azbox server skystar2 client
Potreboval bych poradit jak rozbehnout sdileni mezi azboxem a skytar 2.
v azboxu (s nainstalovanou enigmou rc4) mam v interni ctecce starou tt kartu. V pristroji mam nainstalovan oscam.
Vsechny programy povolene kartou mi v azboxu bezi.
Do skystaru jsem si nasel klienta flycccam. Ten plugin ma jen 2 soubory, jeden je konfiguracni (cfg) a druhy je knihovna.
dle navodu co je uvnitr toho konfiguracniho souboru (viz nize)
#add your cccam account here
C: host port user pass
#for example
#C: www.dmtvro.cn 5678 AAAAAAAA BBBBBBBB
pocitam ze by to nastaveni u me mohlo vypadat nejak takto.
C: 192.168.1.111 25000 root azbox
Pokud to nastaveni mam spravne, potreboval bych uz jen poradit jak nastavit ten oscam v azboxu s enigmou.
#for example
Re: azbox server skystar2 client
toho clienta co mas nepoznam. Ja pouzivam na skystar 2 aCamd. Ten si tu mozes stiahnut v downloade pre AzboxHD bez enigmy.
nastavenie potom pre cccamd - konfiguruje sa subor cardclient.conf je tam aj vzor
# Comment lines can start with # or ;
# every client line starts with the client name, followed by some arguments:
# 'config' (optional) is number between 1-999 to combine with filtering
# 'hostname' is the name of the server
# 'port' is the port on the server
# 'emm' is a flag to allow EMM transfers to the server
# (0=disabled 1=enabled)
# 'caid' (optional) caid on which this client should work
# 'mask' (optional) mask for caid e.g. caid=1700 mask=FF00 would allow
# anything between 1700 & 17FF.
# Default is no filter 0000 & 0000. If only caid is given mask is FFFF.
# You may give multiple caid/mask values comma separated
# (e.g. 1702,1722,0d0c/ff00).
# 'username' is the login username
# 'password' is the login password
# cccamn client
# 'softcam' (0=disabled 1=enabled) default 1=enabled
# 'maxhops' (0-999) default 5 hops
#cccamn:192.168.7.54
0/0000/0000:username:password
0/0000/0000:username:password:0:Disable soft
0/0000/0000:username:password:0:2:Disable soft and max 3 hops
# cccamn client
Tak jsem to ted zkusil podle "fyzika" a jede to :-)
Na azboxu pouzivam uz dlouho kombinaci mgcamd/newcs s kartou skylink nastavene podle nejakeho navodu tady z fora. Ted jsem na PC oprasil svuj DVBdream 1.4g a doinstaloval plugin Acamd 0.6.1.8, upravil jsem jen Cardclient.conf pridanim radku:
newcamd:tvojeip
1/0000/0000:test1:test1:0102030405060708091011121314
a hotovo. Ma to jen nepodstatnou chybu, kdyz vypnu dvbdream a zase zapnu tak program nenajede ale po prepnuti na jiny se to zas chytne a jede vse.
newcamd:tvojeip
AZBOX HD Premium, Skylink, fw RTi Core v1.2 Enigma 2
nejsem si zcela jist a proto se optam, funguje tohle i na enigme? Nehodam se vracet na zakladni fw. Enigma sice ma svoje mouchy, ale i tak je to o parnik lepsi.
Zkousel jsem jenom na oficialnim fw 0.9.4890 takze na Enigmu fakt nevim.
to je jedno, ty sa pripajas so Skystar kartou na card server newcamd alebo ccamd protokol a jej je jedno ci ten server bezi na enigme alebo na hocicom a na hociaky box. to je kompatibilne. Staci takto?
Inak s tym acamd klientom sa pripojis na newcamd server, cccamd, radegast alebo co ja viem co este vsetko.
je mi celkem jedno co pouziju za klienta. To co tu navrhujete vypada podobne jako flycccam nebo hadu. Ted potrebuji jen dohledat kde najdu navod na nastaveni oscamu.
- schmegea
- Mazák
třeba zde :higlander píše:je mi celkem jedno co pouziju za klienta. To co tu navrhujete vypada podobne jako flycccam nebo hadu. Ted potrebuji jen dohledat kde najdu navod na nastaveni oscamu.
http://streamboard.gmc.to/wiki/index.php/OSCam/en
- schmegea
- Mazák
včera byl výpadek, dnes už jede.
Aj mna by zaujimalo ako nastavit predtym som mal mgcamd+newcs + wincsc newcamd 5.25 a slapalo to vyborne s orig.firmware a teraz mam nahodenu enigmu rc4 len neviem co nastavit a kde v ktorych polozkach enigma ma trocha inac, bud nejaky config dopisat do oscam alebo inym sposobom neskusal som niet tolko casu.Nema niekto overenu konfiguraciu...
