MultiCAS_Edit
Užitečné programy
MultiCAS_Edit
MultiCAS_Edit v1.0
Small tool to manage your cccam and multicas data.
After succesfull installation, use the options tab to edit settings
Verzia pre ftp prenos z PC do boxu .
autor: Telesat.
Ima
Re: MultiCAS_Edit v1.0
Příspěvek od Ima »
MultiCAS_Edit v1.1
Fix:
Bug when load wrong Key.bin file - program crash
-Arreglado bug problema al cargar Key bin file. El programa se cerraba
Add:
- now, you can edit splitter data
- if file : splitterdata.bin , will be created
Ahora se puede editar datos
Creado file splitterdata.bin
AzHD Elite fw 0.9.2371 : Emu mgcamd+newcs,MultiCAS : Motor SG2100 : LCD Sony KDL32W4000 Full HD
005jon Slovakia
Re: MultiCASEdit v1.2
Příspěvek od 005jon »
MultiCASEdit v1.2
- CCcam Status , get info of server status(on/off) and ecm info
- Edit Serever lines - now simply , you can add C: line
- Auto update of changes
dempsey
Re: MultiCAS_Edit v.1.4
Příspěvek od dempsey »
MultiCASEdit
v.1.4
Fix:
- Uphops set in C: line
Add:
- Display Card List Info
thx to telesat
dempsey
Re: MultiCAS_Edit
MultiCASEdit
v.1.5
Add:
- NewCamd & CR ( in Spliter & CCcam TAB )
Zpět na „Utility AzBox HD“
