MCAS
MCAS
Zatial najstabilnejsi EMU plugin, aky som skusal, FW: 1.07.89
Pri nahravani cez FTP nezabudnite na oba plugin subory nastavit atribut 755,
ja mam vrchnu citacku zablendovanu, autor pise, ze podporuje obe citacky.
- MCAS Reader update + improved
- EMU conflict resolved with MCAS
- Timing + EMM fix.
- Fixed various minor bugs
- Both card readers are now supported.
- Timing + EMM fix.
Naposledy upravil(a) 7andy7 dne 27 úno 2010, 10:02, celkem upraveno 1 x.
Re: MCAS 12.02.2010
- NDS Cards imporved (Sky Italia etc.)
- SmartCard Monitoring OSD Banner + fonts extended
- MCAS Cardslot + SamrtCard upgrade
- Adjustment CardSlot 1+2
- Keydatabase (Keditor) update
- Important : Pls use with SW 10789 !
--> existing Plugin Format User Data (Green Button) User Data Download !
Re: MCAS
MCAS 04.03.2010 - verzia pre fw 1.07.94
rozbalit a nahrat cez USB , alebo prekopirovat do /var/ . Nezabudnite na chmod 755 !
Re: MCAS
MCAS 18.03.2010 použiteľný s firmware 1.07.97
Pri nahrávaní cez FTP nezabudnite na chmod (atribut) 755
- TimeShift + Record bug fix (forward back spooling,trickmode)
- Stability imporved
- Minor bugs fix.
- Important : Pls use with SW 10797 !
- TimeShift + Aufnahme fehler behoben (vor-zurück spulen)
- Stabilität verbessert
- Kleine fehler behoben
- Wichtig : Bitte mit SW 10797 nutzen !
--> bestehende Plugin Nutzerdaten Formatieren (Grüne Taste) Software Download Fenster !
Uzivajte!
- Minor bugs fix.
Uzivajte!
Re: MCAS
čerstvý mcas
Re: MCAS
MCAS - 29.03.2010
Nagra library update
- Tivusat fix.
- TNT fix.
- Syk Italia fix.
- Init. bug fix.
- DB update
- Speed improved
- Important :
- Tivusat fix.
- TNT fix.
- Syk Italia fix.
- Init. bug fix.
- DB update
- Speed improved
- Important :
Re: MCAS
MCAS
- Nova Cy / Hotbird /
Re: MCAS
octaCAM__MCAS_EMU__12042010
- Canal+ NL EMU fix. (Ird2, Astra19.2E)
--> http://www.lyngsat.com/packages/canaldigitaal19.html
- Bulsatcom EMU fix. (ird2, Hellas Sat 39E)
--> http://www.lyngsat.com/packages/bulsatcom.html
- Nagra MCAS fix.
- NOVA CY (zypern) EMU add. IRD2 (Hotbird 13 ost /east) 10.April !
--> http://www.lyngsat.com/packages/nova.html
- Nagra MCAS fix.
Re: MCAS
octaCAM__MCAS_EMU__13042010_2nd
- RSA bug fix.
- Boykey bug fix.
- testujte s novým súborom key.data
Pred skopírovaním zastavte emulátor v menu plugin
key .data extrahujte a skopírujte cez ftp do root/var
Ja som preventívne zmenil aj atribúty na 755
potom reštartnite box a spustite emulátor
- RSA bug fix.
- Boykey bug fix.
Re: MCAS
- TV Globo AU fix. (Hotbird 13E)
Re: MCAS
- Keditor update
--> Plugin Menu : Keditor start with green Button & RESET keys with Blue Button
- DigiTv Au improved (Thor 0.8W)
- RAI AU fix. (Hotbird 13E)
--> Wait arround 1 hour auf Rai channel !
- SC Treiber fix.
- SC Treiber fix.
Re: MCAS
MCAS 24.05.2010
Re: MCAS
keydata MCAS - fix - Canal+ NL fix. Astra19,2E 25.05.2010
Re: MCAS
- NDS Algo bug fix.
- Sky Italia bug fix.
