Oscam L2B
Vše ohledně Oscamu
maxmanpc Slovakia
Re: Oscam L2B
Příspěvek od maxmanpc »
Frekvencie nepomohli :( Stále sa to snaží bežať cez cryptoworks.
2024/03/24 07:42:00 00000000 s     (main) System name    = Linux
2024/03/24 07:42:00 00000000 s     (main) Host name      = ustym4kpro
2024/03/24 07:42:00 00000000 s     (main) Release        = 4.4.35
2024/03/24 07:42:00 00000000 s     (main) Version        = #1 SMP Mon Dec 24 06:39:12 UTC 2018
2024/03/24 07:42:00 00000000 s     (main) Machine        = armv7l
2024/03/24 07:42:00 00000000 s     (main) Stb model      = dm8000
2024/03/24 07:42:00 00000000 s     (main) Stb boxtype    = ustym4kpro
2024/03/24 07:42:00 00000000 s     (main) creating pidfile /var/tmp/oscam-stable.pid with pid 29540
2024/03/24 07:42:00 00000000 s   (config) userdb reloaded: 3 accounts loaded, 0 expired, 0 disabled
2024/03/24 07:42:00 00000000 s     (main) signal handling initialized
2024/03/24 07:42:00 00000000 s   (config) 12 provid's loaded
2024/03/24 07:42:00 00000000 s   (config) 168 service-id's loaded in 2 ms
2024/03/24 07:42:00 00000000 s      (net) newcamd: initialized (fd=3, port=10000)
2024/03/24 07:42:00 00000000 s      (net) -> CAID: 0653 PROVID: 000000, 000004, 000008, 00000C, 000010
2024/03/24 07:42:00 00000000 s   (reader) freesatD [internal] creating thread for device /dev/sci0
2024/03/24 07:42:00 00000000 s     (main) waiting for local card init
2024/03/24 07:42:00 45A55D9F h    (webif) webif: decompressed 163830 bytes back into 400664 bytes
2024/03/24 07:42:00 45A55D9F h    (webif) HTTP Server running. ip=0.0.0.0 port=8888
2024/03/24 07:42:00 2A524054 r   (reader) freesatD [internal] Reader initialized (device=/dev/sci0, detect=cd, mhz=600, cardmhz=600)
2024/03/24 07:42:00 2A524054 r   (reader) freesatD [internal] Reader sci internal, detected box type: ustym4kpro
2024/03/24 07:42:01 2A524054 r   (reader) freesatD [internal] card detected
2024/03/24 07:42:01 2A524054 r   (reader) freesatD [internal] ATR: 3B 78 12 00 00 54 C4 03 00 8F F1 90 00
2024/03/24 07:42:03 2A524054 r   (reader) freesatD [internal] Hist. Bytes: TĦ#3;
2024/03/24 07:42:03 2A524054 r   (reader) freesatD [internal] detect irdeto card
2024/03/24 07:42:03 2A524054 r   (reader) freesatD [internal] Warning: needed try nr 2, next ECM has some delay
2024/03/24 07:42:06 2A524054 r        (-) -- Skipped 1 duplicated log lines --
2024/03/24 07:42:06 2A524054 r   (reader) freesatD [internal] card detected
2024/03/24 07:42:06 2A524054 r   (reader) freesatD [internal] type: CryptoWorks
2024/03/24 07:42:06 2A524054 r   (reader) freesatD [internal] Warning: needed try nr 2, next ECM has some delay
2024/03/24 07:42:07 2A524054 r   (reader) freesatD [internal] card system not supported
2024/03/24 07:42:07 2A524054 r   (reader) freesatD [internal] Normal mode failed, reverting to Deprecated Mode
2024/03/24 07:42:07 2A524054 r   (reader) freesatD [internal] ATR: 3B 78 12 00 00 54 C4 03 00 8F F1 90 00
2024/03/24 07:42:09 2A524054 r   (reader) freesatD [internal] Hist. Bytes: TĦ#3;
2024/03/24 07:42:09 2A524054 r   (reader) freesatD [internal] detect irdeto card
2024/03/24 07:42:09 2A524054 r   (reader) freesatD [internal] Irdeto SC 58 version 19 revision 1, patch level e
2024/03/24 07:42:09 2A524054 r   (reader) freesatD [internal] Owner ID : A888
2024/03/24 07:42:09 2A524054 r   (reader) freesatD [internal] Providers: 4, ascii serial: ##########, hex serial: ######, hex base: ##
2024/03/24 07:42:09 2A524054 r   (reader) freesatD [internal] Caid     : 0653, acs: 0.05, country code: SVK
2024/03/24 07:42:10 2A524054 r   (reader) freesatD [internal] Rand4    : B3BDBC40
2024/03/24 07:42:10 2A524054 r DynCamKey
2024/03/24 07:42:10 2A524054 r IPRCiLayer supported
2024/03/24 07:42:10 2A524054 r .......................................................
