Ahoj,
mam AZbox a vlozenu CSLink kartu, a na LAN je Optibox ako klient
ked bezi CCcam na oboch (na azboxe je 2.3.0 na optiboxe 2.1.4) tak je vsetko OK.
ked na AZBoxe spustim oscam 1.00 nemam ziaden problem, vsetko slape, ale optibox na LAN neprecita kartu (na nom stale bezi CCcam)
treba nieco doplnit do CCcam.cfg na optiboxe ? (mam tam F: xxx xxx aj C: xxxxxxxxxxxx)
poradi niekto ?
CCcam and oscam
Re: CCcam and oscam
Treba Ti nakonfigurovat oscam ako server cccam pre klienta cccam...
myslim ze by stacilo v oscam.cfg pridat a upravit podla teba:
[cccam]
port = cislo_portu
version = verzia_cccam_u
build = xxxx
reshare = 2
a v oscam.user pridat klienta:
[account]
user = optibox
pwd = optibox
monlevel = 0
uniq = 1
group = 1
au = 0
caid = 0xxx
ident = 0xxx:yyyyyy
Udaje dopln podla Tvojich potrieb.
V optiboxe by si nemal menit nic ak budu zhodne udaje....
[cccam]
port = cislo_portu
build = xxxx
reshare = 2
[account]
user = optibox
pwd = optibox
monlevel = 0
uniq = 1
group = 1
au = 0
caid = 0xxx
ident = 0xxx:yyyyyy
- VeeN
Re: CCcam and oscam
skusal som vseliako ale oscam na optiboxe nevidno ...vikino píše:Treba Ti nakonfigurovat oscam ako server cccam pre klienta cccam...
skusme priklad nastavenia konfiguracie na na realnych datach:
cccam.cfg na optiboxe ver. 2.1.4:
F: sat1 sat1 yes
F: sat2 sat2 yes
F: sat3 sat3 yes
F: sat4 sat4 yes
F: sat5 sat5 yes
C: 192.168.1.12 12000 sat2 sat2 yes
cccam.cfg na AZboxe ver. 2.3.0:
F: sat1 sat1 yes
F: sat2 sat2 yes
F: sat3 sat3 yes
F: sat4 sat4 yes
F: sat5 sat5 yes
C: 192.168.1.11 12000 sat1 sat1
v takejto konfiguracii to slape, ak je spustene cez GSU ccam 2.3.0.
ked spustim oscam emu 1.00, na azboxe vsetko slape ale optibox sa zasekne :-(
oscam.conf:
# oscam.conf generated automatically by Streamboard OSCAM SVN_1.20_GSU_VERSION build #5918
# Read more: http://streamboard.gmc.to/svn/oscam/tru ... m.conf.txt
[global]
usrfile = /tmp/oscamuser.log
logfile = /tmp/oscam.log
cwlogdir = /tmp/oscam.cw
disablelog = 1
disableuserfile = 1
usrfileflag = 0
clienttimeout = 5000
fallbacktimeout = 2500
clientmaxidle = 120
failbantime = 0
bindwait = 120
netprio = 0
clientdyndns = 0
resolvedelay = 30
unlockparental = 0
nice = -10
serialreadertimeout = 1500
maxlogsize = 32
waitforcards = 0
preferlocalcards = 1
saveinithistory = 1
readerrestartseconds = 5
lb_mode = 0
lb_save = 0
lb_nbest_readers = 1
lb_nfb_readers = 1
lb_min_ecmcount = 5
lb_max_ecmcount = 500
lb_reopen_seconds = 900
[monitor]
port = 989
nocrypt = 127.0.0.1,192.168.1.0-192.168.1.255
aulow = 120
hideclient_to = 7
monlevel = 4
appendchaninfo = 1
[newcamd]
port = 15000@0D96:000004;15001@0D0F:000004,000008;15002@0D03:000004,000008
mgclient = 1
[cccam]
port = 12000
reshare = 2
version = 2.3.0
[dvbapi]
enabled = 1
au = 1
boxtype = azbox
user = azbox
pmt_mode = 0
priority = 0666,0D96,0D03,0D0F,0D70,0624,0D95
[webif]
httpport = 8888
httprefresh = 8
httpallowed = 127.0.0.1,192.168.0.0-192.168.255.255
oscam.user:
# oscam.user generated automatically by Streamboard OSCAM SVN_1.20_GSU_VERSION build #5918
# Read more: http://streamboard.gmc.to/svn/oscam/tru ... m.user.txt
[account]
#user = azbox
#pwd = azbox
user = sat2
pwd = sat2
monlevel = 0
uniq = 1
group = 1,2,3,4
#au = CRYPTOWORKS
au = 0
caid = 0D0F,0D03,0D96
#cccmaxhops = 0
Re: CCcam and oscam
Podla toho by to malo fungovat, ja by som skusil vymenit binarku za nejaku inu, bud unstable, alebo cs.
