BusyBox v 1.14.2 (13.07.2009)
Currently defined functions:
ash, bunzip2, bzcat, cat, chmod, chown, chpasswd, chroot,
clear, cp, cut, date, dd, depmod, df, dmesg, du, echo, egrep,
env, false, fdisk, fgrep, free, fuser, getty, grep, gunzip,
halt, hostname, httpd, id, ifconfig, init, insmod, kill,
killall, killall5, linuxrc, ln, login, ls, lsmod, mkdir,
mknod, modprobe, more, mount, mv, netstat, nmeter, nohup,
passwd, pgrep, pidof, ping, pivot_root, poweroff, printenv,
ps, pwd, reboot, reset, rm, rmdir, rmmod, route, sh, sleep,
split, start-stop-daemon, stat, sync, tar, telnetd, top,
touch, true, tty, udhcpc, umount, uname, vi, which, yes,
zcat
Chybaju tu hlavne (podla mna ) :
wget ,alebo curl,alebo lynx
a aby sa v tom clovek mohol aj vrtat este : lsof a fuser
Zoznam podporovanych prikazov
Re: Zoznam podporovanych prikazov
Pridam aj novy zoznam prikazov pre verziu fw 1.07.36 - rozsireny na zelanie
nslookup, passwd, pgrep, pidof, ping, pivot_root, poweroff,
printenv, ps, pwd, reboot, reset, rm, rmdir, rmmod, route,
sh, sleep, split, start-stop-daemon, stat, sync, tar, telnetd,
top, touch, traceroute, true, tty, udhcpc, umount, uname,
uptime, vi, wget, which, yes, zcat
- messo
pridam este dolezite
diff - rozdiel medzi subormi
fsck.jfs - ekvivalent scandisku
gawk - programovaci jazyk na pracu z datami
hdparm/sdparm - parametre disku
nice - priorita procesu
tail - vypis zo suboru od urciteho riadku, alebo kolko poslednych riadkov atd....
Pri plugine HDDTEMP
/var/bin/hddtemp.sh - teplota interneho/usb disku
Priklad
Dolezite:
ls - vypis adresara
vi - textovy editor
Pri plugine HDDTEMP
Priklad
# /var/bin/hddtemp.sh -f /var/etc/hddtemp.db /dev/sda1
/dev/sda1: SAMSUNG HD502HI: 45 CDolezite:
ls - vypis adresara
vi - textovy editor