2024/03/24 07:42:10 2A524054 r   ********** CamKeyData CRC ERROR  *****************
2024/03/24 07:42:11 2A524054 r IPRCiLayer supported
2024/03/24 07:42:11 2A524054 r .......................................................
2024/03/24 07:42:11 2A524054 r   ********** CamKeyData CRC ERROR  *****************
2024/03/24 07:42:12 2A524054 r   (reader) freesatD [internal] card detected
2024/03/24 07:42:12 2A524054 r   (reader) freesatD [internal] type: CryptoWorks
2024/03/24 07:42:13 2A524054 r   (reader) freesatD [internal] type: CryptoWorks, caid: 0D97, ascii serial: #########, hex serial: ##########
2024/03/24 07:42:13 2A524054 r   (reader) freesatD [internal] issuer: CryptoWorks, id: 04, bios: v3, pin: unknown, mfid: 3F20
2024/03/24 07:42:13 2A524054 r   (reader) freesatD [internal] providers: 4 (04,08,0C,10)
2024/03/24 07:42:13 2A524054 r   (reader) freesatD [internal] disable pincode to card
2024/03/24 07:42:13 2A524054 r   (reader) freesatD [internal] found card system cryptoworks
2024/03/24 07:42:13 2A524054 r   (reader) freesatD [cryptoworks] THIS WAS A SUCCESSFUL START ATTEMPT No  1 out of max allotted of 1
2024/03/24 07:42:13 2A524054 r   (reader) freesatD [cryptoworks] provider: 1, id: 04, name: Operator: FFFF
2024/03/24 07:42:13 2A524054 r   (reader) freesatD [cryptoworks] chid: 7FFE, date: 2024/03/24 - 2024/04/23, name: Product 7FFE
2024/03/24 07:42:13 2A524054 r   (reader) freesatD [cryptoworks] chid: 7FFD, date: 2024/03/24 - 2024/04/03, name: Product 7FFD
2024/03/24 07:42:13 2A524054 r   (reader) freesatD [cryptoworks] chid: FFD8, date: 2021/12/22 - 2022/01/01, name: Product FFD8
2024/03/24 07:42:13 2A524054 r   (reader) freesatD [cryptoworks] chid: 0021, date: 2024/03/23 - 2024/04/03, name: Product 0021
2024/03/24 07:42:13 2A524054 r   (reader) freesatD [cryptoworks] chid: 0022, date: 2024/03/23 - 2024/04/03, name: Product 0022
2024/03/24 07:42:13 2A524054 r   (reader) freesatD [cryptoworks] chid: 0064, date: 2024/03/23 - 2024/04/03, name: Product 0064
2024/03/24 07:42:13 2A524054 r   (reader) freesatD [cryptoworks] chid: 0065, date: 2024/03/23 - 2024/04/03, name: Product 0065
2024/03/24 07:42:13 2A524054 r   (reader) freesatD [cryptoworks] chid: 03EA, date: 2024/03/23 - 2024/04/23, name: Product 03EA
2024/03/24 07:42:13 2A524054 r   (reader) freesatD [cryptoworks] chid: 03EE, date: 2024/03/23 - 2024/04/23, name: Product 03EE
2024/03/24 07:42:14 2A524054 r   (reader) freesatD [cryptoworks] chid: 03F2, date: 2024/03/23 - 2024/04/23, name: Product 03F2
2024/03/24 07:42:14 2A524054 r   (reader) freesatD [cryptoworks] chid: 03F3, date: 2024/03/23 - 2024/04/23, name: Product 03F3
