Xcam emu pre fw od verzie 1.07.89
1. Download IRD v.1.07.89 to the PVR.
2. Unzip plugin.zip and find "bin" and "etc".
3. Make a folder "plugin" and copy "bin" and "etc" into the "plugin" folder.
4. Copy "plugin" into a USB stick.
5. Connect the USB stick to the PVR in Live mode.
6. Download "plugin" to the PVR (you can find "plugin" with Left/Right button of Remote)
7. In the PVR, go to Menu > Utilites > Plugin.
8. You can see useful menus and set each menu.
** xcamclient is start/stop the C/S of the embedded config.
** You don't need to care about internal card reader on/off from now on.
this is all you want.
Re: Emu pluginy spustiteľné od fw 1.07.89
-MCAS
-XCam client + XCamConfiguje / newcamd-cccam-cccam2-aroureos-radegast-camd33-camd35-cardd-buffy
-EXSim
-EXSim_Y4
-Keditor
-EXSim
-EXSim_Y4
-Keditor
Oprava pre automaticky start XcamClient .
Po volbe autostart pre Xcam prida jeho spustaciu rutinu do suboru autostart.sh . Napriek tomu, XcamClient nenastartuje po vypnuti .
Pomocou ftp a PSpadu si opravte spustaci script takto:
sleep10;/var/bin/XcamClient
Xcam 05.04.2010
update CCcam protokol.
klient podporujuci protokoly: CCcam, aroureos, radegast, camd33, camd35, cardd, buffy, newcamd, gbox
Plugin instalovatelny z USB . Nezabudnite predchadzajucu verziu zmazat !!!
Re: Xcam emu pre fw od verzie 1.07.89
Xcam z 29.4.2010
- Sky HD problem fix.
- update : xcamclient, xcamconfigure & cardclient cfg
- Recording PaTv OK
- Ch zapping time HD to HD less 3 Sec.
- Ch zapping time SD to SD less 2 Sekunden.
- 2 REC. with 1 C line OK (but 2 C lines more better solution)
- Decoding REC ch. in PIP OK (Picture in Picture)
- Sky HD tets on CCCam Server 2011 212 214
- Big thanks to koivo !
- Recording PaTv OK
- Recording problem fix when Playback
- Stability improved
- XcamConfigure update
- Freezing CH except SkyHD correct.
- Auto Start problem fixed
- Playback problem fixed
- XcamClient new built
- Dôležité :
--> pred inštaláciou zmažte užívateľské dáta (Zelené tlačítko v menu upgrade) !
- Dôležité :
- Minor bugs fix. (Stability)
- Update :
--> XcamClient
--> XcamConfigure
--> cardclient.conf
- Test OK with SW V10826
- Dôležité :
- Update :
--> XcamClient
--> XcamConfigure
--> cardclient.conf
- Dôležité :
Re: Xcam emu pre fw od verzie 1.08.3x
- Update :
--> XcamClient
--> XcamConfigure
--> API 1,02 & V1083x
- Update :
--> XcamClient
--> XcamConfigure
- Improvements & minor bugs fix.
Update XcamClient
* oprava padania aplikacie
Pred instalaciou neodstranujte predchadzajucu verziu Xcamu ! staci stopnut Xcam , nahrat na USB kluc /plugin/, extrahovany z prilozeneho archivu a nainstalovat v boxe.
Nastavenia ostavaju doterajsie, Xcam sa po restarte spusti automaticky s vasimi starymi nastaveniami .
Update XcamClient 16.09.2010
rozbalit na usb kluc , tak aby vznikol adresar plugin a v nom vnoreny adresar/bin/ so subormi .
prekopirovat na usb kluc a nahrat v prijimaci, po vyzve.
Po restarte bude fungovat s Vasimi povodnymi nastaveniami.
Opat - ponechat vsetky subory - nic nemazat !- update : XcamXlient
--> Connect-Verlust problem fix.
- update : XcamClient
--> Shutdown (loss connect) bug fix.
--> Baglanti kopma hatasi fix.
16.September 2010
Xcam k fw 1.08.44
Opat stara znama chyba - XCamClient spusteny a nefunkcny. Oprava je jednoducha . Tu prilozeny subor rozbalit a vzniknuty adresar /plugin/ skopirovat na USB kluc. Vlozit do prijimaca a pockat na vyzvu k instalacii . Len nainstalovat- nic nemazat, povodny Xcam musi byt nainstalovany .
V Menu - plugin sa potom objavi polozka Xcam-Check , na tej polozke zvolte autostart -cervenym tlacitkom.
Xcam potom uz bude startovat automaticky a spravne .
Xcam k fw 1.08.44
- Disconnect bug fix.
- New function add. :
--> Live Tv Mode : press "0" (Null) Button
--> Xcam (cccam2) Infobox
--> Red & Green Button for reconnect & refresh
- update : XcamXlient & XcamConfigure
--> Pls use with SW V10844 !
