Chybová hláška ERR:0x01
pofino
Re: Chybová hláška ERR:0x01
Jerry už je všetko v poriadku.Po prehratí cez porter nestačilo počkať len na vypísanie "100%"na prijímači,ale aj na "write 100%" a potom sa rozblikalo "Complete". Teraz už maká fw 1.08.65+Mcas - testujem.Snáď to pomože i ostatnym pri takomto probléme.Ste tu všetci skvelí moderátor. Veľká vďakajerry píše:Nie je problemom viacnasobne nahravanie cez porter. Len nahravaj spravny image.
HdboxFS9200/Fw Test/loader1.54/karta Skylink ICEvýmena/LacieRikiki 640gbHdd
gfi
Pokud by se nekdo setkal s "Error messages", tady jsou nektere poznamky ke kodum:
Jde o aktualni procesy, proto nejsou vsechny kody chybove hlasky.
0x00 No Error
0x01 Application Error
0x02 BlockXpress
0x03 InvalidFlash
0x04 Security Main BCB
0x05 Security Front PCB
0x10 System ID not match
0x11 Range (Downloading file is bigger than the arear reserved)
0x12 UartTimeOut (Serial communication error)
0x13 BlockCrc (Downloaded package file crashed)
0x14 DataType (Not supporting data type)
0x15 XfdVer (Not supporting IRD version)
0x20 OtaTimeOut (While OTA, the Antenna line is disconnected)
0x21 OtaCrc32 Ota downloaded file crashed
0x70 Kernel File system error
0x71 rootfs Error
0x72 device fs (Device file system error)
0x80 FlashWriting (Error During Flash writing)
0x81 EepromWriting
0x82 XfdmWriting (IRD Write ERROR)
0x83 EepromReading
0x90 USBNotFound
0x91 USBFatReadErr
0x92 USBFileFound
0x93 USBReadErr
0x00 No Error
0x02 BlockXpress
0x03 InvalidFlash
0x71 rootfs Error
0x81 EepromWriting
0x83 EepromReading
0x90 USBNotFound
0x91 USBFatReadErr
0x92 USBFileFound
0x93 USBReadErr
