RTi core RC6 Enigma 2 Image-diskusia
What is new :
- All drivers are rewriten and placed in Kernel space !!!
- Completly new kernel ( from 2.6.22-19 upgraded to 2.6.29 )
- New DVB-S2 Tuner driver for Elite - Premium - Premium+ and Ultra
- DVB-T and DVB-C for all models comming very soon.
- Twin tuner support for Premium+ comming very soon.
- Completly new Gstreamer build by sattomy ( Support for seeking added and Improved stability and playback )
- New and enhanced Videomode ( A/V Settings ) by telesat ( Added settings for DTS and AC3 )
- Deinterlace ( 1, 2, 3 - 1 and 2 give so far best result on our tests )
- Digital Audio settings ( Inside of A/V Settings )
- MediaCenter Plugin by sattomy
- Fixed problem for HD channels on 23.5 , 13 E, 0.8 and 30 w
- Improved Video quality
- Better STC compensation ( Switching to / from AC3 or DTS fixed )
hdcz
Re: RTi core RC6 Enigma 2 Image-diskusia
Instalace RC6 ...spustim v menu rescue mod a pockam, až me vypise IP adresu, tu dame do AZup 2.0.1, zvolim volbu instal E2/Kernel, vyskoci okno, kde zvolime soubor patch.E2, potvrdime a uz to jede...
AZbox premium 500gb + Azbox Elite.
dublaha
U mna zatial problem so zvukom. Neda sa ovladat hlasitost, zvuk ide stale na max.
- Stevo102
Skúšali ste niekto Glass System utility? Vyhadzuje zelenú obrazovku
dedecek_
Zdravím všechny moudré a hodné lidi!
Prosím o polopatický návod instalace z 4890 na RC6. Je mi téměř 70 let a anglicky neumím. Instalaci origo SW a E2 do RC4 jsem zvládnul, ale RC6 se bojím.
Moc děkuju.
Moc děkuju.
frcko73
postup je presne rovnaky...sa mi zda....akurat to idem skusat.
Elektronek
Prave nainstalovano, problem se zvukem stejny, jdu zkusit GSU atd..
frcko73
no insalacia prebehla ok....glasssysuti 2.42 ok.....aktivacia ccam 2.2.1=zelena smrt.....akykolvek pohyb v glasssysutil 2.42=zelena smrt.......,takze sa ani nemusim snazit,zelena smrt nastane za par sekund aj bez akehokolvek pohybu v boxe.
Elektronek
Stejny problem, dela to GSU.
boben
takže ten istý problém ako u RC5..nedá sa nejak spojazdniť sharing cez mgcamd bez GSU?
Azbox HD premium, Enigma2, Western digital Caviar Green D10EADS 1TB,
monkus
na oficialnom fore je uz fix pre ovladanie hlasitosti...
frcko73
no nic,kvoli nefunkcnosti GSU som sa vratil k RC4.
cetrojka
Zvuk opraven, bohužel nejde nastavit formát 16 : 9 , jedině nastavit rošířený obraz v TV.
Má někdo podobný problém?
Vyskusaj druhy update, robinek ho tam prave nahodil: viewtopic.php?f=256&t=7262
