nstream player plugin 0.3 RTMP
Společné Pluginy pro Dreambox .
005jon Slovakia
Příspěvek od 005jon »
Intallation step-by-step:
1. Install nstream player plugin on your box
enigma2-plugin-extensions-nstreamplayer_0.3_mipsel.rar
2. Extract
usr.rar
- copy rtmpgw to your box to /usr/bin folder and chmod it 755
- copy librtmp.so.0 to to /usr/lib
- copy rtmpgw_cam.sh the start stop script to your /usr/script directory and chmod it 755
3. Edit your nstream.xml file and copy it to /usr/lib/enigma2/python/Plugins/Extensions/nStreamPlayer
nstream.rar
4. start the script from your cam manager (cam named rtmpgw) or manually from telnet:
/usr/script/rtmpgw_cam.sh start
/usr/script/rtmpgw_cam.sh restart
Kvalita obrazu je super žiadne machule keď HD tak HD :106:
18+ :31:
005jon Slovakia
Re: nstream player plugin 0.3 RTMP
StreamPlayer with rtmpgw ipk install package
- added rtmpgw binaries
- added libgstflv.so and libgstrtmp.so gstreamer plugins
- added sample nstream.xml playlist with rtmp streams
- modified plugin.py to auto start-stop rtmpgw
Check the included nstream.xml and rtmpdump.txt help file for rtmp stream syntax. You can play also http and rtsp streams with nStreamPlayer.
vpvpvp
Příspěvek od vpvpvp »
005jon píše:StreamPlayer with rtmpgw ipk install package
Aj to funguje? Ja mám zelenu obrazovku a restart.
005jon Slovakia
ano funguje
Zpět na „Pluginy pro Dreambox“