2024/03/24 07:42:14 2A524054 r   (reader) freesatD [cryptoworks] chid: 7533, date: 2024/03/23 - 2024/04/23, name: Product 7533
2024/03/24 07:42:14 2A524054 r   (reader) freesatD [cryptoworks] chid: 7536, date: 2024/03/23 - 2024/04/23, name: Product 7536
2024/03/24 07:42:14 2A524054 r   (reader) freesatD [cryptoworks] chid: 754B, date: 2024/03/23 - 2024/04/23, name: Product 754B
2024/03/24 07:42:14 2A524054 r   (reader) freesatD [cryptoworks] chid: 7554, date: 2024/03/23 - 2024/04/23, name: Product 7554
2024/03/24 07:42:14 2A524054 r   (reader) freesatD [cryptoworks] provider: 2, id: 08, name: Operator: FFFF
2024/03/24 07:42:14 2A524054 r   (reader) freesatD [cryptoworks] provider: 3, id: 0C, name: Operator: FFFF
2024/03/24 07:42:14 2A524054 r   (reader) freesatD [cryptoworks] provider: 4, id: 10, name: Operator: FFFF
2024/03/24 07:42:14 2A524054 r   (reader) freesatD [cryptoworks] ready for requests
2024/03/24 07:42:15 00000000 s     (main) init for all local cards done
2024/03/24 07:42:15 00000000 s (emmcache) loading emmcache disabled since no reader is using it!
2024/03/24 07:42:15 00000000 s (emmcache) loading emmstats disabled since no reader is using it!
2024/03/24 07:42:15 00000000 s     (gbox) local gbox failed init
2024/03/24 07:42:15 448413D5 c   (client) plain dvbapi-client granted (local, au=auto (1 reader))
2024/03/24 07:42:15 448413D5 c   (dvbapi) dvbapi channelcache loaded from /etc/tuxbox/config/oscam-stable/oscam.ccache
2024/03/24 07:42:15 448413D5 c   (dvbapi) Detected /dev/dvb/adapter0/demux0 Api: 0, userconfig boxtype: 0 maximum number of filters is 40 (oscam limit is 64)
2024/03/24 07:42:15 448413D5 c   (dvbapi) Detected /dev/dvb/adapter0/ca0 device, total available descramblers: 16
2024/03/24 07:42:20 448413D5 c   (dvbapi) Demuxer 0 ecmpid 0 CAID: 1882 ECM_PID: 0533 PROVID: 000000
2024/03/24 07:42:20 448413D5 c   (dvbapi) Demuxer 0 ecmpid 1 CAID: 1886 ECM_PID: 0534 PROVID: 000000
2024/03/24 07:42:20 448413D5 c   (dvbapi) Demuxer 0 ecmpid 2 CAID: 0D97 ECM_PID: 0535 PROVID: 000000
2024/03/24 07:42:20 448413D5 c   (dvbapi) Demuxer 0 ecmpid 3 CAID: 0653 ECM_PID: 0536 PROVID: 000000
2024/03/24 07:42:20 448413D5 c   (dvbapi) Demuxer 0 ecmpid 4 CAID: 0B02 ECM_PID: 0537 PROVID: 000000
2024/03/24 07:42:20 448413D5 c   (dvbapi) Demuxer 0 found 5 ECM pids and 5 STREAM pids in CA PMT
2024/03/24 07:42:20 448413D5 c   (dvbapi) Demuxer 0 no suitable readers found that can be used for decoding!
2024/03/24 07:42:24 448413D5 c   (dvbapi) Demuxer 0 no enabled matching ecmpids -> decoding is waiting for matching readers!
