pre nelinuxovych uzivatelov, aby stale nemuseli vypisovat celu cestu k spustitelnemu suboru (unrar, mc etc.), je vhodne nastavit premennu PATH a dat si vsetky spustitelne binarky a skripty do nejakeho adresara (v mojom pripade /DATA/hdb1/monkus/bin)
nastavenie zadam do spustacieho suboru /DISK2/etc/start.d/S10UserDefinedShell
start() {
echo "===> Starting user defined script"
echo "User script test" > /tmp/UserDefinedShellIsRunning
/MMP/usr/bin/vfd_display -td210 -led boff
cp /DATA/hdb1/monkus/config/resolv.conf /etc/resolv.conf
echo "export PATH=\$PATH:/DATA/hdb1/monkus/bin" >> /root/.bashrc
etc.
overime si to nasleodvne
MMP[start.d]$ bash
MMP[start.d]$ echo $PATH
/bin:/sbin:/usr/bin:/usr/sbin:/usr/bin/X11:/usr/local/bin:/DATA/hdb1/monkus/bin
MMP[start.d]$ ls -al /DATA/hdb1/monkus/bin/
drwxr-xr-x 2 root root 4096 Jun 15 18:11 ./
drwxr-xr-x 8 root root 4096 Jun 13 13:40 ../
-rwxr-xr-x 1 root root 2189980 Jun 15 18:10 mc*
-rwxr-xr-x 1 root root 391396 Jan 30 10:39 unrar*
MMP[start.d]$ pwd
/DISK2/etc/start.d
MMP[start.d]$ unrar
UNRAR 3.80 freeware Copyright (c) 1993-2008 Alexander Roshal
Usage: unrar <command> -<switch 1> -<switch N> <archive> <files...>
<@listfiles...> <path_to_extract\>
cesta k suborom (PATH)
Rady a návody pro majitele HD přijímače.
monkus
