IKS a AZbox HD
IKS a AZbox HD
Viete co je to IKS ?
internetovy protokol na zdielanie cez internet pomocou UDP. Vyhodou je relativne vyssia bezpecnost. Pri UDP sa totiz komunikuje len jednym smerom - necaka sa na odpoved ci server rozumel, ale iba sa caka ci data prevezme . Co s nimi spravi - je jeho vec. Server (pre IKS v Korei) uz data potom dalej distribuuje podla poziadaviek klientov.
Zdielaju sa samozrejme ecm . Nic ine. Sak naco aj,ze ?
Su mnohe prijimace,ktore IKS maju ako sw podporu uz zabudovanu (napr Openbox S9 , S10....), ako plugin IKS mozno doinstalovat aj do dreamboxu . DM100 ma IKS priamo vo fw.
IKS je platena sluzba . Pre majitelov AZBOX HD mozno ale vyuzit mesacny trial - a preckat tak nedostupnost MTV :))
Ako na to :
Installing OpenXCas
press the home button and go to plugins and press ok now press the red button on the remote to add plugins
now press the blue button to edit one of the urls to this url http;//satlab.techsat.info/AZPlugins = AZP is in caps now press ok to set the url now press ok to log on now go to openxcas and press ok and it will load now
exit out and go to openxcas and press ok now go to download executable and press ok
now press the blue button to edit one of the urls.
add this url if it is not already there http://satlab.techsat.info/AZCamd and press ok
press ok to log on now go to multicas and press ok and it will load
now go down the list to NewCS and press ok and it will load
now exit out and then hard reboot the receiver with the power switch
turn the power back on press the home and go to plugins and press ok
go to Activation & priority setting and press ok
press the blue button to remove # from the front of multicas and NewCS
press the yellow button to start the cams then exit out and go to camd setup and press ok
go to smartcard interface and press ok
go down to smart card splitter & CS and press ok
right arrow to client newcamd and you are there add your server info
press the save button then do a reboot and you are done
Je to prevzate z amer. serveru , takze si to treba prelozit. Podstatne je ale spravne zadanie adresy serveru pre stiahnutie podpory. Ta je stale aktivna !
Vela stastia testerom a dajte vediet ako Ste dopadli.
Zpět na „AzBox HD diskuze“
