Readme_OCTAGON_SF10x8_HD_V11118__19_11_12
for Octagon HD SF1008, SF1008SE, SF1018 HDTV :
Changes :
- Upgrades & Imporvements :
--> Before Start update pls. stop PlugIns !
--> Pls. update Bootloder version (L1.54/L2.54) !
--> EPG hangup bug fix.
--> Network bug fixed for plugin.
--> Plugin API 1.16.1
--> Many hangup points fixed
Online SW upgrade : octagon-germany.de/download
Online Plugin & SW upgrade : octagon-forum.com/develop
IMPORTANT : Advice for Software and Setting Update
Please save/copy Swoftware & Setting files in MAIN Directory from your USB Stick !
Please make after SW update Factory Reset (System Recovery) !
SmartCard Activate : (Pls use Octacam Mcas Plugin)
Storage Setup`s (Save/Store to STB) :
Menu --> Installation --> System Recovery --> Press OK Button :
--> System restore to stored Position (recover/restore Backup)
--> Store System Data (Backup Store)
Storage Setup`s to USB Stick/Storage :
Menu --> System Tools --> Data Transfer --> Press OK Button :
--> Transfer All System Data to USB Storage
--> Transfer Service Data to USB Storage (Channel list)
--> Data Download from USB Storage
Sky Premiere Portal (Multifeed) - Taste --> Blue Button
Master Password : 1008, 1018
Connection STB to PC :
- Connect STB with LAN Cable to PC
- Menu --> Installation --> Netzwork Settings --> change DHCP off and ON
--> Pls. wait until your IP nummer showing
--> Workstation in PC --> In Address Bar \\ (flashx2) give \\IP number and Press ENTER
--> You can see : Root (LINUX) & Storage (Speicher SATA HDD + USB1 + USB2) !
--> Also can use Samba and FileZila Program !
Preco ho nema HD BOX ?
fw 1.11.18
Re: fw 1.11.18
Toto je diskusia k fw pre Hdboxy - nie pre Octagony. Buď teda tak láskavý a necpi to tam kde to nepatrí.
Presúvam
Presúvam
s@pro
Re: fw 1.11.18
Protože
1. to je zejména pro CI+ plus
2. --> EPG hangup bug fix. (mrkni kolikrát se ta kouzelná formulace opakuje za poslední rok )
4. nic významného tento soft neřeší
5. Další aktualizace API , tím pádem i pluginů , zase experimenty .
6 . Fotisácké softy se hodí tak každý třetí až čtvrtý , lidi nemají chuť jednou až dvakrát měsíčně si rozhodit přijímač jenom proto aby se zase vrátili o několik verzí zpátky .
Chtějí : pokud je něco nového tak jeden ale funkční .
atd atd ...
atd atd ...
s@pro
Re: fw 1.11.18
A ještě bych doplnil na téma stupidïty korejců z Fortisu ,
tisíckrát připomínané ,aby se před aktualizací s/w vyply automaticky pluginy .
Na každé škole na světě už v první tříde předmět "programování" se učí příkaz "KILL" .
Je třeba jich znova poslat do školy od první třídy ...
Na Octagon foru to píšou pokaždé u každého nového softu vypnout pluginy ! , tady se dost často na to zapomíná .