2024/03/24 07:42:50 448413D5 c        (-) -- Skipped 5 duplicated log lines --
2024/03/24 07:42:50 448413D5 c   (reader) freesatD [cryptoworks] EMM: reader_caid 0D97 != emmpid caid 1882 -> SKIP!
2024/03/24 07:42:50 448413D5 c   (reader) freesatD [cryptoworks] EMM: reader_caid 0D97 != emmpid caid 0B02 -> SKIP!
2024/03/24 07:42:50 448413D5 c   (reader) freesatD [cryptoworks] EMM: reader_caid 0D97 != emmpid caid 0653 -> SKIP!
2024/03/24 07:42:50 448413D5 c   (reader) freesatD [cryptoworks] EMM: reader 0D97 match since emmpid has no provid -> SEND!
2024/03/24 07:42:50 448413D5 c      (emm) emm:
2024/03/24 07:42:50 448413D5 c      (emm)   86 70 08 A9 FF 83 01 04 84 01 00
2024/03/24 07:42:50 448413D5 c   (reader) freesatD [cryptoworks] EMM: Entered cryptoworks_get_emm_type ep->emm[0]=86
2024/03/24 07:42:50 448413D5 c   (reader) freesatD [cryptoworks] EMM: SHARED (Header)
2024/03/24 07:42:50 448413D5 c   (reader) freesatD [cryptoworks] EMM: shared emm (EMM-SB)
2024/03/24 07:42:51 448413D5 c      (emm) emm:
2024/03/24 07:42:51 448413D5 c      (emm)   86 70 08 A9 FF 83 01 04 84 01 00
2024/03/24 07:42:51 448413D5 c   (reader) freesatD [cryptoworks] EMM: reader 0D97 match since emmpid has no provid -> SEND!
2024/03/24 07:42:51 448413D5 c   (reader) freesatD [cryptoworks] EMM: Entered cryptoworks_get_emm_type ep->emm[0]=86
2024/03/24 07:42:51 448413D5 c   (reader) freesatD [cryptoworks] EMM: SHARED (Header)
2024/03/24 07:42:51 448413D5 c   (reader) freesatD [cryptoworks] EMM: shared emm (EMM-SB)
2024/03/24 07:42:52 448413D5 c   (dvbapi) Demuxer 0 stopped descrambling for program 03F5 (Markiza HD)
2024/03/24 07:42:53 448413D5 c   (dvbapi) Demuxer 0 ecmpid 0 CAID: 1882 ECM_PID: 04CF PROVID: 000000
2024/03/24 07:42:53 448413D5 c   (dvbapi) Demuxer 0 ecmpid 1 CAID: 1886 ECM_PID: 04D0 PROVID: 000000
2024/03/24 07:42:53 448413D5 c   (dvbapi) Demuxer 0 ecmpid 2 CAID: 0D97 ECM_PID: 04D1 PROVID: 000000
2024/03/24 07:42:53 448413D5 c   (dvbapi) Demuxer 0 ecmpid 3 CAID: 0653 ECM_PID: 04D2 PROVID: 000000
2024/03/24 07:42:53 448413D5 c   (dvbapi) Demuxer 0 ecmpid 4 CAID: 0B02 ECM_PID: 04D3 PROVID: 000000
2024/03/24 07:42:53 448413D5 c   (dvbapi) Demuxer 0 found 5 ECM pids and 5 STREAM pids in CA PMT
2024/03/24 07:42:53 448413D5 c   (dvbapi) Demuxer 0 no suitable readers found that can be used for decoding!
2024/03/24 07:42:57 448413D5 c   (dvbapi) Demuxer 0 no enabled matching ecmpids -> decoding is waiting for matching readers!
2024/03/24 07:43:23 448413D5 c        (-) -- Skipped 5 duplicated log lines --
2024/03/24 07:43:23 448413D5 c   (reader) freesatD [cryptoworks] EMM: reader_caid 0D97 != emmpid caid 1882 -> SKIP!
2024/03/24 07:43:23 448413D5 c   (reader) freesatD [cryptoworks] EMM: reader_caid 0D97 != emmpid caid 0B02 -> SKIP!
