Dobrý den,
řeším problém s OSCAM ymod1855 pod OpenRSI 3.0. Doteď bez potíží fungoval se SkyLink kartou (irdeto karta 0624 ). Zcela samovolně mě ale přestaly hrát všechny kódované programy. OSCAM běží bez problémů (v GSU - Universal Cams manager - vše zelené) ale programy stále nehrají. Nejspíše nastal nějaký problém v komunikaci s kartou.
UCM
CAMs(3): Oscam2 ymod 18t55
SRV(1): žádný
Bin files Ok, Cam/Srv Found
OK,UCM Cam/Srv running
UCM active Cam: Oscam2 ymod 18t55
UCM active Serv: None
Přikládám log ...
2017/02/14 20:09:49 1855 763054B0 r chid: 7FFE, date: 2017/01/31 - 2017/03/02, name: Product 7FFE
2017/02/14 20:09:49 1855 763054B0 r chid: FFD8, date: 2017/02/03 - 2017/03/05, name: Product FFD8
2017/02/14 20:09:49 1855 763054B0 r chid: FFD0, date: 2017/02/03 - 2017/03/05, name: Product FFD0
2017/02/14 20:09:49 1855 763054B0 r chid: 0000, date: 2000/01/00 - 2000/01/07, name: DownLoad00000000Ť
2017/02/14 20:09:49 1855 763054B0 r provider: 2, id: 08, name: Operator: FFFF
2017/02/14 20:09:50 1855 763054B0 r chid: 0000, date: 2000/01/00 - 2000/01/07, name: DownLoad00000000Ť
2017/02/14 20:09:50 1855 763054B0 r provider: 3, id: 0C, name: Operator: FFFF
2017/02/14 20:09:50 1855 763054B0 r provider: 4, id: 10, name: Operator: FFFF
2017/02/14 20:09:51 1855 763054B0 r chid: 0000, date: 2000/01/00 - 2000/01/07, name: DownLoad00000000Ť
2017/02/14 20:09:51 1855 763054B0 r [cryptoworks-reader] ready for requests
2017/02/14 20:09:51 1855 75B054B0 c azbox (0D96&000004/1F44/05A1/0000/80:3D31/00-00): not found (3404 ms) by skylink-cslink_karta (try 2) - CT 2/STV3
2017/02/14 20:09:51 1855 75B054B0 c azbox (0D96&000004/1F44/05A1/0000/80:3567/00-00): not found (2038 ms) by skylink-cslink_karta - CT 2/STV3
2017/02/14 20:09:51 1855 75B054B0 c dvbapi: try pids again #1
2017/02/14 20:09:51 1855 75B054B0 c azbox (0500&051910/1F44/05A2/0000/130:B345/00-00): rejected caid (3 ms) - 0500:1F44 unknown (invalid caid 500)
2017/02/14 20:09:57 1855 75B054B0 c azbox (0D96&000004/1F44/05A1/0000/80:3567/00-00): timeout (5089 ms) by skylink-cslink_karta (try 2) - CT 2/STV3
2017/02/14 20:09:57 1855 75B054B0 c dvbapi: Found 1 IRDETO ECM CHIDs
2017/02/14 20:09:57 1855 75B054B0 c azbox (0624&000000/1F44/05A0/0000/59:744A/00-00): rejected caid (1 ms) - CT 2/STV3 (invalid caid 624)
2017/02/14 20:09:57 1855 75B054B0 c dvbapi: try pids again #2
2017/02/14 20:09:57 1855 75B054B0 c azbox (0500&051910/1F44/05A2/0000/130:B345/00-00): rejected caid (3 ms) - 0500:1F44 unknown (invalid caid 500)
2017/02/14 20:10:00 1855 75B054B0 c azbox (0D96&000004/1F44/05A1/0000/80:4CB8/00-00): not found (223 ms) by skylink-cslink_karta - CT 2/STV3
2017/02/14 20:10:00 1855 75B054B0 c azbox (0624&000000/1F44/05A0/0000/59:06F7/00-00): rejected caid (1 ms) - CT 2/STV3 (invalid caid 624)
2017/02/14 20:10:00 1855 75B054B0 c dvbapi: try pids again #3
2017/02/14 20:10:00 1855 75B054B0 c dvbapi: can't decode channel
2017/02/14 20:10:00 1855 75B054B0 c azbox (0500&051910/1F44/05A2/0000/130:B345/00-00): rejected caid (3 ms) - 0500:1F44 unknown (invalid caid 500)
2017/02/14 20:10:03 1855 75B054B0 c dvbapi: can't decode channel
2017/02/14 20:10:03 1855 75B054B0 c azbox (0D96&000004/1F44/05A1/0000/80:3567/00-00): timeout (5657 ms) by skylink-cslink_karta (try 2) - CT 2/STV3
a konfiguraci oscam:
[global]
usrfile = /tmp/oscamuser.log
logfile = /tmp/oscam.log
cwlogdir = /tmp/oscam.cw
disablelog = 1
disableuserfile = 1
usrfileflag = 0
clienttimeout = 5000
fallbacktimeout = 2500
clientmaxidle = 120
failbantime = 0
bindwait = 120
netprio = 0
clientdyndns = 0
resolvedelay = 30
unlockparental = 0
nice = -10
serialreadertimeout = 1500
maxlogsize = 32
waitforcards = 0
preferlocalcards = 1
saveinithistory = 1
readerrestartseconds = 5
lb_mode = 0
lb_save = 0
lb_nbest_readers = 1
lb_nfb_readers = 1
lb_min_ecmcount = 5
lb_max_ecmcount = 500
lb_reopen_seconds = 900
[monitor]
port = 989
nocrypt = 127.0.0.1,192.168.1.0-192.168.1.255
aulow = 120
hideclient_to = 7
monlevel = 4
appendchaninfo = 1
[newcamd]
port = 15000@0D96:000004;15001@0D0F:000004,000008;15002@0D03:000004,000008
mgclient = 1
[cccam]
port = 8000
reshare = 1
version = 2.2.0
[dvbapi]
enabled = 1
au = 1
boxtype = azbox
user = azbox
pmt_mode = 0
priority = 0666,0D96,0D03,0D0F,0D70,0624,0D95
[webif]
httpport = 8888
httprefresh = 8
httpallowed = 127.0.0.1,192.168.0.0-192.168.255.255
Věděl by někdo vyčíst kde je zádrhel?
OSCAM ymod1855 = prestal dekodovad kartu
Otázky pro začátečníky E2
efendy55
Re: OSCAM ymod1855 = prestal dekodovad kartu
v users ktorý chceš aby ti ich posielal , napr. takto :
au = 1
a v redars napr. aj takto , alebo podla potreby :
emmcache = 0,1,2,1
používaš EMU ?? ked máš tak nastavený oscam ? pokial viem tak 0D03,0D0F,0D70 sú už vypnuté a tam vraj nič nefrčí ..... alebo sa mýlim ?????
au = 1
emmcache = 0,1,2,1
Všetko4K,Linux E2
EMU nepoužívám. Oscam jsem stáhl přes GSU, dále nahrál konfiguráky a jakmile se rozběhly kódované programy a nesekaly se nic jsem dále neřešil. Nyní běží stabilně.. jenom ty zápisy neprochází. Neřešil jsem jestli je Oscam nastaven na podporu EMU.efendy55 píše:v users ktorý chceš aby ti ich posielal , napr. takto :
au = 1
emmcache = 0,1,2,1
