NXP256 satdigitalne beta FW
005jon Slovakia
Příspěvek od 005jon »
Web browser zatiaľ nefunguje :90:
Testovaná karta 0D0F a 0666 :106:
funkčný Telnet & FTP :106:
Zmena menu
upravene web rozhranie http://IP_NXP256/
Pridaný CCcam 2.3.0
Servers/Clients
štart cez telnet
./usr/sbin/CCcam
Stop cez telnet
killall -9 CCcam
Potrebne súbory treba pridať : /mnt/huangpu/cccam/
cccam.rar
Web rozhranie http://IP_NXP256:16001
01:14:11.020 CCcam: ======================================================================
01:14:11.022 CCcam: starting CCcam 2.3.0 compiled on Dec 15 2011@23:38:08
01:14:11.023 CCcam: ======================================================================
01:14:11.024 CCcam: online using nodeId ebcd84c7de5fc5b5
01:14:11.046 CCcam: DM7025 detected
01:14:11.047 CCcam: create 8 cam device(s)
01:14:11.580 CCcam: added 264 keys from /mnt/huangpu/cccam/SoftCam.Key
01:14:11.604 CCcam: added 172 keys from /mnt/huangpu/cccam/AutoRoll.Key
01:14:11.618 CCcam: added 67 keys from /mnt/huangpu/cccam/constant.cw
01:14:11.673 CCcam: parsed 449 entries from /mnt/huangpu/cccam/CCcam.prio
01:14:11.730 CCcam: added 510 provider names from /mnt/huangpu/cccam/CCcam.providers
01:14:33.713 CCcam: added 11926 channel names from /mnt/huangpu/cccam/CCcam.channelinf01:14:33.809 CCcam: newca
CCcam - Nedokáže ovládať čítačku kariet & DVB API
DVB API treba použiť vstavaný protokol Cccam
IP:127.0.0.1
Port: 12000
Meno: NXP256
HESLO: NXP256
Informácie a menu čerpane zo zahraničných stránok @NOR SAT @يامن (@yamen )
Tak nie je to moja zásluha ja som to len prerobil pre Dreamsky NXP256
nxp256-satdigitalne-beta0-06-no-web.rar
__________________________________________________________________________________________________________________
NXP256 satdigitalne beta 0.07 no web
Opravene: WIFI USB ( testovane tenda w311u a Edimax EW-7318USq)
nxp256-satdigitalne-beta0-07-no-web.rar
NXP256_satdigitalne_beta0.10b_no_WEB
Doplnený driver- ftdi_sio.ko ( Smartreader )
Za driver ďakujem @pecou
oscam.server
[reader]
label = smargo_cw
enable = 1
protocol = mouse
device = /dev/ttyUSB0
detect = cd
mhz = 357
cardmhz = 357
group = 1
Zápisy prechádzajú cez oscam za použitia externej čítačky ( Smartreader )
Testovaná ICE skylink aj stará CW
NXP256_satdigitalne_beta0.10b_no_WEB.rar
NXP256_satdigitalne_beta0.12_no_WEB
Web NXP - Pridane a opravená štartovacie skripta pre CCcam, OSCAM a check (kontroluje každých 60s či funguje cccam alebo oscam pokiaľ nie automaticky ho naštartuje)
Možnosť si vybrať CCcam 2.3.0 alebo CCcam 2.1.1 v závislosti aké súbory nakopírujete do NXP cez FTP
CCcam 2.3.0.rar
CCcam 2.1.1.rar
CCcam - Nedokáže ovládať internu čítačku kariet, len externej čítačky ( Smartreader )
SERIAL READER : /dev/ttyUSB0
Na dekódovanie obrazu treba použiť vstavaný protokol Cccam
IP:127.0.0.1
Port: 12000
Meno: NXP256
HESLO: NXP256
nxp256-satdigitalne-beta0-12-no-web.rar
NXP256_satdigitalne_beta0.15_no_WEB
Fw je postavený na základe Dreamsky-NXP256HDV1.70-2012-9-19
Dôvod - YouTube a prechod zápisov na ICE kartách
Pridane :
- FTP & telnet
- Web rozhranie NXP
- OSCAM 1.20-5820
- Cccam ( podľa výberu 2.1.1 alebo 2.3.0 )
Nove možnosti na FW: NXP256 satdigitalne beta 0.15
- Start all script in /mnt/huangpu/script in numerical order. /mnt/huangpu/script/S??* ;
- Doplnený driver- ftdi_sio.ko pre Smartreader (doplniť štartovacie scripta do /mnt/huangpu/script )
S98ftdi.rar
- OpenVPN (doplniť štartovacie scripta do /mnt/huangpu/script )
S15openvpn.rar
- ntpdate - Synchronizácia času cez internet - Local system time - (doplniť štartovacie scripta /mnt/huangpu/script) prikaz : ntpdate 217.147.223.78 &
- ctorrent (cez telnet prikaz: ctorrent)
Enhanced CTorrent dnh3.3.2   Original code Copyright: YuHong(992126018601033)
WARNING: THERE IS NO WARRANTY FOR CTorrent. USE AT YOUR OWN RISK!!!