2024/03/24 07:43:23 448413D5 c   (reader) freesatD [cryptoworks] EMM: reader_caid 0D97 != emmpid caid 0653 -> SKIP!
2024/03/24 07:43:23 448413D5 c   (reader) freesatD [cryptoworks] EMM: reader 0D97 match since emmpid has no provid -> SEND!
2024/03/24 07:43:23 448413D5 c   (dvbapi) Demuxer 0 stopped descrambling for program 03F4 (Dvojka HD)
2024/03/24 07:43:23 448413D5 c   (dvbapi) Demuxer 0 ecmpid 0 CAID: 1882 ECM_PID: 0533 PROVID: 000000
2024/03/24 07:43:23 448413D5 c   (dvbapi) Demuxer 0 ecmpid 1 CAID: 1886 ECM_PID: 0534 PROVID: 000000
2024/03/24 07:43:23 448413D5 c   (dvbapi) Demuxer 0 ecmpid 2 CAID: 0D97 ECM_PID: 0535 PROVID: 000000
2024/03/24 07:43:23 448413D5 c   (dvbapi) Demuxer 0 ecmpid 3 CAID: 0653 ECM_PID: 0536 PROVID: 000000
2024/03/24 07:43:23 448413D5 c   (dvbapi) Demuxer 0 ecmpid 4 CAID: 0B02 ECM_PID: 0537 PROVID: 000000
2024/03/24 07:43:23 448413D5 c   (dvbapi) Demuxer 0 found 5 ECM pids and 5 STREAM pids in CA PMT
2024/03/24 07:43:23 448413D5 c   (dvbapi) Demuxer 0 no suitable readers found that can be used for decoding!
2024/03/24 07:43:27 448413D5 c   (dvbapi) Demuxer 0 no enabled matching ecmpids -> decoding is waiting for matching readers!
2024/03/24 07:43:53 448413D5 c        (-) -- Skipped 5 duplicated log lines --
2024/03/24 07:43:53 448413D5 c   (reader) freesatD [cryptoworks] EMM: reader_caid 0D97 != emmpid caid 1882 -> SKIP!
2024/03/24 07:43:53 448413D5 c   (reader) freesatD [cryptoworks] EMM: reader_caid 0D97 != emmpid caid 0B02 -> SKIP!
2024/03/24 07:43:53 448413D5 c   (reader) freesatD [cryptoworks] EMM: reader_caid 0D97 != emmpid caid 0653 -> SKIP!
2024/03/24 07:43:53 448413D5 c   (reader) freesatD [cryptoworks] EMM: reader 0D97 match since emmpid has no provid -> SEND!
2024/03/24 07:43:54 448413D5 c      (emm) emm:
2024/03/24 07:43:54 448413D5 c      (emm)   86 70 08 A9 FF 83 01 04 84 01 00
2024/03/24 07:43:54 448413D5 c   (reader) freesatD [cryptoworks] EMM: reader 0D97 match since emmpid has no provid -> SEND!
2024/03/24 07:43:54 448413D5 c   (reader) freesatD [cryptoworks] EMM: Entered cryptoworks_get_emm_type ep->emm[0]=86
2024/03/24 07:43:54 448413D5 c   (reader) freesatD [cryptoworks] EMM: SHARED (Header)
2024/03/24 07:43:54 448413D5 c   (reader) freesatD [cryptoworks] EMM: shared emm (EMM-SB)
2024/03/24 07:43:57 448413D5 c      (emm) emm:
2024/03/24 07:43:57 448413D5 c      (emm)   86 70 08 A9 FF 83 01 04 84 01 00
2024/03/24 07:43:57 448413D5 c   (reader) freesatD [cryptoworks] EMM: reader 0D97 match since emmpid has no provid -> SEND!
