Monkus OpenXCAS Tools 1.0:
- AzBox HD Backup v0.9
- AzBox HD USB Mount Script v2.0
- AzBox HD USB Background Copy Script v1.1
Installation:
- OpenXCAS must be installed previously
- copy monkus_tools_1.0.tar to /EMU/OpenXCAS directory
- tar xvf monkus_tools_1.0.tar
- rm monkus_tools_1.0.tar
How to use:
- NEXT Button on Remote Controller, select Tool, press OK button
- HOME, PLUGINS, OpenXCAS, Activation & Priority Setting
# AzBox HD Backup v0.9 for OpenXCAS
# - new code :-)
# - channel list
# - browser and rss settings
# - users and password
# - plugins and addons lists
# - some system settings
# - samba configuration, users and passwords
# - ssh keys and configuration
# - main backup list (/EMU/OpenXCAS/backup/backup.list)
# - custom list of files and directories (/EMU/OpenXCAS/backup/custom.list)
# - EMU directory
# - boot logo
# - restore script after factory reset
# NEED TO CHANGE !!! (if you`re using usb device)
BACKUPDIR=/DATA/hdb1/backup
Restore:
- connect to your azbox hd via telnet / ssh
- cd $BACKUPDIR (f.e. /DATA/hdb1/backup)
- ./restore.sh
- automated reboot (without prompt!)
Enjoy your restored data with new firmware :-)
# AzBox HD USB Background Copy Script v1.1 for OpenXCAS
# v1.1
# - need to have data on usb device in directory "123456"
# - all mounted usb devices will be scanned for this directory
# - data (files, directories) will be copied to $TARGET
# - default $TARGET is internal disk (az hd premium), directory "download"
# - start copying from plugin / openxcas / usbcopy or by remote controler
# - data is copying on background, possible to watch tv or browsing f.e.
# - or switch azbox to standby mode
# - red led active during copying
# - check blinking red led on azbox for finnished job
# - stupid prevent from duplicate copying
# bugs
# - working only with 1 usb device with $SOURCEDIR
# - if copying and recording go parallel, red led will be off after copying
# best practice $SOURCEDIR is 123456 (all fs compatibility - fat supports only 8 characters, not case sensitive)
# AzBox HD USB Mount Script v2.0 for OpenXCAS
# v2.0
# - new code (using stb default usb mount tool)
# - front and rear usb port support
# - default stb fs support (ext3, ext2, fat32 and read-only ntfs)
# - solved problem with some usb devices formated by windows
# - usb devices must have correct partition table
USB button on remote controller will unmount all usb devices from azbox hd, to mount it back without PC use this script.
PS: este mozno jedna prosba na testerov, skuste to otestovat :-)
monkus openxcas tools for azbox hd
monkus
Naposledy upravil(a) monkus dne 31 srp 2009, 07:03, celkem upraveno 1 x.
