Oscam - ERROR: no characters found in ATR!
kiregps
Potřebuji pomoc. Mám nově Xtrend ET7500 a dosud neaktivovanou kartu freesat (tj. asi Irdeto Ice). Image je Open ATV, nainstalovaný Oscam r11214. Nastavil jsem vše podle nejlepšího vědomí a svědomí, ale nedaří se připojit ke kartě. Připojuji obsahy konfiguračních souborů a výstup z logu. Předem děkuji za jakoukoliv radu...
oscam.server:
[reader]
label = freesat
description = freesat_ice
protocol = internal
device = /dev/sci0
caid = 0D97
force_irdeto = 1
detect = cd
mhz = 600
cardmhz = 2700
group = 1
emmcache = 1,3,2,0
oscam.conf:
[global]
logfile = /dev/tty
nice = -1
preferlocalcards = 1
[cache]
[cccam]
port = 12000
nodeid = 7F02E4421061144C
version = 2.3.0
reshare = 0
[dvbapi]
enabled = 1
au = 1
pmt_mode = 0
user = dvbapiau
boxtype = dreambox
[webif]
httpport = 83
httprefresh = 10
httppollrefresh = 10
httphideidleclients = 0
httpallowed = 127.0.0.1,192.168.0.0-192.168.255.255
oscam.user:
[account]
user = dvbapiau
pwd =
group = 1,2,3,4,5
uniq = 3
au = 1
oscam.dvbapi:
P: 0D96
P: 0D97
I: 0D03
I: 0D0F
I: 0D70
I: 0D02
I: 0B00
I: 1815
I: 0624
I: 0666
I: 0653
log:
2017/02/05 18:44:52 00000000 s (reader) freesat [internal] creating thread for device /dev/sci0
2017/02/05 18:44:52 00000000 s (stat) loadbalancer: could not open /tmp/.oscam/stat for reading (errno=2 No such file or directory)
2017/02/05 18:44:52 00000000 s (main) waiting for local card init
2017/02/05 18:44:52 3AC5DCA2 r (reader) freesat [internal] Reader initialized (device=/dev/sci0, detect=cd, pll max=27.00 MHz, wanted mhz=6.00 MHz)
2017/02/05 18:44:52 3AC5DCA2 r (reader) freesat [internal] Reader sci internal, detected box type: et7500
2017/02/05 18:44:52 2E7858FA h (webif) webif: decompressed 165742 bytes back into 394760 bytes
2017/02/05 18:44:52 2E7858FA h (webif) HTTP Server running. ip=0.0.0.0 port=83
2017/02/05 18:44:53 3AC5DCA2 r (reader) freesat [internal] card detected
2017/02/05 18:44:53 3AC5DCA2 r (reader) freesat [internal] ERROR: no characters found in ATR!
2017/02/05 18:44:53 3AC5DCA2 r (reader) freesat [internal] Deactivating card
2017/02/05 18:44:53 3AC5DCA2 r (reader) freesat [internal] Read ATR fail, attempt 1/7 fs = 9
2017/02/05 18:44:54 3AC5DCA2 r (reader) freesat [internal] ERROR: no characters found in ATR!
2017/02/05 18:44:54 3AC5DCA2 r (reader) freesat [internal] Deactivating card
2017/02/05 18:45:04 3AC5DCA2 r (reader) freesat [internal] Read ATR fail, attempt 7/7 fs = 3
2017/02/05 18:45:04 3AC5DCA2 r (reader) freesat [internal] Error activating card.
2017/02/05 18:45:05 3AC5DCA2 r (reader) freesat [internal] THIS WAS A FAILED START ATTEMPT No 1 out of max alloted of 1
2017/02/05 18:45:05 3AC5DCA2 r (reader) freesat [internal] card initializing error
oscam.server:
[reader]
label = freesat
protocol = internal
device = /dev/sci0
caid = 0D97
force_irdeto = 1
detect = cd
mhz = 600
cardmhz = 2700
group = 1
emmcache = 1,3,2,0
oscam.conf:
[global]
logfile = /dev/tty
nice = -1
[cache]
[cccam]
port = 12000
version = 2.3.0
reshare = 0
[dvbapi]
enabled = 1
au = 1
pmt_mode = 0
user = dvbapiau
boxtype = dreambox
[webif]
httpport = 83
httprefresh = 10
oscam.user:
[account]
user = dvbapiau
pwd =
group = 1,2,3,4,5
uniq = 3
au = 1
oscam.dvbapi:
P: 0D96
P: 0D97
I: 0D03
I: 0D0F
I: 0D70
I: 0D02
I: 0B00
I: 1815
I: 0624
I: 0666
I: 0653
log:
efendy55
Re: Oscam - ERROR: no characters found in ATR!
skús to takto....
