Zápisy
Honk76
Zápisy
Příspěvek od Honk76 »
Neprochází mi zápisy přes newcs a mgcamd zde přikládám nastavení můžete někdo z Vás zkušených mrknout či to mám správně děkuji.AZbox hd elite firmware 0.9.4890 Ice karta podle mě co jsem vyčetl na fóru je mám zapnuté
# EMM messages
# 00 don't show any EMMs (default)
# 01 show only valid EMMs
# 02 show valid and bad EMMs with complete data display
M: { 01 }
# ECM messages
# 00 don't show any ECMs
# 01 show only valid ECMs (default)
# 02 show valid and bad ECMs with complete data display
C: { 02 }
# AU
# 01 enable AU
# 02 AU Auto
# 03 network cards update only
A: { 01 }
# key update (sum 01 or 02 with 04)
# 01 update only new keys, default setting
# 02 update all keys (used for valid PMK checking)
# 04 replace (not add) http-aes keys, only first key replaced !
U: { 01 }
# config files folder (softcam, autoroll, ignore/priority)
# 00 files in /var/keys
# 01 files in /tmp
T: { 00 }
# network mode, use summ for several clients
# 00 no network (default)
# 01 newcamd netclient
# 02 radegast netclient
# 04 camd3 netclient
G: { 33 }
# network retry, use summ for several options
# 00 disable
# 01 retry every new ecm
# 02 try to connect to offline shares every Q: seconds
# 04 try to detect and fast reconnect to lost (and not used atm) server
N: { 07 }
# network ecm timeout in seconds
K: { 5 }
# newcamd dead routes connect retry, sec
Q: { 20 }
# network shares priority
# 00 newcamd, radegast, camd3 (default)
# 01 camd3, radegast, newcamd
# 02 newcamd, camd3, radegast
P: { 02 }
# on screen display type
# 00 No OSD (default)
# 01 neutrino
# 02 enigma
# 03 relook
O: { 00 }
# on screen display Options, summ of:
# 01 show emu ecm
# 02 show network shares messages
# 04 show decoding failed / fta
# 08 show emm keys update
S: { 03 }
# Log option, summ of:
# 00 Off
# 01 Network
# 02 console
# 04 file, appended ! delete it by yourself, before it eat all your hdd
L: { 01 } 192.168.1.100 514
# keep ecm cache, seconds
E: { 15 }
# cache option, summ of:
# 00 Off (default)
# 01 Ecm pids cache, store pids used to decode in /tmp/ca_cache.list at exit, load at startup, same syntax as restore.list