2024/03/24 07:43:57 448413D5 c   (reader) freesatD [cryptoworks] EMM: Entered cryptoworks_get_emm_type ep->emm[0]=86
2024/03/24 07:43:57 448413D5 c   (reader) freesatD [cryptoworks] EMM: SHARED (Header)
2024/03/24 07:43:57 448413D5 c   (reader) freesatD [cryptoworks] EMM: shared emm (EMM-SB)
2024/03/24 07:43:57 448413D5 c   (dvbapi) Demuxer 0 no enabled matching ecmpids -> decoding is waiting for matching readers!
2024/03/24 07:43:59 448413D5 c      (emm) emm:
2024/03/24 07:43:59 448413D5 c      (emm)   86 70 08 A9 FF 83 01 04 84 01 00
2024/03/24 07:43:59 448413D5 c   (reader) freesatD [cryptoworks] EMM: reader 0D97 match since emmpid has no provid -> SEND!
2024/03/24 07:43:59 448413D5 c   (reader) freesatD [cryptoworks] EMM: Entered cryptoworks_get_emm_type ep->emm[0]=86
2024/03/24 07:43:59 448413D5 c   (reader) freesatD [cryptoworks] EMM: SHARED (Header)
2024/03/24 07:43:59 448413D5 c   (reader) freesatD [cryptoworks] EMM: shared emm (EMM-SB)
2024/03/24 07:44:00 448413D5 c      (emm) emm:
2024/03/24 07:44:00 448413D5 c      (emm)   86 70 08 A9 FF 83 01 04 84 01 00
2024/03/24 07:44:00 448413D5 c   (reader) freesatD [cryptoworks] EMM: reader 0D97 match since emmpid has no provid -> SEND!
2024/03/24 07:44:00 448413D5 c   (reader) freesatD [cryptoworks] EMM: Entered cryptoworks_get_emm_type ep->emm[0]=86
2024/03/24 07:44:00 448413D5 c   (reader) freesatD [cryptoworks] EMM: SHARED (Header)
2024/03/24 07:44:00 448413D5 c   (reader) freesatD [cryptoworks] EMM: shared emm (EMM-SB)
2024/03/24 07:44:00 448413D5 c   (dvbapi) Demuxer 0 no enabled matching ecmpids -> decoding is waiting for matching readers!
2024/03/24 07:44:02 448413D5 c      (emm) emm:
2024/03/24 07:44:02 448413D5 c      (emm)   86 70 08 A9 FF 83 01 04 84 01 00
2024/03/24 07:44:02 448413D5 c   (reader) freesatD [cryptoworks] EMM: reader 0D97 match since emmpid has no provid -> SEND!
2024/03/24 07:44:02 448413D5 c   (reader) freesatD [cryptoworks] EMM: Entered cryptoworks_get_emm_type ep->emm[0]=86
2024/03/24 07:44:02 448413D5 c   (reader) freesatD [cryptoworks] EMM: SHARED (Header)
2024/03/24 07:44:02 448413D5 c   (reader) freesatD [cryptoworks] EMM: shared emm (EMM-SB)
2024/03/24 07:44:03 448413D5 c      (emm) emm:
2024/03/24 07:44:03 448413D5 c      (emm)   86 70 08 A9 FF 83 01 04 84 01 00
2024/03/24 07:44:03 448413D5 c   (reader) freesatD [cryptoworks] EMM: reader 0D97 match since emmpid has no provid -> SEND!
2024/03/24 07:44:03 448413D5 c   (reader) freesatD [cryptoworks] EMM: Entered cryptoworks_get_emm_type ep->emm[0]=86
2024/03/24 07:44:03 448413D5 c   (reader) freesatD [cryptoworks] EMM: SHARED (Header)
2024/03/24 07:44:03 448413D5 c   (reader) freesatD [cryptoworks] EMM: shared emm (EMM-SB)
2024/03/24 07:44:04 448413D5 c   (dvbapi) Demuxer 0 no enabled matching ecmpids -> decoding is waiting for matching readers!
2024/03/24 07:44:05 448413D5 c      (emm) emm:
2024/03/24 07:44:05 448413D5 c      (emm)   86 70 08 A9 FF 83 01 04 84 01 00
2024/03/24 07:44:05 448413D5 c   (reader) freesatD [cryptoworks] EMM: reader 0D97 match since emmpid has no provid -> SEND!
