fw 0.9.1759
dempsey
fw 0.9.1759
Příspěvek od dempsey »
0.9.1759
Release Notes
Fixed
- Support some high-bitrate contents
- Bugs on playing WMV with WMAPRO
- WMV file in media player cause box hang up, and need reboot
- Size of subtitles not saved
- |<< and ****| should change song
- TXT subtitles that don¡¯t work (mpl2 and tmplayer)
- << and **** not working, it should be more intuitive, One press should
make advance just few seconds, if keep pressing button more faster
- RSS don't work at some link:
ht_p://servis.idnes.cz/rss.asp?c=zpravodaj
ht_p://serwisy.gazeta.pl/rss/0,0.html <-- Not RSS site
ht_p://rss.gazeta.pl/pub/rss/gazetawyborcza_swiat.xml
ht_p://rss.gazeta.pl/pub/rss/gazetawyborcza_nauka.xml
ht_p://rss.gazeta.pl/pub/rss/gazetawyborcza_kraj.xml
- Input of password for WEP is extended to 256 digit
- Example, i make scan at One TP that don0t exist on table (let's say
Hellas Sat 10956 V) i scan it, appear message Save channels i plug
YES, than he returns back to menu of scan i make exit, and i scan
another TP, scan is OK or failed, and i go back to TV Mode to watch
channels that i scan on first, but when i p*ick they i got "NO SIGNAL"
message, like if TP infos (S/R, FEC, PID's... are lost on STB).
- User should add new frequency on EDIT menu
- SR and transponder mHZ should have only 5 input fields and not 6
- When Go to TV Channel Menu, and press some Scan option, go first to
satellite that are used at moment. Now all times goes to 4.0E channels,
so if i have dish at Hispsat Dish starting moving uneseraly
Pridané
- Slovenské a Francúzke OSD
- User can capture the snapshot of TV using the "CHECK" key on REMOTE
- WPA-PSK and WPA2-PSK on Wireless LAN
- drivers(usbserial.ko & ftdi_sio.ko) for Infinity USB smart
- User defined shell which not be overwritten after upgrading firmware
- You can find the sample shell script in /DISK2/etc/start.d/
- At satellite list be possible sort by Position (0¨¬E to 260¨£E) and by Satellite name0.9.1759
http://ngboxcom.dyndns.tv/ftp/az_develo ... /patch.bin
dempsey
Re: Firmware 0.9.1759
Slovenské OSD nie je kompletné - po jeho vytvorení boli pridané ďaľšie funkcie / české detto /
Pridaná možnosť "Snapshot" - snímku obrazovky - funguje cez tlačítko Check - viď obrázok
robinek
Příspěvek od robinek »
Změnili opět strukturu channel listu ? Dík
dempsey
Setting z 0.9.1621 funguje
Ako najzaujimavejsia funkcia je pridanie ovladacov pre externu citacku na USB "
" . Tak sa hned pozrieme ako spolahlivo to funguje. Podpora bude asi len pre newcs ,ale funkcia je to viac ako fajna :D
Aj v tomto fw plati, to co v predchadzajucich. Na plne vyuzitie vsetkych zmien je potrebne zvolit vyrobne nastavenia, odinstalovat stary OpenXCAS a nainstalovat ho znovu. Najlepsie cez DO a ponuku Home 3 - add .
Je potrebne zalohovat si nastavenia - naladene programy a konfiguraciu citacky .
Nahravanie je uz opravene. Nahra a prehra uz aj HD programy. Nevyhodou je, ze record demon si rezervuje pre seba OpenXCAS - takze pre klasicke sledovanie kodovanych programov, je potrebne opat spustit emulator . Tyka sa samozrejme len nahravania kodovanych programov.
A DVD ISO - opat funkcne.
dempsey
Príjemné je tiež používanie info tlačítka na EPG. Po otvorení rozšíreného EPG už netreba stlačiť exit do obrazu. Po znovustlačení info sa vráti základný infobar, ktorý po pár sekundách zmizne. Najlepšie by bolo ak by po tom znovustlačení zmizlo všetko z obrazovky :31:
ltrejbal
Příspěvek od ltrejbal »
grantec píše:Aj v tomto fw plati, to co v predchadzajucich. Na plne vyuzitie vsetkych zmien je potrebne zvolit vyrobne nastavenia, odinstalovat stary OpenXCAS a nainstalovat ho znovu. Najlepsie cez DO a ponuku Home 3 - add .
Jen pro jistotu kontrolni otazka. Odinstalovat OpenXCAS znamena vymazat cely adresar EMU nebo staci v menu Plug-in udealt Delete Plug-in?
staci cez menu - delete plugin
robinek
Tak nevím ... mě nahrávání opět přestalo fungovat. Už mě to celkem začíná s... :32:
Dal jsem FW 1759 a tím funkčnost nahrávání končí ... a to tu grantec píše, že je opravené.
Něco se na HDD sice uloží, ale nejde to přehrát ani v AzBoxu ani v PC :42:
Udělal jsem reset do továrního, upgradnul FW, opět tovární, smazal celý OpenXCAS a znovu nainstaloval z azboxworldu.
Používám EMU mgcam jako klienta proti newcs serveru.
Jo a ještě zajímavě funguje Timeshift ... zastavím si program a znovu pustím .. to je OK.
Pak zmáčknu stop a pořad se vrátí do živého vysílání .. to je také OK.
Pak mě jen tak ani nevím proč asi po pěti hodinách napadlo zkusit zmáčknout tlačítko přetáčení zpět a zjistil jsem, že můžu normálně přetáčet, že se pořád ukládá záznam. To je trochu divné ne ? :wink:
dempsey
Ja toho moc nenahrávam, ale skúsil som teraz nahrať kúsok zo zdieľaného Film+.
Nahralo sa bez problému - prehralo tiež
robinek
dempsey píše:Ja toho moc nenahrávam, ale skúsil som teraz nahrať kúsok zo zdieľaného Film+.
A jaké používáš EMU vč. verze pls ?
dempsey
mgcamd z azboxworld