# 02 Ecm data cache, remember CW for (E:) time
# 04 Emm cache for network cards, do not resend the same emm twice, cache not cleared until restart
H: { 06 }
# reread files, summ of:
# 00 No (default)
# 01 reread config file on channel change (including priority and ignore, but not replace/cache)
# 02 reread SoftCam.Key on channel change
# 04 reread SoftCam.Key if file changed
R: { 04 }
# debug, summ of
# 00 off (default)
# 01 debug ecm
# 02 debug emm
# 04 debug network ecm
# 08 debug network emm
# 16 debug network login
# 32 show mem/cpu stats every 1 min
# 64 add timestamp to log messages
D: { 04 }
# box type
# 00 autodetect, change only if you think wrong type detected.
# 01 dbox2
# 02 dreambox
# 03 triple-dragon
# 04 relook
# 05 openbox
B: { 00 }
# urls for aes keys update, any number or urls allowed,
# url data must contain key in format 0500:007C00:0000000000:00:key1:keyl
#W: { http://some.host.com/keys.php }
<?xml version="1.0"?>
<newCSconfig>
<readers name="Card Readers">
<device>
<name>upper</name>
<type>azbox</type>
<node>/dev/scard</node>
<export>yes</export>
<enabled>yes</enabled>
<blocksa>no</blocksa>
<blockua>no</blockua>
<blockga>no</blockga>
<newcamd_port>20000</newcamd_port>
<autosid>no</autosid>
<carddetect>yes</carddetect>
<priority>hard</priority>
<PTShandshake>no</PTShandshake>
<mhz>350</mhz>
<boxkey>79FDC0E18D278138</boxkey>
<rsa>9ED52515321F04BCF7772151149D6895154B559A8D825A4E7D711A9FAFD5C66BF64689501B254DF1832F754C21095379CF97B4E5BE6E0F1C9CEBF0A0E91D5ACD</rsa>
</device>
</readers>
<xmlserver>
<enabled>0</enabled>
</xmlserver>
<radegastserver>
</radegastserver>
<cache>
<emm>10</emm>
<ecm>-1</ecm>
</cache>
<debug>
<darint39>sintoi51</darint39>
<level>internal</level>
<type>all</type>
<output>console, tcp</output>
<logfile>/tmp/newcs.txt</logfile>
<console_options></console_options>
<file_options></file_options>
<udp_host>172.16.1.1</udp_host>
<udp_port>9000</udp_port>
<udp_options></udp_options>
<tcp_port>1001</tcp_port>
<tcp_options></tcp_options>
</debug>
<newcamdserver>
<name>local</name>
<deskey>01 02 03 04 05 06 07 08 09 10 11 12 13 14</deskey>
<user>
<name>dummy</name>
<password>dummy</password>
<hostname>127.0.0.1</hostname>
<port>12000</port>
<au>on</au>
</user>
<user>
<name>a</name>
<password>1</password>
</user>
Yano
Re: Zápisy
Příspěvek od Yano »
Neviem ci sa nieco zmenilo, uz davno mam oscam a E2, ale na ICE a prechod zapisov sa pouzival MULTICAS.
newcs+mgcamd uz bol len na nerusene sledovanie.
alihen
Re: Zápisy
Příspěvek od alihen »
mam ten isty pocit ako Yano. je to uz davno co som to mal tiez takto, no oscam v E2 ide lepsie
Honk76
Re: Zápisy
Ano v druhém Azboxu mám E2+oscam ale nepřijde mi to tak stabilní jako tato kombinace která chodí 100% již přes rok a někde jsem četl že i zápisy se tam dají nastavit aby procházeli ale nějak to nefunguje.A asi díky E2 už nikdo neporadí??
qswi3120
Re: Zápisy
Příspěvek od qswi3120 »
tiez som zacal vcera skusat newcs1.6.13+mgcamd1.35 na verzii 0.9.5309. Nemozem to rozchodit, nastavenia mam take ako ty.
Podarilo sa ti medzitym spojazdnit ten tvoj? Ak ano prosim posli info.
Rad by som vyskusal server newcs na origo FW oproti klientovi mgsamd/Ccam... na E2 s kernelom 3.4.4
Mimochodom ako sa da zmenit email na fore, nasiel som moznost zmenit iba heslo. Diky
Technisat Multitenne 45 + LNB for 4 satellites - AZBOX HD - Samsung LE52A656, Selfsat H21D4 Flachantenne Quad LNB - AZBOX HD+(2xDVB-S2) - LG 42SL8000
havranek
Re: Zápisy
Příspěvek od havranek »
Zdar, mám FW 0.5020 vyměnil jsem kartu skylink výměna a nejsem stavu donutit multicas aby prošly zápisy. Vyzkoušel jsem všechny možné setingi zde z fora s bakulou reautorizací a už druhý týden 0 bodů. Nenapadá někoho čím by to mohlo být? Díky moc.
marnav
Re: Zápisy
Příspěvek od marnav »
Strčit do jiného boxu či do modulu.
HDBOX FS-9105 HD Plus, 2.11.90 4x
ICE, Skylink, Fuba 85, Monoblock Quad 23,5+19,2
havranek
Re: Zápisy
Pokud projdou tak se uloží na kartu a zase to cca 14 dnů pojede? A co pak po těch 14 dnech už by to mohlo chodit v mém stroji?
