Skin HD Glass 16
- schmegea
Skin HD Glass 16
Skin HD Glass 16
v1.02
- změna konfigurace v menu_nastavení
- picony stejně jako ve 14
Měl jsem v testu pro azbox a můžu říct, že je to nádherný skin
Pokud chcete cokoliv vylepšit - pište
v1.02
- schmegea
Re: Skin HD Glass 16
- autorestart GUI after save, when set of Extra Infobar is changed
- fix main code crash when timeshift is used
- schmegea
- small changes in main code
- schmegea
- changed control code for infobar management (added keymap)
Vzkaz od tvůrce tohoto skvělého skinu:(bylo mi ctí pro něj testovat 16 aby byla vychytaná i pro azbox)
Warning: this is the last version, end of my job in skins, no more of skin in public version for now, end support of all my versions (glass series), sorry..... (may be meet sometimes in the future, bye)
(bylo mi ctí pro něj testovat tento skin ve verzi 16, před jeho prvním uveřejněním, aby byl funkční i pro azbox)
- schmegea
balíček pro výměnu 2 obrázků dreambox za obrázky Azboxu
- schmegea
2.15
- you can set permanent extrainfobar via setup, if this option is disabled press OK twice - extrainfobar is displayed
- added multiextrascreen option - choose screen via setup and press yellow button - actually 8 screens are defined, you can create and add/use own screen by editing file: G16screens.py located in: /usr/lib/enigma2/python/Screens/, you can define max 99 screens
- added icon set option - choose set of icons via setup and press blue button - actually 4 sets from max 5, you can add/change own set of icons, this set is used for active screen always (dirs for icons are: i_type-1(5) located in: /usr/share/enigma2/hd_glass16/icons/
- added new option: type of menu, may be the type list or icons (icons type is standardized for DMM image menu list, if your image have not a item in menu like icons (BP, LTmenu....) name of item is showed bottom with arrow icon -right bottom icon)
- updated name of satellites for all orbit
- added help button to show/hide detailed Ecm and TP info (help button is active only when tuner is active - if you watching movie from hdd, listen music, internet radio..., button is inactive), you can change mapping this button editing file: keymap2.xml located in: /usr/lib/enigma2/python/Plugins/Extensions/setupGlass16/, you can set position of the screen using arrow buttons on RC in setup and press OK button
- schmegea
HD Glass16 ver. 2.16
- fix enhanced info font size in screen 1 and 8
- schmegea
2.17
- fix screen 8 (renderer definition)
- schmegea
Když z editujete keymap2.xml located in: /usr/lib/enigma2/python/Plugins/Extensions/setupGlass16/
takto
restart gui
tlačitko resolution "show/hide detailed Ecm and TP info"
zařadím do balíčku change picture
takto
<keymap>
<map context="GlobalActions">
<key id="KEY_TV" mapto="showSpecialScreen" flags="m" />
</map>
</keymap>
restart gui
- schmegea
- added mapped RESOLUTION button to HELP as dreambox
prosím o test snad to mám dobře
- schmegea
- added 2xOK function - if permanent extrainfobar is enabled, you can use "user code/screen", may be enabled/disabled via setup of skin ( edit/create code in the file G16_UserInfo.py in /usr..Screens - examle: G16_UserInfo-example.py), ipk file have my user code, when new the G16_UserInfo.py is created, my code will be destroyed
- schmegea
HD GLASS 2.21
- fixed bug when permanent extrainfobar is disabled
- fixed virtualkeybord.py (thx petrkl12)
- small update of extrascreen 1
balíček azbox-change-picture-icon-menu-skin-hdglass16_2.19_mipsel.rar instalovat jen pokud máte nastaveno ICON MENU, po instalaci můžete přepnout na LIST menu,
tento balíček vymění obrázky dreamboxu za obrázky azboxu,
přiřadí v keymap.xml tlačítku resolution funkci HELP
změní barvu EPG programu v channel selection na oranžovou.
- schmegea
2.22
- splitted detection of type cam mbox and mgcamd
- fixed detection of mgcamd (GP3)
- schmegea
HD Glass16 ver. 2.23
- fixed network test
- schmegea
HD Glass16 ver. 2.25
- added correct detection of AGC for dm800se ( used in screens - 1, 7, 8)
- changed the time activity of oled roller from 100x to infinity if name of the channel is too long
