RTi core RC11 Enigma 2
Re: RTi core RC11 Enigma 2
Áno, to viem, tam som to i zapísal, ale ako píšem, v "/dev" vôbec nie je také zariadenie (súbor) "/dev/sda1", "/dev/sda2"
... takže neviem čo na-mount-ovať do /media/hdd a /media/usb
AZBox Elite HD + IPBox 200S / Toroidal 90 (1W+13E+19,2E+23.5E) / Multiswitch EMP 17/12 / LG 50PK550
Otvor si adresar etc v ktorom je subor fstab v nom su riadky /dev/hdb1/media/hdd auto defaults 0 0mkris píše:Áno, to viem, tam som to i zapísal, ale ako píšem, v "/dev" vôbec nie je také zariadenie (súbor) "/dev/sda1", "/dev/sda2"
a /dev/sda1 /media/usb auto defaults 0 0
Pokud neexistuji soubory /dev/sda, /dev/sda1 atd. pripadne sdb, tak mas problem s pripojenim usb disku.mkris píše:Áno, to viem, tam som to i zapísal, ale ako píšem, v "/dev" vôbec nie je také zariadenie (súbor) "/dev/sda1", "/dev/sda2"
Azbox jej proste nevidi. Soubory se totiz vytvori az po pripojeni a detekci usb disku.
Pripoj disk a zkus prikaz dmesg a uvidis co se deje. Mel bys tam videt detekci vcetne jeho typu atd.
root@AZBox:~# dmesg |grep usb
[14887.573000] usb 1-1: uevent
[14915.770000] usb 1-1: new high speed USB device using ehci_hcd and address 3
[14915.913000] usb 1-1: default language 0x0409
[14915.919000] usb 1-1: New USB device found, idVendor=1058, idProduct=1100
[14915.926000] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[14915.933000] usb 1-1: Product: My Book
[14915.938000] usb 1-1: Manufacturer: Western Digital
[14915.943000] usb 1-1: SerialNumber: 57442D574341553436333734373830
[14915.951000] usb 1-1: uevent
[14915.980000] usb 1-1: usb_probe_device
[14915.984000] usb 1-1: configuration #1 chosen from 1 choice
[14915.994000] usb 1-1: adding 1-1:1.0 (config #1, interface 0)
[14916.001000] usb 1-1:1.0: uevent
[14916.017000] usb-storage 1-1:1.0: usb_probe_interface
[14916.022000] usb-storage 1-1:1.0: usb_probe_interface - got id
[14916.054000] usb-storage: device found at 3
[14916.058000] usb-storage: waiting for device to settle before scanning
[14916.074000] drivers/usb/core/inode.c: creating file '003'
[14917.281000] usb-storage: device scan complete
root@AZBox:~# cat /etc/fstab |grep sda
root@AZBox:~# mount /media/usb/
root@AZBox:~# mount|grep sda
/dev/sda1 on /media/usb type ext3 (rw,errors=continue,data=ordered)
root@AZBox:~# dmesg |grep -i ext3
[15397.692000] EXT3 FS on sda1, internal journal
[15397.697000] EXT3-fs: mounted filesystem with ordered data mode.
... Vďaka, po zadaní uvedených príkazov bol záver nasledovný:
root@AZBox:~# mount |grep sda
/dev/sda1 on /media/hdd type ext3 (rw,errors=continue,data=ordered)
[ 735.965000] EXT3-fs: INFO: recovery required on readonly filesystem.
[ 735.972000] EXT3-fs: write access will be enabled during recovery.
[ 736.012000] EXT3-fs: recovery complete.
[ 736.017000] EXT3-fs: mounted filesystem with ordered data mode.
root@AZBox:~#
ale po následnom reštarte (počkal som asi 5 min. pre istotu) sa disk automaticky na-mount-oval do /media/hdd.
S tým diskom sa však muselo niečo stať, lebo som na ňom mal nakopírované nejaké videá a obrázky aj nejaké testovacie
nahrávky z RC9 a všetko to zmizlo.
I tak moc ĎAKUJEM za radu.
root@AZBox:~#
frcko73
- Mazák
zistil som,ze mi nejde PrimaHD......
,dalej nefunguje Rescue Mode,vzdy mi to hodi Restart boxu.....
potvrzuji .. rescue mode nejdefrcko73 píše:zistil som,ze mi nejde PrimaHD......,dalej nefunguje Rescue Mode,vzdy mi to hodi Restart boxu.....
- Stevo102
No tak to som zvedavi ako tampotom dame novu RC12 ked nejde rescue mode
Jednak to muzou opravit pres online update a nebo si lze pomoci tim, ze hodis patch.bin RC4 na flashku a pri bootu by to melo nabehnout do rescue (to jsem ale nezkousel)Stevo102 píše:No tak to som zvedavi ako tampotom dame novu RC12 ked nejde rescue mode
Funguje to - vyzkoušeno. Vracím se takto i do origo softu.
frcko73
- Mazák
ak das na flasku akykolvek fw,strcis do boxu,vzdy to skoci do rescue mode.
- Stevo102
Aha, tak to ma nenapadlo. Akurát som skúšal nastavenia HDMI, a funguje to správne len s nastavením 720p/50Hz. Nech nastavím čokolvek inak, tak po chvílke buď vyhodí error tuner alebo dáky PID error, a ani po prebudení zo standby nenabehne obraz. Takže jediná možnosť je nastaviť 720p/50Hz...
Tak tento problem ja nemam. A jelikoz to nikdo nehlasil jako bug, tak bych rekl, ze to je jen u tebe
frcko73
- Mazák
chlapy,to ozaj musite zbytocne citovat posledne prispevky? Potom je to neprehladne. Ved kazdeho napadne,ze odpovedate na posledny prispevok.
mam podobny problem.. akurat som neskusal menit rozlisenie.. mam 1080i.. cas od casu mi napise aby som skontroloval tuner a jedina moznost je reboot.. signal vidim ale obraz ziadny.. vacsinou to robi ked viac krat prepinam.. inak tento problem mam od RC8
- Stevo102
Ano presne toto sa mi stava, keď je tam ine nastavenie ako 720p/50 tak to vyhadzuje, inak nemusíš rebootovať, stačí ísť do nastavení A/V settings a zmeniť to na niečo iné a ono sa to rozbehne. Ale po nejakom čase ti to znova vyhodí, takže najjednoduchšie je dať tak ako som napísal a vyhneš sa týmto hláškam.
