RTi core RC12 Enigma 2
Re: RTi core RC12 Enigma 2
Posted by hfmls:
Enigma2 new version is coming for elite/premium etc in next few days...
mediaplayer ok, card reader and fixes.
Tož uvidime...
Tož uvidime...
- Blackfire
No po úspešnej čítačke bude nad čím rozmýšľať. Inak momentálne mi original FW funguje celkom OKcamaar píše:Posted by hfmls:
Tož uvidime...
AZBOX Premium, LNB Inverto Black ULtra, SG2100, Gital, WI-FI, Interny HDD wd 2.5" scorpio blue 500gb, plazma Samsung PS50, pes
- Yano
Dalsie info od RTi (CR=Card Reader)
just to inform you that we got CR working so it will be included in next version
[ 2276.861000] sci: SMP8xxx driver loaded (rd_buffer_size = 256, wr_buffer_size = 256, freq = 3571200, interfaces = 1)
[ 2276.898000] sci0: card state change 0->1
[ 2276.902000] sci0: scard present detected.
[ 2276.906000] sci0: enabled smartcard interface.
[ 2280.936000] scard_open :: scard_priv[minor=0].b_mode = 0
...atd...
...atd...
babo12
Tak vcera som nahodil E2 R12 ale na 0.8W: NGC HD, NG WILD HD - tma, ESPN HD ide ako sa mu zachce
23.5E: CT HD - vcerajsi futbal sa mi zdal akoby trhalo obraz. Problem len u mna ? Alebo je to problem s image?
DM Two UHD - Opendreambox2.6, DM 800HDseV2 - OpenATV 6.3, VU+ zero4k - VTI 15
Take jsem vcera testoval na AZboxu HD Elite Enigmu2 (RC12), prechod z original FW (0.9.5306) na RC4 a na RC12 v poradku. Do boxu jsem naistaloval Tunisiasat Addons manageru 3.0, Gp-cam-cccam, Newmenu a Keymap.
Mam doma pouze CRT TV, pri testovani mel box problem uchovat nastaveni scartu na RGB (po kazdem restartu bylo opet nastaveno CVBS, nastaveni vzdy ulozeno) ostatni z A/V casti zustalo nastaveno. Obcas se po prepnuti programu nebo po skenovani druzice objevila hlaska o kontrole nastaveni tuneru a pro dalsi sledovani vysilani pomohl jen restart.
Obraz na 23,5 u SD i HD v poradku bez trhani, navrat na original FW bez problemu.
monkus
ja som sa vratil na oficialny fw z rc12, mali by ste vidiet moju zenu, aka je zrazu spokojna :-)
Ta moje je asi z jiné planety - když jsem se chtěl vrátit na ofiko, tak ani náhodou. Mám PB-Beta-3.1-AZBOX HD a je fakt, že na Full HD a s aparaturou nejde obraz ani zvuk s origo srovnat / a sdílení na cccamu taky ne/. Už aby chodila karta a korektně nahrávání.monkus píše:ja som sa vratil na oficialny fw z rc12, mali by ste vidiet moju zenu, aka je zrazu spokojna :-)
- visper
Ta moje je asi z jiné planety... Dědečku a máš mladou ženu nebo babičku? Ptám se proto jestli, mám tu moji začít taky nějak cvičit :)
Mám babičku /62 let/, ale živou a moderní - E2 jí vyhovuje: líbí se jí obraz/je živější než origo/, předělal jsem setting / v oblíbených mám dělení 28E, 23,5E CZ+SK, 19E D, 19E A, 13E SF,
9E, 0,8W CZ+SK/ - dobře se jí v tom hledá a hlavně jsem ji utáhnul na plugin CSFD - to je informací o filmu!
vikino
Tak to je super moderná babička, ku ktorej Ti mozem len pogratulovat...
Prajem Vam, nech Vam tu Eňu pre AZHD coskoro dotvoria k pouzivania hodnemu stavu...
- visper
Tak moje babička je jen o trošku mladší, ale když jsem jí to přečetl, tak mi vrazila do ruky smeták a že se jde učit tu Enigmu.
Dědečku, já ti všechno věřím kromě toho obrazu, origo soft má různé mouchy, ale obraz má technicky dokonalý, tam se nic vylepšit nedá.
Nejde o technickou úroveň - subjektivně pocit trochu jiného podání barev - E2 je "šťavnatější".
Hlavně aby pokračoval vývoj. Dreambox se už začíná soudit a VU má zákaz používání E2.
Marusys(výrobce VU+) má problém, protože používal E2 jako oficiální firmware ve svých přijímačích bez povolení od Dream multimedia. Doufejme, že to tady hrozit nebude.
- dempsey
frcko73
- Mazák
si ma predbehol.....
