SIF TeAm Enigma2 Koala Azboxhd
Diskuze E2
abdulmp
Příspěvek od abdulmp »
Skusal uz niekto tento image?
- Sifteam cloud system (You can connect your sifteam forum account on your stb, in the future release you can backup your image,share channels settings etc etc in your personal account storage)
- New Graphic skin. Thank you so much to daconi.
- Redisegned SifTeam Panel Menu
- Redesigned Software Manager.Added possibility to rank your favourite plugin, you can consult top rated,most downloaded plugin etc etc
- Added Bouquets and Channels Menu. Now you can download your favourite channel list settings.
- Exclusive possibility to use Original Sky Ita channel list numeration starting from number 100 like skybox stb
- Added OpenWebIf
- New System to detect and install Usb devices
- Many fixes to Mount Disk manager
- Added Temporary-Static Mount.
- Added uuid use on fstab
- Airplay Server coming soon
- Support for Dreambox 8000-7020hd-800se-800-500hd Vuplus-Ultimo-Duo-Uno-Solo Cteck et9000-5000 Xtrend et9200-6000 Azbox Premium/Plus Hd Azbox ME
schmegea
Re: SIF TeAm Enigma2 Koala Azboxhd
Příspěvek od schmegea »
Zkusím večer a pak dám report, sifteam se mi líbí i na dreamu tak uvidíme na jakém základu je to vybudováno pro azbox
blackie Slovakia
Příspěvek od blackie »
Hladal som nejake screens, ak vas to zaujima, nasiel som toto: http:// ....
upravil vikino lepsie by bolo keby si nejake screeny urobil a sam ich tu ukazal...
AZbox HD Elite rev.3@OpenATV 6.1, Sony KDL-32W4000, Skylink, 2xLNB Chess Ed.3@Maximum E-85(19E+23,5E)
Mirec12345
Příspěvek od Mirec12345 »
Vyzera lakavo, je to zalozene na RTi (ked tak na ktorej verzii?) tak ako RSI alebo to robia komplet samostatne?
stabilita vs. RTi ??
kedysi- predane:
AZBox Premium HD+ E2 OpenRSI-OpenPLI 2.1 na DOM Astra 23.5E CCCam 2.3.0 karta Skylink ICE 0D96 2,5'' HDD Seagate Momentus 5400.2 120GB SATA 5400rpm
gorick
Dal poděkování: 3 poděkování
Příspěvek od gorick »
Tak som to nahodil.
Instalacia prebehla ok.
Prvotne nastavenie, setting cez dreambox edit ok.
Uvita vas novy skin cerveno-cierny redheat.
Na modrom tlacitku je SIFTeam Panel, cez ktory som sa dostal ku stiahnutiu aj inych skinov
/je ich tam 38, nainstaloval som 4 z nich a vsetky isli, takze kompatibilita skinov asi ok /
Tento image ma svojske usporiadanie adresarov a poloziek v menu, treba vediet ako nanho.
/skusam nahodit oscam a configs/-ma to napr. svoj camd reader-emulator a card server...uff
Prva negativna skusenost - nemozem zapnut mediacenter- vzdy zelena smrt.
Standby nevypina hdmi - ostava seknuty obraz, na vfd svieti modra ledka...
visper
Příspěvek od visper »
Přes jaký Azup si to natáhl? Zkoušel jsem z RTI 1.6 i 1.7, natáhne to ale nejde spustit, na displeji vypisuje jakési nesmysly.
nokixxx Czech Republic
Příspěvek od nokixxx »
Jsem na tom stejne, uz jsem se dostal na uvodni obrazovku kde pise boot ale i po deseti minutach se nic nedeje. Azbox elite, azup posledni. Jdu zkouset dal. Daval jsem to na vetci doom. Na origo mam 1.6 a nechce se mi to premazavat.
Azbox elite Enigma2 Openrsi 3.0 v.21.7.2013. Oscam.
gorick
Azup som pouzil ten z RTI 1.7. Prvotne spustenie trvalo dost dlho. Skus to este restartovat cele, ked sa ti zda, ze dlho cakas...Pri tom boot to stalo dost dlho, ale urcite menej ako 10 min...mozno tak 3min.
Naposledy upravil(a) gorick dne 06 bře 2012, 16:12, celkem upraveno 1 x.
Mirec12345
nokixxx píše:Jsem na tom stejne, uz jsem se dostal na uvodni obrazovku kde pise boot ale i po deseti minutach se nic nedeje. Azbox elite, azup posledni. Jdu zkouset dal. Daval jsem to na vetci doom. Na origo mam 1.6 a nechce se mi to premazavat.
ak citam spravne tak tento image je z prvej generacie azetiek len pre premium a premium+
Support for Dreambox 8000-7020hd-800se-800-500hd Vuplus-Ultimo-Duo-Uno-Solo Cteck et9000-5000 Xtrend et9200-6000 Azbox Premium/Plus Hd Azbox ME- toť na ich stranke
kedysi- predane:
Mirec12345 píše:
uz jsem jim psal tak snad odpovi. Pak je pro me matouci "New SifTeam Koala Enigma2 Azbox Elite-Premium-Plus-Ultra-Me 05/03/2012". Ale v supportu elite opravdu nemaj.
abdulmp
A v com je Elite od prveho Premia iny?? - ma len inu krabicu, externy zdroj a na doske aj sata-radic a wi-fi - ale ostatne by malo by po HW stranke rovnake ak sa nemylim... Takze ak je tam ovladac aj pre tieto zariadenia (obsahuju ich aj ine enigmy) tak pri boxe ktory ich nema nebude len pouzity. Ci je tam aj nejaky iny rozdiel?
krokodill
Příspěvek od krokodill »
Také jsem ho vyzkoušel a to mám Elite, jen jsem si to pořádně nepřečetl. Líbil by se mi, zkusil jsem Cccam 2.3.0 a chodilo to pěkně, ale když jsem si chtěl namapovat flešku, tak první zelená smrt a s ní zmizely kanály z oblíbených. Opětovně jsem je tam naladil, něco jsem vyzkoušel, opět zelená smrt se smáznutým setingem, takže návrat na RTi_Core_1.7.0
jejich odpoved "sorry for the issue......tonight i hope we'll release a fix for that. Thank you so much and have a nice day"
Tak v azup nechat zaskrtnuto "only kernel" po te co jsem so zaskrtnul vse nabehlo. :55:
gorick
nokixxx píše:jejich odpoved "sorry for the issue......tonight i hope we'll release a fix for that. Thank you so much and have a nice day"
Tato ich odpoved bola urcena myslim pre AZBox Me...Lebo pre AZMe ten ich image nejde vobec. A ja som to donho ladoval, premazal som si vsetky 3 particie /images/. Po recovery som sa dostal max. na 31 percent. Joj a teraz vsetko nanovo :cry:
A este v AZHD ide vam Mediacenter? U mna vzdy zelena.
Zpět na „AZ HD Diskuze E2“