General Options:
-h/-H           Show this message
-x              Decode metainfo (torrent) file only, don't download
-c              Check pieces only, don't download
-v              Verbose output (for debugging)
Download Options:
-e int          Exit while seed <int> hours later (default 72 hours)
-E num          Exit after seeding to <num> ratio (UL:DL)
-i ip           Listen for connections on specific IP address (default all/any)
-p port         Listen port (default 2706 -> 2106)
-I ip           Specify public/external IP address for peer connections
-u num or URL   Use an alternate announce (tracker) URL
-s filename     Download ("save as") to a different file or directory
-C cache_size   Cache size, unit MB (default 16MB)
-f              Force saved bitfield or seed mode (skip initial hash check)
-b filename     Specify bitfield save file (default is torrent+".bf")
-M max_peers    Max peers count (default 100)
-m min_peers    Min peers count (default 1)
-z slice_size   Download slice/block size, unit KB (default 16, max 128)
-n file_list    Specify file number(s) to download
-D rate         Max bandwidth down (unit KB/s)
-U rate         Max bandwidth up (unit KB/s)
-P peer_id      Set Peer ID prefix (default "-CD0303-")
-A user_agent   Set User-Agent header (default "Enhanced-CTorrent/dnh3.3.2")
-S host:port    Use CTCS server at host:port
-a              Preallocate files on disk
-T              Convert foreign filenames to printable text
-X command      Run command upon download completion ("user exit")
-d              Daemon mode (fork to background)
-dd             Daemon mode with I/O redirection
Make metainfo (torrent) file options:
-t              Create a new torrent file
-u URL          Tracker's URL
-l piece_len    Piece length (default 262144)
-s filename     Specify metainfo file name
-p              Private (disable peer exchange)
-c comment      Include a comment/description
Example:
ctorrent -s new_filename -e 12 -C 32 -p 6881 example.torrent
home page: http://ctorrent.sourceforge.net/
see also: http://www.rahul.net/dholmes/ctorrent/
bug report: http://sourceforge.net/projects/dtorrent/ or dholmes@ct.boxmail.com
original author: bsdi@sina.com
nxp256-satdigitalne-beta0.15-no-web.rar
Budiž světlo je to len testovací FW neviem čo tam všetko funguje a nefunguje ale jupici fungujú, možná že sa dočkáme ja originálneho FW od programátorov NXP.
NXP256_satdigitalne_beta0.17_no_WEB.rar
YouTube Fix
NXP256_satdigitalne_beta0.18_no_WEB.rar
YouTube - SD/HD Fix
g-share2-40 Fix (zmena adresy)
NXP256_satdigitalne_beta0.19_no_WEB.rar
mike69
Re: NXP256 satdigitalne beta 0.06
Příspěvek od mike69 »
Ešte som to nevyskúšal, ale vyzerá to zaujímavo. A ak sa časom do toho budú dať robiť nejaké pluginy a príp. aj skiny, tak by to bolo super.
skeczmen
Příspěvek od skeczmen »
Witam
Mam soft 1.58 i tuner nie wgrywa tego softu(zaczyna napis boot i spowrotem 1.58).
Jak wgrac ten nowy ?
cycu_14
Příspěvek od cycu_14 »
skeczmen píše:Witam
Wgtaj soft NXP256HD-MCas_1-11 ustawienie fabryczne a potem soft NXP256 satdigitalne beta 0.06
Soft jest OK!! tylko nie dzala F1-456 :51:
__________________
Illusion-M5-Combo >
90antena >
DREAMSKY 256 NXP >Obrázek
Openbox S9 HD PVR>
NBOX HD 250Gb ENIGMA 2>
Iamm NTR-S20 >
FERGUSON DF9000PVR (XCAM premium)
005jon Slovakia
@skeczmen - Základ FW je použití z FW 1.58 preto to píše 1.58 .......
@cycu_14 - F1-456 na FW NXP256 satdigitalne beta 0.06 je zámerné zmazane preto že je sprístupnené FTP aj telnet .
FRANTA1971
Příspěvek od FRANTA1971 »
Škoda nefunguje wifi :90:
005jon Slovakia
Mne wifi funguje aký tip USB WIFI máš ?.......išla ty aj FW 1,58 ? lebo ovládače sú prebraté z FW1.58
jojo1616
Příspěvek od jojo1616 »
005jon: Dobrá práce! Kdyby tak šlo ještě něco udělat s dlouhými odezvami uni čtečky v oscamu, tak budu velmi vděčný.
005jon Slovakia
Je tam problém z driverom čítačky a stým nespravím nič.
pecou Czech Republic
Příspěvek od pecou »
005jon píše:Je tam problém z driverom čítačky a stým nespravím nič.
Alespoň by bylo dobré, pokud je možné sáhnout do samotného firmware přidat podporu pro smargo usb čtečky. To znamená ftdi driver a možná i usbutils. Též je tam poměrně stará verze oscamu, pokoušel jsem se zkompilovat novou verzi. Ale nevím proč, ač se zdá, že běží, tak nejde webif, ikdyž je při kompilaci zapnutý.
tomi22
Příspěvek od tomi22 »
funguje tam aj extra movie alebo ne bol by som rad
005jon Slovakia
Mne skončilo extra movie pred rokom tak neviem odskúšať to iste platy z G-s*** treba otestovať kto ešte ma prístup.
FRANTA1971
Mně nejdou USB WIFI tenda w311u a well wcu150n.
na 1.58 jdou
005jon Slovakia
Re: NXP256 satdigitalne beta FW
NXP256 satdigitalne beta 0.07 no web :idea:
Opravene: WIFI USB ( testovane tenda w311u a Edimax EW-7318USq) :92:
Uložené v prvom príspevku navrchu.
pablo64
Příspěvek od pablo64 »
G SHARE ide bez probl. aj celkovo celkom fajn , web browser nepouzivam ani wifi takze ostanem pri 0.6 zatial
VU+ ZERO
Dreamsky NXP256 HD,
