azbox is the special one
Hmmm... cakal som viac. Okrem uprav nejakych pluginov, nevidím rozdiel oproti RTI alebo RSI. Po 15 minutach v standby nenabehlo hdmi. Spotreba ostala rovnaka...A este bol k tomu image pribaleny fixstandbypremium-azboxhd_0.1_mipsel.ipk. Aj som ho nainstaloval, no netusim, ci vobec nieco fixnul.
Este potestujem, ale som sklamany...
Hm Fajn itak nejsem spkojen s rti 1.3 a jdu do toho ...čekal jsem vice ...( já musím počkad dele než žena zaspí ,,... ) tak se nezlopte...
Podám info,,,ok
zatial bezim asi hodinu a OK
sklamanie... zatial nie. no uvidime
zelenu som nemal este ani raz
mytube -OK
prehravanie nahravok a MKV (tie co som skusal) OK (k titulkom som sa este nedostal-TV uz okupuju deti)
spotrebu nemam ako zmerat
zatial spokojnost
Stabilní
přehrává - i samsung předváděcí bez škobrtnutí
zvuk dobrý
přepínání rychlé
stanby neřeším - večer vypínám
vadí mi mapování tlačítek - v RSi jsem měl poslední stažitelnou kymap a box se dal krásně ovládat v základních funkcích palcem /zobrazení kanálů, výběr kanálu, volba hlasitosti, výběr pluginů, EPG atd./ : V tomto nefunguje. Poraďte, prosím, někdo, jak přemapovat tlačítka.
Jinak spokojenost - hlavně žádná tma na HDMI.
Na mapování tlačítek slouží Multi Quickbutton, můžeš si to skoro úplně přemapovat. Jinak já jsem spokojený, Mediacenter opravený, přehrává jak má, přepínání v normě. Oproti RSI možná pomalejší přepínání, ale to může být množstvím pluginů. EPG na Thoru OK