Začínám zvažovat i ten modul, ale zase pomalu začínám uvažovat o E2. Díky
havranek
Re: Zápisy
Tak jsem kartu odnesl do Omka tam ve vteřině po reautorizaci zabrala, jela cca 14dnů, když jsem koukal na ipazboxu:1001/sub tak tabulka byla prázdná, ale jelo to. Už jsem vyzkoušel všechny možné setings, ale stále 0 bodů. Nedokáže mě prosím někdo nějak nakopnout co dělám špatně než nakopnu Box z okna (už začínám otvírat okno). Momentálně mi ipazboxu:1001 při akt. news nahlásí problém s připojením. Provedl jsem dokonce přeinstaci FW 0.9.5020 a nainstaloval pluginy a stále nic. Karta ICE 0D96. Díky.
jarsou
Re: Zápisy
Příspěvek od jarsou »
Bojuji se stejným problémem. Ne a ne na kartu ICE dostat zápisy. Je zajímavé, že po první inicializaci na zkušební dobu jela měsíc bez problému se všemi programy, ale když to skončilo
a já kartu zaregistroval, tak zápisy neprojdou. A chodit každých 14 dnů ji jinam inicializovat, je blbé. Podařilo se někomu tento problém vyřešit bez přechodu na E2 či zakoupení modulu do čtečky?
AzBox HD Premium,fw 0.9.3877,ext.HDD SG External Desktop 1TB - ext3, karta CS-Link, mgcamd+newcs+SCD, WIFI, zvuk 5.1
pauco Slovakia
Re: Zápisy
Příspěvek od pauco »
niekde som cital, ze zapisy na ICE kartu funguju v kombinacii mgcamd138+newcs170
inac bezproblemove su tieto emu: oscam, gbox, gboxnet, cccam230, scam
AZbox Elite HD
havranek
Re: Zápisy
Zdar borci válčil jsem hodně. Přečetl vše možné a nakonec se mi nějak zadařilo a funguje od listopadu
Používám FW 0.9.5020 + mgcamd v1.34d a news v1.6 z nějaké zálohy tady na foru, ale už nevím která to byla vystřídal jsem snad všechny a stále mi to nešlapalo. Pak jsem se začal zabívat proč v pluginech mám mimo OPENxCAS TechSat. Nakonec jsem přes červené tlačítko ADD plug-in a přidáním SERVER URL http://satlab.techsat.info/AZPlugins stáhl a nainstaloval TechSat_AZK2.2 a pomocí něj vždy když se mi objeví zakódováno stáhnu Download MGcam Keys a zase to jede. Doba je různá od cca týdne až po měsíc.
MultiCas mám zakázaný trvale. na portu IPboxu:1001/sub nemám nic ale jede to a je to jednoduší než zapínat MultiCas a posílat reautorizace ze skylinku což bylo potřeba někdy udělat i několikrát. Při tomto postupu to většinou zabralo pouze když jsem hned posobě na skylinku poslal reset pinu a reautorizaci naopak to nejde (20min prodleva). Přes techsat to zvládne i manželka. Kartu mám přímo v AZboxu.
Třeba to pomůže i někomu jinému. AZZdar. :106:
havranek
Re: Zápisy
jarsou píše:Bojuji se stejným problémem. Ne a ne na kartu ICE dostat zápisy. Je zajímavé, že po první inicializaci na zkušební dobu jela měsíc bez problému se všemi programy, ale když to skončilo
Hele chovalo se mi po výměně karty úplně stejně zkus přihodit pouze ten tech sat a dej sem vědět jestli jede.
hades
Re: Zápisy
Příspěvek od hades »
Zkus kartu vytáhnout a základ skylinku pojede i tak, protože jede v emu. :88:
(Nejhorší smrt je z vyděšení)
VTronik
Re: Zápisy
Příspěvek od VTronik »
pauco píše:niekde som cital, ze zapisy na ICE kartu funguju v kombinacii mgcamd138+newcs170
Fungují.
Skylink ICE
Zpět na „Dotazy začátečníků“
