Skin HD Glass 16
Skiny a picony E2
JIKARU Wales
Dal poděkování: 3 poděkování
Re: Skin HD Glass 16
Příspěvek od JIKARU »
HD Glass16 ver. 7.24
- fix installer to "py" cleaned images
- fix infoECM plugin by Duri
- added new Channelsel. type: PIG(+act,next,left)
- help updated in download
Update is available online via setup
JIKARU Wales
HD Glass16 ver. 7.37
- fix channel number in all Chammel Selection screens used default (by image)
services list
- removed screen for displaying Help - will be use default definition by image
- changed activating of the Special info from global action to infobarplugins
- added new Channelsel. type: Classical
- added autodetect images based on dmm image from 24.4.2013 and autodisable
option: Enable ChannelSel. percent
- fix main code for images based on dmm from 24.4.13 with full compatibility to older images
Recomendation: before update your image to image based on dmm image from 24.4.13, update skin to version 7.37
simonn2 Czech Republic
Příspěvek od simonn2 »
HD Glass16 ver. 7.83
- fix Channelsel. type: PIG(+several event) - show next 3 events
- added new Channelsel. type: New style(+several event)
- 2nd fix all renderers to display picon (IPTV channels only)
Thx @ shamann
VU+ SoloSE V2 (vždy nejnovější VTi), AZBOX Elite HD (OpenPLi 6.1)
HD Glass16 V7.88
- added new option in the setup: Restore config
(/usr/share/enigma2/hd_glass16/hdg16.conf)
1 after pressing "green", "OK" - always save complete renewable config
2 After activation "Restore config" will reset the values ??applicable
to verification
3 view diagnostics, if some incorrect value, the dump invalid parameters
- for defective items with type "set" to set the default value, others leave
it unchanged
4 you may use any number of config items in the config file, not necessarily all
- those who are not, leaving unchanged
5 the restoration and press cancel - uses the original value
6 after restoring verify the applicable Amended Nomenclature
7 after reconstruction automatically refresh display all settings
- updated pl, sk, cz, en, ru, de, it, uk, pt, tr, es, fa, al, ro translations
- added screen 39
- added icons type 14, 15 (prefered for screen 39)
- previews, icons sets and extrascreens graphics updated in download
HD Glass 16 ver. 8.03
New update:24.01.2014
- added detection of vu duo2
- added detection type "emu" if is used oscam and protocol "constcw"
Zpět na „Skiny a picony E2“
