Ahoj
tak už jsem se k tomu screenu dopracoval.
Je tam tohle:
Pulse 4K - Open PLI se Skylink prosba
JohnPeri
JohnPeri
Re: Pulse 4K - Open PLI se Skylink prosba
A ze stanice co nejede a má vyšší kodovaní jsem z položky Files získal tohle:
Unix starttime: 1697370061
Starttime: 15.10.2023 13:41:01
Version: oscam-1.20_svn-r11715
Compiler: arm-linux-gnueabihf
Box type: pulse4k (generic)
PID: 1974
TempDir: /tmp/.oscam
GBox tmp_dir: not defined using: /tmp/.oscam
ConfigDir: /etc/tuxbox/config/oscam/
WebifPort: 8081
Web interface support: yes
LiveLog support: yes
jQuery support intern: yes
Touch interface support: no
SSL support: no
DVB API support: yes
DVB API with AZBOX support: no
DVB API with MCA support: no
DVB API with COOLAPI support: no
DVB API with COOLAPI2 support: no
DVB API with STAPI support: no
DVB API with STAPI5 support: no
DVB API with NEUTRINO support: no
DVB API read-sdt charsets: no
Irdeto guessing: no
Anti-cascading support: no
Debug mode: no
Monitor: no
Loadbalancing support: no
Cache exchange support: no
Cache exchange AIO support: no
CW Cycle Check support: no
LCD support: no
LED support: no
Clockfix with realtime clock: no
IPv6 support: no
camd 3.3x: no
camd 3.5 UDP: yes
camd 3.5 TCP: yes
newcamd: yes
CCcam: yes
CCcam share: yes
gbox: yes
radegast: no
scam: no
serial: yes
constant CW: no
Pandora: no
ghttp: no
Reader support: yes
Nagra: yes
Nagra Merlin: yes
Irdeto: yes
Conax: yes
Cryptoworks: yes
Seca: yes
Viaccess: yes
NDS Videoguard: yes
DRE Crypt: yes
TONGFANG: yes
Bulcrypt: yes
Griffin: yes
DGCrypt: yes
cardreader_phoenix: yes
cardreader_drecas: no
cardreader_internal_azbox: no
cardreader_internal_coolapi: no
cardreader_internal_coolapi2: no
cardreader_internal_sci: yes
cardreader_sc8in1: no
cardreader_mp35: no
cardreader_smargo: no
cardreader_pcsc: no
cardreader_smartreader: no
cardreader_db2com: no
cardreader_stapi: no
cardreader_stapi5: no
cardreader_stinger: no
PID: 1974
WebifPort: 8081
SSL support: no
Irdeto guessing: no
Debug mode: no
Monitor: no
LCD support: no
LED support: no
IPv6 support: no
camd 3.3x: no
camd 3.5 UDP: yes
camd 3.5 TCP: yes
newcamd: yes
CCcam: yes
CCcam share: yes
gbox: yes
radegast: no
scam: no
serial: yes
constant CW: no
Pandora: no
ghttp: no
Reader support: yes
Nagra: yes
Nagra Merlin: yes
Irdeto: yes
Conax: yes
Cryptoworks: yes
Seca: yes
Viaccess: yes
NDS Videoguard: yes
DRE Crypt: yes
TONGFANG: yes
Bulcrypt: yes
Griffin: yes
DGCrypt: yes
cardreader_mp35: no
cardreader_pcsc: no
JohnPeri
A tohle mám z Open ATV 7.1 kde ty stanice s vyšším kodováním jedou:
Unix starttime: 1697370040
Starttime: 15.10.2023 13:40:40
Version: oscam-1.20_svn-r11704
PID: 2282
ConfigDir: /etc/tuxbox/config/oscam-stable/
WebifPort: 8888
SSL support: no
DVB API read-sdt charsets: yes
Irdeto guessing: yes
Debug mode: yes
Monitor: yes
Loadbalancing support: yes
LCD support: no
LED support: no
IPv6 support: no
camd 3.3x: no
camd 3.5 UDP: yes
camd 3.5 TCP: yes
newcamd: yes
CCcam: yes
CCcam share: yes
gbox: yes
radegast: yes
scam: yes
serial: no
constant CW: yes
Pandora: no
ghttp: no
Reader support: yes
Nagra: no - no EMM support!
