E2 na azbox HD
- asconn
Re: E2 na azbox HD
Dle informací na satpimps.com by měl být nový testovací image uvolněn dnes nebo zítra.
Technotrend S2-3600 HD USB + Asus K52JC, AZBOX Elite HD (E2-OpenRSI-OpenPLI 3.0), Illusion M3-Kyng, Dreambox DM800HD, SkyLink ICE, SG 2100 USALS, Samsung LE40A559 Full HD, Samsung LE37C550
- cvoky007
Re: E2 na azbox HD
http://rapidshare.com/files/426062706/E ... 1.0.25.rar
http://www.megaupload.com/?d=H7FQQA4C
What is new ?
- FTA SD and HD channels working. ( DD 2.0 , AC3 working by HDMI tested on Einsfestival HD )
- New IR driver ( few more mapped buttons e.g Info button, Audio selection is Check button on RCU )
- Fixed Section filters and PID selection.
- Added part of CA system
- Multimedia support for MPEG2 , MPEG4 ( XviD ), h264, and various audio support.
- Please read ReadMe file if You want also to install additional things to get working Multimedia by Media Player in E2.
- If You have Full HD TV , You can set resolution by editing bootup file located in :
/etc/init.d
Find line :
# Elite and Premium
below You will see line insmode ...
and replace existing insmode line with this one :
insmod /lib/modules/2.6.22.19-19-the_ripper/extra/em8634dvb.ko options="-analog -f PAL_BG -digital -f HDMI_1080p50 -hdmi_chip SiI9030 0 14 15 100 0"
Few tips :
Before loading Enigma 2 , move Your dish to some satellite ( Astra 19.2 e is good because of FTA HD channels ), as on E2 currently we didnt fix DiseQc bug ( We will fix it when we finish Premium+ driver ).
Try to use Simple configuration in Tuner Configuration, e.g choose satellite on which position currently You are.
README for MULTIMEDIA :
First download 2 .so filles attached to this post and put them in :
/usr/lib/gstreamer-0.10 directory, and after that follow procedure below :
If You want also to test Multimedia on AzBox Enigma 2 media player , You have to install 3 IPK files located in this archive :
gst-plugin-asf_0.10.16-r0.0_mipsel.ipk
gst-plugin-avi_0.10.25-r0.0_mipsel.ipk
gst-plugin-dvbmediasink-dbg_0.10+cvs20101006-r0_dm800.ipk
working formats:
audio: mpeg, aac, ac3, dts, wma (but not pro), pcm (not all ?)
video: mpeg2, mpeg4 (xvid), h264 (only show singe frames)
IPK Installation procedure :
Transfer 3 *.ilk files to /tmp folder of Your AzBox and run this commands, one by one :
ipkg install /tmp/gst-plugin-asf_0.10.16-r0.0_mipsel.ipk
ipkg install /tmp/gst-plugin-avi_0.10.25-r0.0_mipsel.ipk
ipkg install /tmp/gst-plugin-dvbmediasink-dbg_0.10+cvs20101006-r0_dm800.ipk
If You cant use ipkg install, use command opkg install or ipkg-extract .
http://www.satpimps.com/showthread.php?t=135894&page=64
What is new ?
/etc/init.d
Find line :
# Elite and Premium
Few tips :
working formats:
DM7020 (geminy 4.70)
OPTIBOX500S (geminy 4.20)
Astra 23.5/Thor 0.8
Astra 23.5/Thor 0.8
- St.
Re: E2 na azbox HD
mas uz nekdo prvni poznatky ? ;o)
St.
St.
DPD Panasonic 42PZ80E, AzBox Premium, 2.5" hdd Toshiba, Enigma2, CCcam, Skylink
- cvoky007
Re: E2 na azbox HD
cakam na redukciu ATA-CF :)
ale zatial funguju len FTA
potom chcu rozbehat CI slot, interna citacka zatial nie je pre nich priorita
Astra 23.5/Thor 0.8
Astra 23.5/Thor 0.8
Babangida
Re: E2 na azbox HD
St. píše:mas uz nekdo prvni poznatky ? ;o)
St.
Vcera vecer jsem to v rychlosti zkousel
Instalace s AzUP na 2x bez problemu
Kanaly jsem tam hodil pres DreamboxEdit a FTA na 23.5 slapaly bez problemu
MediaPlayer jsem vsak nerozchodil - pri instalaci IPK souboru to vzdy dopadlo s chybou
Dreamer
Re: E2 na azbox HD
Ahoj,
mám problém - podařilo se mi v pohodě nahrát E2, ale nemůžu se vrátit zpět na původní firmware.