[reader]
label = Upc
protocol = internal
device = /dev/sci0
detect = cd
mhz = 450
cardmhz = 2700
group = 1
emmcache = 0,1,2,1
je to karta ice a máš ju aktívnu ???
[reader]
label = Upc
protocol = internal
device = /dev/sci0
detect = cd
mhz = 450
cardmhz = 2700
group = 1
emmcache = 0,1,2,1
Všetko4K,Linux E2
kiregps
Karta je pár dní nová, takže předpokládám, že je Ice. Číslo karty začíná na 1022... Aktivovaná není, nemám jiné zařízení ani CA modul. Parametry jsem změnil, ale výsledek je stejný:
2017/02/05 23:22:10 3AC5DCA2 r (reader) freesat [internal] Reader initialized (device=/dev/sci0, detect=cd, pll max=27.00 MHz, wanted mhz=4.50 MHz)
2017/02/05 23:22:10 3AC5DCA2 r (reader) freesat [internal] Reader sci internal, detected box type: et7500
2017/02/05 23:22:10 2E7858FA h (webif) webif: decompressed 165742 bytes back into 394760 bytes
2017/02/05 23:22:10 2E7858FA h (webif) HTTP Server running. ip=0.0.0.0 port=83
2017/02/05 23:22:11 3AC5DCA2 r (reader) freesat [internal] card detected
2017/02/05 23:22:12 3AC5DCA2 r (reader) freesat [internal] ERROR: no characters found in ATR!
2017/02/05 23:22:12 3AC5DCA2 r (reader) freesat [internal] Deactivating card
kiregps
Ještě doplňuji, že o aktivaci jsem se už dvakrát snažil, ale neúspěšně. Pravdou je, že to bylo ještě s jiným nastavením oscamu.
efendy55
požiadaj providra o refresh karty . išla ti v nejakom uni boxe tá karta ??? nebola párovaná ? ak je to nová karta tak ti ju musí provider aktivovať a to im musíš zavolať a nahlásiť číslo karty , ináč ti nepôjde .
Všetko4K,Linux E2
kiregps
OK, díky. Zkusím tedy znovu požádat o aktivaci karty.
Důležité asi je zda chybová hláška "ERROR: no characters found in ATR!" je projevem neaktivované karty nebo projevem chybné komunikace s kartou...?
kiregps
Hmmmm, ATR je Answer to Reset (https://en.wikipedia.org/wiki/Answer_to_reset). To vypadá na chybu v základní komunikaci karty se čtečkou a ne o problém, že ještě není aktivovaná.
dym1
Ako tam mas vlozenu kartu cipom hore alebo dole?
kiregps
kiregps
V logu je vidět, že nejdřív čtečka píše "card detected". Nic z ní dál ale evidentně nevyčte. Zkoušel jsem obě čtečky, výsledek stejnej. Jediný co mi zbyde, je asi měnění frekvencí...
dym1
Nemam 7500 ale karta by mala byt cipom dole strana 13. Cipom hore je tusim iba v et9000. Skusal si ju otocit a restart boxu.kiregps píše:Čipem nahoru...
V et9x00 je karta čipom dole.
kiregps
Panebože, že by to byla takováhle kravina...
V manuálu to napsaný není, pouze obrázek, ze kterýho se dá soudit, že čipem dolů. Jestli je to fakt ono, hodím si mašli na nejbližším stromě. Každopádně díky za radu, hned večer to zkusím...
efendy55
hm , človeče .....
mala by ísť čipom dole a dúfam že dávaš čipom do boxu ......
UNI čítačka dekódovacích kariet (karta sa vkladá čipom dole), spolupracuje s kartami Skylink Irdeto , ICE a Freesat UPC CRW, ICE a CSlink Irdeto. Čítačka kariet nespolupracuje s kartami Skylink Irdeto standart M7!
Všetko4K,Linux E2
Kasr
Vo vypise ma mimo ine:
Takze karta je otocena spravne.
