CuBiC 2.0
The new DaCube Image 2.0 goes OpenPli now comes the Public Beta.
Features:
-enigma2 Base OpenPli 3
-CuBIC Core - based on openPli 3.0
-Linux Kernel - Vu+ 3.1.1, Dreambox 3.2.25, Xtrend 3.4.3
-DLNA Server
-UPNP Browser
-Online Update
-CuBiC HD Skin
-Share Bar with gBox Support
-YAMP Music Player
-Multi Language Support in our Panel (Ungarian, German, (Russian with Build 011) (We -search for translators)
-Online Feed
News:
Here is the public release from CuBiC 2.0 build 010.
The Image use Online Updates and you can if we release an new Build make an Update over our Panel.
Should an update failures, which can happen from time to time, so you can use the flash image that we deposit at any online update in our ULC.
With the Online Update feature will we give Long Time Support for our Images and we will make it with every Update an little bit better.
Bugtracker:
If you find Bugs, so can you use our Bugtracker.
For Hardware:
DM500 HD
DM7020 HD
DM800 SE
DM8000
VU+ Solo
VU+ DUO
VU+ UNO
VU+ ULTIMO
Xtrend et5x00
Xtrend et6x00
Xtrend et9x00
Changelog:
Build 010:
From openPLI Team:
All PLi Updates incl. Wed, 29 Aug 2012 21:16:30
From DaCube Team:
Change: Addon Manager to seperate Call Menü
-Fix: epg.dat HDD Spin problem
-Fix: Startproblem scam, gbox, mgcamd (Install from our Feed or use our offline Cam Package)
-Fix: BackupSuite was not working
-Fix: CronManager
-Change: OnlineUpdate shows now installable Packages before an upgrade runs
-New: YAMP integrated
-Remove: MediaPlayer
Tu stiahni img CuBiC 2.0
DaCube Image
Images pro přijímač Clarke-Tech ET9000 HD , Xtrend ET9x00
DaCube Image
Re: DaCube Image
Par screenov z img CuBiC 2.0:
Zpět na „Clarke-Tech ET9000 HD , Xtrend ET9x00 Images“