Postup: nahraju na USB patch.bin (zkoušel jsem několik verzí vč. 0.9.5020), zapnu box, dostanu IP adresu, připojím se pomoci AZUp na tuto IP, spustí se vytváření cramfs a asi v 50% chyba, napíše mi, že je to "unsupported FW version" a skončí. Zkoušel jsem několik verzí patch.bin a se stejným výsledkem. Přitom když na USB nahraju E2 a spustím instalaci pomocí AZUp, tak instalace proběhne OK. Dělám něco špatně?
Díky za každou radu.
- gorick
- Mazák
Re: E2 na azbox HD
Podobny problem som riesil. Mne tu chybu s hlaskou " unsupported FW version" davalo este pri prvej instalacii E2. Babral som sa s tym asi 2 hodiny.Stale dokola to iste aj po zmene roznych FW.Uz som bol fakt zufaly,az ma napadla genialna vec ,, vymena USB za iny typ,, Potom to prebehlo v pohode v Azupe do 100%Dreamer píše:Ahoj,
vikino
Re: E2 na azbox HD
Urob presne taky isty postup ako si robil, len s tym rozdielom, ze USB flasku zasun do zadneho USB vstupu na AZHD Premium.Dreamer píše:Ahoj,
- hitman222
Re: E2 na azbox HD
Dream800 HDse_OpenPli
Vu+Solo2_OpenPli
Cloud-ibox3_OpenPli
Dreambox 7020,Dreambox 500
Samsung UE46ES8000
motor SG2100(SKY Link)
Vu+Solo2_OpenPli
Cloud-ibox3_OpenPli
Samsung UE46ES8000
Dreamer
Re: E2 na azbox HD
Díky mocgorick píše:Podobny problem som riesil. Mne tu chybu s hlaskou " unsupported FW version" davalo este pri prvej instalacii E2. Babral som sa s tym asi 2 hodiny.Stale dokola to iste aj po zmene roznych FW.Uz som bol fakt zufaly,az ma napadla genialna vec ,, vymena USB za iny typ,, Potom to prebehlo v pohode v Azupe do 100%Dreamer píše:Ahoj,
Neuvěřitelné, leč účinné ... s jinou flashkou bez problémů. Nechápu, ale funguje to OK
Dreamer
Re: E2 na azbox HD
Díky za tip, ale já mám ELITEvikino píše:Urob presne taky isty postup ako si robil, len s tym rozdielom, ze USB flasku zasun do zadneho USB vstupu na AZHD Premium.Dreamer píše:Ahoj,
- cvoky007
Re: E2 na azbox HD
stiahni si z http://hotfile.com/dl/77577121/b781f20/ ... S.zip.html alebo http://www.multiupload.com/HQS9KOD62X (fw + pluginy ccam a mgcamd + e2 skiny)Dreamer píše:Ahoj,
rozbal a z adresara \E2 AZBOX The_Ripper 1.0.25 Latest\addons skopiruj subory (libgstdvbaudiosink.so, libgstdvbvideosink.so)
do /usr/lib/gstreamer-0.10
Astra 23.5/Thor 0.8
Astra 23.5/Thor 0.8
- jaris85
Re: E2 na azbox HD
zdarec
tak jsem zkousel nainstalovat enigmu a bohužel se to nějak nepovedlo. postupoval jsem podle navodu a při restartu mi to na displeji napsalo "RESCUE MODE?" a na TV mam bez signalu. když vytahnu flashku a provedu reboot tak mi to piše "geeko
" a na televizi opět bez signalu. nevim co stim!!!???prosim o pomoc... předem diky jsem v tom začatečnik
AzBox Premium HD + wd 3.5" scorpio blue 500GB + karta Skylink, TV LED LG 55LE5500 139cm, reciever Samsung HW-C700, repro Yamaha NS 555B,444B,333B
- 0ctopus
Re: E2 na azbox HD
Uz mesiace nekomentujem dianie tu na fore, teraz urobim vynimku, kedze nikto ti nepise.jaris85 píše:zdarec
když vytahnu flashku a provedu reboot tak mi to piše "geeko" a na televizi opět bez signalu. nevim co stim!!!???prosim o pomoc...
Na nakopnutie tu mas link: http://www.satpimps.com/showthread.php?t=139627
Daj ostatnym vediet, ako si dopadol.
0ctopus
dm 500, dm 7000, dm 7025, ...
- jaris85
Re: E2 na azbox HD
tak jsem to rozchodil.
dal jsem tam flashku s patch.bin (enigma)
zapojil jsem internetovy kabel RJ45 (ja ho měl totiž normalně připojen přes wifi)
spustil jsem AZUp
restartoval box
načetlo mi to ip adresu tu jsem zadal do AZUp
přeinstalovala se enigma a už to šlape
spustil jsem AZUp
restartoval box
