Zdravim mam Azbox HD s firmwarem 0.9.4931 a spravuji jej pre Maz3.
Co bych chtel? Nahravat na sitovy disk, ktery bezi na routeru Asus Wl-500W na sambe. Na prehravani ho vidim.
Pred rokem jsem na forech resil, musel se do Azboxu pichnut USB, pak na nej namount sitak a strcit ten script do startovaciho scriptu, aby se to vzdy mountnulo.
1. Neni po roce uz hotovy nekde nejaky script, ktery funguje a rychle se zavadi?
2. Nebo vytvoreny plugin, jez by to umel?
3. Nebo muze mi prosim nekdo postup zopakovat, nmohu to na webu najit ani pres strycka Googla. (Kam mamc co naspat, jak ma vypadat mount prikaz, kam napsat aby to startovalo i po restartu a kde popripade nastavit nejaka prava)
Moc diky za pripadne odpovedi.
Sitovy disk nahravani (script?)
Re: Sitovy disk nahravani (script?)
Mounting Wizard v1.3 by Daniel sa vola taky plugin co by to mal robit
ale inac to funguje nejak takto:
mount -t smb 192.168.x.xx:/dir/to_your/music /DATA/music
atd
pripadne si urobit zaznam do /etc/fstab ale to by som nerobil
pripadne si mozes do openxcas pridat ten mount ako dalsi cas a vies si to potom krizikom enablovat/disablovat
tu mas anglicky navod na to
Make a new folder in the OpenXCAS plugin directory on the Azbox:
create a file in this folder with the name mount.sh with the following content:
Create a file called openxcas.conf in the same folder:
then do a:
in the same folder to give the files execute rights.
Go up one folder into /EMU/OpenXCAS and add a line in the module.seq file called mount (a # in front of a line means the plugin is deactivated).
Then you can select the plugin in the OpenXCAS menu called mount and start it with the OK or yellow button.
You should see the new files in the Movie and Music menu entries.
akurat si to nfs vymen za smb ak to mas na windowsovom share to co chces mountovat.
atd
cd /EMU/OpenXCAS
mkdir mount
cd mount
#!/bin/sh
mount -t nfs 192.168.x.xx:/dir/to_your/video /DATA/movie -o nolock,soft,rsize=8192,wsize=8192
mount -t nfs 192.168.x.xx:/dir/to_your/music /DATA/music
[module]
name = mount
daemon = mount.sh
version = 1.0
chmod 0755 *
