fw 1.09.20
fw 1.09.20
--> Plugin is capable to download from one's web server
--> Menü - Utilities - Plugin : Blue Button - Download
--> Server URL : Menu - Installation - Network Setting : Firmware upgrade Server
--> Multipicture mosaic funtion bug : Amended (Blue Button)
--> Blind Scan search wrong : Amended
--> Duplicated channel or other bugs in Blind scan : Solved
--> Sky portal CH problem : Solved
--> Hang-up when make 10 min pause during playback rec file : Solved
--> EPG Daily Recording Bug : Solved
--> Working Screen saver during Radio service playback : Solved
--> Can not delete specific Rec file Bug(file name include / or special character) : Solve
--> Unstable Signal Quality : Solved
--> Background black issue in the info Banner's event name : Solved
--> Recording name saved as previous event name in event scheduled recording : Solved
--> Hang-up issue after Factory reset : Solved
--> Hang-up by Data Transfer Menu : Solved
--> When changing service up/down, loop supported in one tuner : Supported
--> Logical channel number (LCN) function off : Amended
--> Audio click noise : Solved
--> Lost descramble in Recording of the specific channel : Solved
--> Can not Recording in Service nemed in Turkish : Solved
--> Service find option in Service list manager : Added (Yellow Button)
--> Menu display spilit or broken : Solved
--> Screen Turns into Black&White in Resolution change mode : Solved
--> Flickering and spot in the screen with Scart in Resolution change mode : Solved
--> 2hours before EPG DATA screened out once open the EPG DATA stored in HDD : Solved
Pozor: Pred aktualizáciou zastavte všetky spustené pluginy v menu a po aktualizácii urobte továrenské nastavenie
http://reviservis.sk/fw/9100/FAC.HD%20B ... 1Jun17.ird
Re: fw 1.09.20
Caute Pani
mam taky mensi problem
Po instalacii nemozem spustit MCAS, Neviem co robim zle ale skusal som to niekolko krat a bez uspechu.
Internu citacku mam spustenu, MCAS mi spusti na par sekund a v zapeti mi ho vypne.
Dakujem
Dakujem
Re: fw 1.09.20
Interna citacka musi byt vypnuta!
baranček
Re: fw 1.09.20
Samozrejme interná čítačka vypnutá a Typ štartu MCASU zvoľ na automatický červeným tlačítkom.
- tulino
Re: fw 1.09.20
okrem automatickeho spustenia Mcasu, co v preklade znamena, ze sa bude po vypnuti tunera automaticky spustat/zapinat, ho este aj startni/zapni, pouzi ZELENE tlacidlo, mas dole v menu napovedu
Re: fw 1.09.20
A urobil si to tak ako sa píše v návode s červeným písmom ?
viewtopic.php?f=166&t=6404&p=52200#p52200
Re: fw 1.09.20
Ano postupoval som podla navodu,
aj som sa pokusal niekolko krat spustit MCAS maualne ale vzdy sa na par sekud da do statusu "STARTED"
aj prebehne na obrazovke zname SMART CARD INITIALIZING CRYPTOWORKS a vzapati ho vypne.
MCAS mam stiahnuty z Dempseyho navodu. Tak isto som skusal uz aj FW nainstalovat este raz ale tam asi problem nebude lebo TA3 ide.
tommix
Re: fw 1.09.20
Stiahni si posledný Mcas a nainštaluj:
viewtopic.php?f=173&t=4865&p=65123#p65123
AZBOX Premium
Tuner B : motor SG 2100
Tuner C : DVB-T
AZBOX Premium
Tuner C : DVB-T
- tulino
Re: fw 1.09.20
ak myslis ten z NOVEMBRA 2010, tak ten ti ist nemoze s firmwarom z JULA 2011, ten software sa vyvija, musis pouzivat aktualne verzie pluginovmbedo píše: MCAS mam stiahnuty z Dempseyho navodu.
(ani elektornkou z roku 1978 neopravis plazmu z roku 2008)
Re: fw 1.09.20
Niekde som tu čítal, že tento firmware je zatiaľ najlepší, tak mi nedalo a skúsil som ho nahodiť. Sklamanie je slabé slovo. Tak dlhú odozvu pri prepínaní som na tomto boxe zatiaľ ešte nezaznamenal. Tvorcovia dosiahli nový rekord. (takže zase späť na 1.09.09).
Pre tých ktorý hľadajú dobrý firmware pre tento box môžem odporučiť len 1.09.09. Po fw.1.08.75 je tento asi najlepší.
Humax IRHD 5100S, Showbox S-500, Openbox X820, offset al85 na 28,2E-23,5E-19,2E-5E, 2x DiseqC 2.0 SUS 44, LNB 3x GI + 1x Inverto, 3x Skylink, Tv Panasonic TX-P42X10Y
Re: fw 1.09.20
Nebol by som si tym taky isty. Tento prijimac je zial taky nespolahlivy a nevyspytatelny, ze po instalacii zabudnes napr. vypnut casovy posun, nechas tam USB, a odozvy su katastrofalne mozno u akejkolvek verzie fw. Teraz sa mi dostal po viac ako roku do ruk HD-BOX, lebo uzivatelov uz jednoducho prestalo bavit pozerat na hlasky "kanal zakodovany" (aj tak to vydrzali dlho), skusam tu uz par dni, vymenil som niekolko fw a nevidim podstatny rozdiel (ani oproti tomu fw 1.08.26, co tam bol povodne). Niekedy po instalacii boli odozvy take katastrofalne, ze som chcel hned fw vyhodit, ale ono sa to po nejakych upravach a zopar restartoch upravilo. Inak ale je tu u mna zatial hroza, a to skusam iba zdielanie karty, mgcamd aj oscam mi do rana spolahlivo zatuhnu. Existuje vobec nejaky soft, ktory by v tomto prijimaci vedel spolahlivo citat kartu v internej citacke a zaroven dalsiu zo vzdialeneho servera ? Nic viac by som radsej od tohto stroja necakal.
MartinK.
Re: fw 1.09.20
Ne idealni FW zatím neexistuje já už bojuju skoro 2 roky. Skoro každý den se v tom musím vrtat a když už si myslím, že jsem to dal dohromady tak se to posere.
maximální spokojenost
Re: fw 1.09.20
Existuje vôbec nejaký bezproblémový a dobre fungujúci HD príjmač s plnou podporou Irdeto kariet? (bez emu, zdieľania a podobných kravín)
