jaky oscam momentalne
- bambule
- Profík
poradí nekdo?
Re: jaky oscam momentalne
pouzival som oscam plus, ale ten celkom prvy , len oscam.keys som daval novy a pouzil som aj novy subor oscam.srvid .
teraz mam v boxe inu kartu, takze pouzivam iny oscam, ale ak budes davat z novsich, davaj az od verzie 513x a vyssie, tie nizsie verzie maju problem na niektorych TP z ASTRA19,2 (eurosport cz, hustler ..)
ak sa ti nechce experimentovat- oscam plus a mas pokoj.
dr.eam1
môže niekto vysvetliť čo presne znamená toto:
uniq = 0 # disabled, default
uniq = 1 # only one connection per user is allowed
uniq = 2 # set user to fake if source ip is different
(e.g. for newcamd clients with different CAIDs and ports)
uniq = 3 # only one connection per user, but only the last login will survive (old mpcs behavior)
uniq = 4 # set user only to fake if source ip is different, but only the last login will survive
aj ked si to preložím , neviem celkom presnena čo , alebo ako to funguje...
Ď.
Ď.
