WeTekPlay PBNIGMA VX 5.1
Odkaz pro stažení firmware Enigma2 a diskuze k firmware.
Moderátor: matchboxx
matchboxx
Příspěvek od matchboxx »
WeTekPlay PBNIGMA VX 5.1 SDcard 10.09.2015
ke stazeni: http://pb-download.com/images/5.1/wetek ... sdcard.zip
NOTE:
- This is still something like 'pre-Release Candidate/post Alpha' or really deep and dark Beta release!
- Fixes are *likely* to be issued on a daily basis. Sometimes more often, sometimes not.
- New E2 remote control unit is favored over the original RC (fixes coming soon).
- Some things like native media support for E2 worked better in PB 4.3, some things are much better in PB 5.x releases...
- Please check PB-Wetek.PDF for some specifics as compared to MIPS PB releases.
- For media playback (streams, mp4, mkv etc.) XBMC might be preferred option than various E2 media players. YMMV.
- In other words, internal E2 player, MP and MP2 are just for custom tests, pls do not use them for now.
- XBMC is at the moment meant to use original WeTek remote control unit, mouse mode. With Kodi, we plan to have better RC support.
- On a 1st start XMBC might be less responsive due to updates.
- Kodi 15.x is being polished, should be in PB feeds soon. Work in progress.
- Channel lists from Ciefp and Vhannibal are likely to be up to date, as well as Oscam (and emu).
- Inital boot (the very 1st one) may take some time as your SD card is partitioned and formatted.
- Warning: When mounting USB based media (sticks, HDDs) in PB device manager, please use /media/usbX path, i.e. try to avoid /media/hdd for now!
- As PB does not like automount stuff, after inserting USB stick/HDD restart of E2 might be needed. For now.
Thx to WeTek team who made this possible!
mihyli
Re: WeTekPlay PBNIGMA VX 5.1
Příspěvek od mihyli »
Nova verzia...12.10.2015
Changelog neviem najst.. :)
matchboxx
ke stazeni http://pb-download.com/images/5.1/wetek ... sdcard.zip
EDIT 12.9.15
- fixed (hopefully) local settings for Kodi like subtitles etc.
matchboxx
mihyli píše:Nova verzia...12.10.2015
Both tuners working...
matchboxx
WeTekPlay PBNIGMA VX 5.1 SDcard 15.09.2015
EDIT 15.9.15
- feeds updated
- E2 code
- DVB driver
- Kernel update
- Better support for small/original RC and OpenElec RC in Kodi
- Kodi userdata moved to extra partition on micro SD to avoid (over) filling of rootfs
- reflash needed
http://anonym.to/?http://pb-download.co ... sdcard.zip
matchboxx
wetekplay-PBNIGMA-VX-5.1-20150917
ke stazeni:http://pb-download.com/images/5.1/wetek ... sdcard.zip
- Kodi 15.1 included
- Samba -> NAS works fine in Kodi, for NFS, at the moment, 1st mount a NFS volume from E2, then root from Kodi. As always YMMV.
- New E2 RC/FB unit is preferred for now except in Kodi where only the original or Elec model RC/FB works, either in mouse or buttonMode.
- E2 media programs like internal PVR, MP or MP2 are there only for testing purposes. Media playback is preferred to be done by Kodi. You might need a reboot if E2 media players are used on certain files!
- Please do read about USB sticks/HDDs and mounting them as /media/usb via PB Device Manager. An E2 restart may be required for now after inserting an USB device. We are not in love with automount business for various tech reasons.
- Temporary removal of USB media should be done via USB eject plugin, permanent via PB device manager. Failure of following this, rather simple, procedure might spoil your media.
- Issues with some transponders are well known, work in progress (as many other stuff).
- Same goes for better support for the original (elipsoid) RC/FB.
- We are aware of (most) problems and working on them.
- FTP/telnet/ssh default password is 'powerboard'
- NAND version not planned at this stage. If ever.
- Reflash needed, simple online update won't do, probably reasonable to do a backup of your settings to an USB stick and do restore after flashing your micro SD card.
Good luck from PB team!
mihyli
Treba doplnit changelog, pretoze XBMC 13.2 uz v PB-Nigme nie je:
- misc E2 stuff
- XBMC out as it made problems for some addons
- Some repos in Kodi
- IPTV playback for settings like ciefp etc. vastly improved. Not done yet.
- reflash of micro SD card needed !
matchboxx
wetekplay-PBNIGMA-VX-5.1-20150919_sdcard
ke stazeni
In short:
matchboxx
wetekplay-PBNIGMA-VX-5.1-20150922
This image is still in infancy mode and should be used only by bold, brave and beautiful. Nevertheless, some might find it interesting.
Please do read included PDF & txt.
In short:
EDIT 22.9.15
- Added support for OE RC, cannot test.
mihyli
EDIT 23.9.15
- fixed problems/hang with Power button in Kodi
- fix some compatibility issues
matchboxx
27.09.2015
EDIT 27.9.15
- probably added support for OE RC power button, cannot test.
- no need for reflash, simple update would do.
matchboxx
29.9.2015
EDIT 29.9.15
- misc E2 stuff
- feeds updated, including v 11017 with major DVBAPI fixes, some lists
- more keymap options (Settings->System->Keymap org, wold, maybe one can work with Elec RC, no clue)
- improved CC manager
- extra partiton set to 'writeback' mode, check/fix after 5 reboots
- switch to Kodi 15.2
- yet again improved add-ons compatibility
- likely to support AirPlay
- context menu for flat E2 remote
- NFS shares acessible via direct Add Network Location (NFS browser still off) as well from 'old' E2 mount option
- somewhat snappier response
- sadly, micro SD reflash needed for now
matchboxx
1.10.2015
EDIT 1.10.15
- fixed RC select plugin, probably as well the favorite unknown zone - Elec RC, cannot test.
- added support for Xtrend et 10000 and Mutant hd2400 RCs, thx Hannes.
- added support for Alien2/1(newer) and Octagon SF8 RC. Alien RC map likely to work, well, more or less, with most of similar SH4 boxes. YMMV!
- more RC mappings likely to come. Or not, free time-good will related.
- fixed issues (hmm, ?) with some micro SD cards and rootfs partition
- probably a bit snappier response and more robust usage. Infancy mode, still testing.
- some changes related to extra partition.
- some changes with mounts of USB devices
- No need to reflash, except for those who might be having trouble with rootfs partition, as new kernel is in the image.
matchboxx
EDIT 3.10.15
- autofs fix by geko37
- no need to reflash
ke stazeni http://anonym.to/?http://pb-download.co ... sdcard.zip
matchboxx
EDIT 4.10.15
- Elec RC fix thx to mikecc and others, Elec keymap has to be changed from ..System->Keymap - Elec
Zpět na „Odkaz pro stažení firmware Enigma2 a diskuze k firmware“