monkus
Re: monkus openxcas tools for azbox hd
Monkus OpenXCAS Tools 1.1:
- AzBox HD Backup v0.91 (NEW)
# AzBox HD Backup v0.91 for OpenXCAS
# 0.91 (ChangeLog)
# - DVB-C and DVB-T support
# 0.91 (ChangeLog)
monkus
diskusie:
- backup http://www.forum.satdigitalne.cz/viewto ... =76&t=3672
- usbcopy http://www.forum.satdigitalne.cz/viewto ... =76&t=3699
monkus
Monkus OpenXCAS Tools 1.2:
- AzBox HD Backup v0.92 (NEW)
- AzBox HD USB Mount Script v2.1 (NEW)
- AzBox HD USB Background Copy Script v1.2 (NEW)
ChangeLog (From 1.1):
# AzBox HD Backup v0.92:
# - prevent plugin starting after reboot
# - active red led during backup
# AzBox HD USB Mount Script v2.1
# AzBox HD USB Background Copy Script v1.2
# - new code :-)
# - fixed small bug with red led
# - new code :-)
monkus
Monkus OpenXCAS Tools 1.3:
- AzBox HD Backup v0.93 (UPDATE)
- AzBox HD USB Mount Script v2.2 (UPDATE)
- AzBox HD USB Background Copy Script v1.3 (UPDATE)
- AzBox HD SwapOn v1.0 (NEW)
ChangeLog (From 1.2):
# AzBox HD Backup v0.93:
# - backup.list change (from /EMU to only /EMU/OpenXCAS[2]) cause archive size
# - writing all buffered filesystem blocks to disk before reboot
# - some warnings in restore.sh script
# - possible to choose archive to restore (./restore.sh /path/to/archive.tar)
# - compatibility with azbox webinterface (by koivo, joseba)
# AzBox HD USB Mount Script v2.2
# - small probe hack to mount some usb devices with isofs (secondary root)
# AzBox HD USB Background Copy Script v1.3
# - check, if usb device exists
# AzBox HD SwapOn v1.0
# - new plugin to add more total memory using swap
# - possible to choose swap device (usb device or internal hard disk)
# - possible to choose swap size (100MB is fine)
monkus
Monkus OpenXCAS Tools 1.4:
- AzBox HD USB Background Copy Script v1.4 (UPDATE)
ChangeLog (From 1.3):
# AzBox HD USB Background Copy Script v1.4
# - fixed bug during copying data from usb2 to usb1 device
Looking for stable SKY DE/IT HD Channels N Lines for testing purposes (small traffic). Thanx in advance.
monkus
Monkus OpenXCAS Tools 1.5:
- AzBox HD Backup v0.94 (UPDATE)
- AzBox HD USB Mount Script v2.3 (UPDATE)
- AzBox HD USB Background Copy Script v1.5 (UPDATE)
- AzBox HD SwapOn v1.1 (UPDATE)
ChangeLog (From 1.4):
# AzBox HD Backup v0.94
# - added iptv channels backup
# - fixed directory structure change EMU -> PLUGINS (0.9.3378 and higher)
# - if backup from old directory sctructure will be restoted to new one,
# just run command "ln -s /PLUGINS /EMU" before running restore.sh script
# - added plugin description:
# utility to backup and restore all important azbox hd settings. sure, i have only
# restricted configuration, just report your settings (configuration files) and bugs
# to my email. this plugin is usefully in case of firmware upgrading with format
# application area f.e.
# AzBox HD USB Mount Script v2.3
# some types of usb sticks (f.e. my sandisk cruzer) have problems with azbox automount script.
# this plugin will probe usb device before running default usb_script.sh. with this plugin,
# you can mount usb devices using remote controller, no need to connect to you computer via
# telnet/ssh and do that manually. remote controller contains button "usb" for unmountig, but
# missing button for usb mounting.
# AzBox HD USB Background Copy Script v1.5
# if you want to copy data f.e. from usb stick to internal or external disk without using your computer, you
# can run copying from this plugin with remote controller. during this operation, it is possible to watch
# tv, browsing or go to standby. it is recommended to use swapon plugin (part of monkus openxcas tools)
# before using usb background copy script. don't forget to setup variables SOURCEDIR, TARGETDIR and TARGETDISK.
# AzBox HD SwapOn v1.1
# during some operations (f.e. large files copying), your azbox goes out
# of memory and process will be killed. using this plugin, you can prevent
# from it. use command "free" to display information about free and used
# memory on the system. disable row at the end, if you can use swap permanently.
monkus
Monkus OpenXCAS Tools 1.6:
- AzBox HD Backup v0.95 (UPDATE)
- AzBox HD SwapOn v1.2 (UPDATE)
ChangeLog (From 1.5):
# AzBox HD SwapOn v1.2
# - permanent swap (ln -s /PLUGINS/OpenXCAS/swapon/swapon.sh /DISK2/etc/start.d/S2swap)
# AzBox HD Backup v0.95
# - added standby and wakeup scripts
# - added network services
# - added default font settings
# - added default custom startup script
# - new archive naming convention (firmware_timestamp.tar)
