Clarke Tech ET-9000 Control Centre Version 1.0 by Lee Hudson - Goldwafers.com
Installation Instructions
Unzip all the files and folders in the zip file to your local hard drive.
How to Use ET9000CC
1. Run the ET9000CC.exe application.
2. Enter the IP address of your Receiver in the IP Address field, example 192.168.1.5
3. If you have changed the password on your receiver, enter the password in the password field
otherwise leave blank.
4. Click Connect Button
Telnet
Self explanatory.
For a list of Busybox commands check out the following website:
_http://www.busybox.net/downloads/BusyBox.html
FTP
Click the FTP Button.
This will load FileZilla FTP Client and automatically connect to your Receiver
For instructions on using FileZilla check out the following website:
_http://wiki.filezilla-project.org/Using
Settings Backup
Click on Settings Backup Button.
Click the Backup Settings Button.
This will backup all the settings from the Receiver to the enigma2 and tuxbox folders on your PC HDD.
The /enigma2 and /tuxbox folders will be located in the same folder as this program.
Click the Restore Clarke Tech Receiver Settings Button.
All your backup data will be restored to the /etc/enigma2 and /etc/tuxbox folders on the Receiver
Once the files have successfully been restored you'll have to reboot the receiver by powering off
and on using the switch on the back of the receiver.
Media Files Manager
Uploading a Media File:
Select the Hard Drive and folder that contains your Media File.
Select the PVR device you have installed from the "Choose PVR Device" drop down window.
Click on the Local file you want to upload so it's highlighted in blue.
Click the Upload Button to transfer the file from your local HDD to the Receiver.
Downloading a Media File:
Select the Hard Drive and folder that you wish the file to be transferred too.
Click on the Remote file you want to download so it's highlighted in blue.
Click the Download Button to transfer the file from the Receiver to your local HDD.
Deleting Local File:
Select Local file so it's highlighted in blue.
Click Delete Local File Button.
Deleting Remote File:
Select remote file so it's highlighted in blue.
Click Delete Remote File Button.
HDD Manager
To mount and format a Hard Disk Drive do the following:
Select the Hard Disk type.
Click the Format Button.
This will erase all the data on the Receiver HDD.
Wait until the format has completed. It can take approx 10-15 minutes for a 1TB HDD.
You'll see a command prompt when the format has completed.
WebControl
Click the WebControl Button to open WebControl in your default web browser.
Upload Channel List
Select the local directory where the Channel List is sorted.
Double click the folder to list the files.
Click the "Upload Channel List" Button.
When you see the "Channel List Uploaded! Reboot Receiver" message box appear click OK.
Now Reboot Receiver by powering off and on.
Kind Regards
Lee.
Goldwafers.com
To keep informed on new developments follow us on Twitter and Youtube:
_http://twitter.com/goldwafers
_http://www.youtube.com/user/goldwafers
Released 20-12-2010
Pluginy a utility pro přijímač Clarke-Tech , Xtrend
Re: Clarke Tech ET-9000 Control Centre
Clarke Tech ET-9000 Control Centre Version 1.1 by Lee Hudson
Rozbaľte všetky súbory a priečinky v zip súbore na váš pevný disk v PC
Released 11-7-2011
How to Use ET9000CC
If your using a private local IP address enter the IP like this: 010.000.000.001
Telnet
Self explanatory.
FTP
Settings Backup
This will backup all the channel & satellite settings from the Receiver to the ******* and tuxbox folders on your PC HDD.
The /******* and /tuxbox folders will be located in the same folder as this program.
All your backup data will be restored to the /etc/******* and /etc/tuxbox folders on the Receiver
Media Files Manager
HDD Manager
WebControl
Upload Channel List
IPK Installer
Click the "..." Button to select the local directory where the "ipk" file is located.
Now click the "Upload and Install IPK File" Button.
The selected "ipk" file will be transferred to the /tmp folder then installed.
Details of the installation will be viewable in the terminal window.
Version History:
Version 1.1 Released 11-7-2011
Added IPK Installer.
Fixed Telnet paste issue. You can now use CTRL V or Right Mouse Button to paste code from clipboard to Telnet Window.
Version 1.0 Released 20-12-2010
First Public Beta Release.
Kind Regards
Lee.
Zpět na „Clarke-Tech , Xtrend Pluginy a utility“