Nagra Merlin: no - no EMM support!
Irdeto: yes
Conax: no - no EMM support!
Cryptoworks: yes
Seca: no - no EMM support!
Viaccess: no - no EMM support!
NDS Videoguard: no - no EMM support!
DRE Crypt: no - no EMM support!
TONGFANG: no - no EMM support!
Bulcrypt: no - no EMM support!
Griffin: no - no EMM support!
DGCrypt: no - no EMM support!
cardreader_mp35: no
cardreader_pcsc: no
Tak nevím jestli bych to měl na tom Open PLI upravit podle tohoto a nebo kde co přepsat aby to jelo i na Open PLI ?
Díky
PID: 2282
WebifPort: 8888
SSL support: no
Debug mode: yes
Monitor: yes
LCD support: no
LED support: no
IPv6 support: no
camd 3.3x: no
camd 3.5 UDP: yes
camd 3.5 TCP: yes
newcamd: yes
CCcam: yes
CCcam share: yes
gbox: yes
radegast: yes
scam: yes
serial: no
constant CW: yes
Pandora: no
ghttp: no
Reader support: yes
Irdeto: yes
Cryptoworks: yes
cardreader_mp35: no
cardreader_pcsc: no
Díky
Warder
Ten tvoj obrazok ukazuje presne co som ocakaval. A to, ze si do svojho boxu NEDAL ten Oscam odomna. Staci pozriet na VERZIU daneho oscamu.
Keby si tam dal oscam odomna, tak ten obrazok by vypadal nejak takto: a v log vypise oscamu by si mal nieco taketo 2023/10/15 14:08:16 0F86693F c (ecm) Octagon (0624@000000/A000/3736/73:3BBA50EF53AD242EB212DF6D80D8E130): found (91 ms) by Skylink-2 (L/2/21/21) - CANAL+ Action
A ten tvoj vypis by vypadal nejak takto:
Unix starttime: 1697302959
Starttime: 11.12.2022 19:02:39
Version: oscam--WARDER--r11-c/2022-M7-ICAM
Compiler: arm-linux-gnueabihf-ssl
Box type: sf8008 (generic)
PID: 2266
ConfigDir: /etc/tuxbox/config/oscam-uni/
WebifPort: 8888
A kedze, aj ked som ti poslal potrebne veci aj navodom a aj tak si to nespravil, tak s tebou koncim.
PID: 2266
WebifPort: 8888
Naposledy upravil(a) Warder dne 15 říj 2023, 14:20, celkem upraveno 1 x.
JohnPeri
Takže pomocí jiného kolegy jsem udělal toto:
Nakopírovat do OpenWeb do karty Files a oscam.server tam všetko smazat a pak kopírovat text.
[reader]
label = skylink_l2b_
protocol = internal
device = /dev/sci0
autospeed = 0
caid = 0624
boxkey = 171282DC2D6DE772
force_irdeto = 1
needsemmfirst = 1
detect = cd
mhz = 450
cardmhz = 2700
group = 1
emmcache = 0,2,15,0
blockemm-unknown = 1
disablecrccws = 1
Pak jsem dostal ve výpisu toto: A jede to.
Ale i tak díky.
[reader]
protocol = internal
device = /dev/sci0
autospeed = 0
caid = 0624
force_irdeto = 1
needsemmfirst = 1
detect = cd
mhz = 450
cardmhz = 2700
group = 1
emmcache = 0,2,15,0
disablecrccws = 1
Ale i tak díky.
JohnPeri
Ahoj
tak kdyby to někdo opravdu chtěl, nahrál jsem to sem:
https://webshare.cz/#/file/GNDAZIKyrr/b ... 7-1829-zip
Login a hesla jsou root