2024/03/24 07:44:05 448413D5 c   (reader) freesatD [cryptoworks] EMM: Entered cryptoworks_get_emm_type ep->emm[0]=86
2024/03/24 07:44:05 448413D5 c   (reader) freesatD [cryptoworks] EMM: SHARED (Header)
2024/03/24 07:44:05 448413D5 c   (reader) freesatD [cryptoworks] EMM: shared emm (EMM-SB)
2024/03/24 07:44:06 448413D5 c      (emm) emm:
2024/03/24 07:44:06 448413D5 c      (emm)   86 70 08 A9 FF 83 01 04 84 01 00
2024/03/24 07:44:06 448413D5 c   (reader) freesatD [cryptoworks] EMM: reader 0D97 match since emmpid has no provid -> SEND!
2024/03/24 07:44:06 448413D5 c   (reader) freesatD [cryptoworks] EMM: Entered cryptoworks_get_emm_type ep->emm[0]=86
2024/03/24 07:44:06 448413D5 c   (reader) freesatD [cryptoworks] EMM: SHARED (Header)
2024/03/24 07:44:06 448413D5 c   (reader) freesatD [cryptoworks] EMM: shared emm (EMM-SB)
2024/03/24 07:44:07 448413D5 c      (emm) emm:
2024/03/24 07:44:07 448413D5 c      (emm)   84 70 59 A9 FF 00 12 58 26 00 00 56 80 04 00 12
2024/03/24 07:44:07 448413D5 c      (emm)   58 26 C0 3E 02 58 26 00 00 38 85 EC 5B ED 3E C4
2024/03/24 07:44:07 448413D5 c      (emm)   60 FB A2 DD CF E4 6A 94 38 92 D0 6E 4D A3 86 2B
2024/03/24 07:44:07 448413D5 c      (emm)   7C D5 18 FD BA D7 28 87 36 EF A7 10 A5 6A B3 35
2024/03/24 07:44:07 448413D5 c      (emm)   88 3C 34 AF 92 88 DC 7D CE 7E FD 55 01 56 30 BC
2024/03/24 07:44:07 448413D5 c      (emm)   9E 1E DF 08 50 D4 C6 07 88 CB 25 19
2024/03/24 07:44:07 448413D5 c   (reader) freesatD [cryptoworks] EMM: reader 0D97 match since emmpid has no provid -> SEND!
2024/03/24 07:44:07 448413D5 c   (reader) freesatD [cryptoworks] EMM: Entered cryptoworks_get_emm_type ep->emm[0]=84
2024/03/24 07:44:07 448413D5 c   (reader) freesatD [cryptoworks] EMM: SHARED, ep = ############ rdr = ############
2024/03/24 07:44:07 448413D5 c   (reader) freesatD [cryptoworks] EMM: shared emm (EMM-SH)
2024/03/24 07:44:07 448413D5 c   (reader) freesatD [cryptoworks] EMM: EMM-SH only in memcpy
2024/03/24 07:44:08 448413D5 c   (dvbapi) Demuxer 0 no enabled matching ecmpids -> decoding is waiting for matching readers!
2024/03/24 07:44:08 448413D5 c      (emm) emm:
2024/03/24 07:44:08 448413D5 c      (emm)   86 70 08 A9 FF 83 01 04 84 01 00
2024/03/24 07:44:08 448413D5 c   (reader) freesatD [cryptoworks] EMM: reader 0D97 match since emmpid has no provid -> SEND!
2024/03/24 07:44:08 448413D5 c   (reader) freesatD [cryptoworks] EMM: Entered cryptoworks_get_emm_type ep->emm[0]=86
2024/03/24 07:44:08 448413D5 c   (reader) freesatD [cryptoworks] EMM: SHARED (Header)
2024/03/24 07:44:08 448413D5 c   (reader) freesatD [cryptoworks] EMM: shared emm (EMM-SB)
2024/03/24 07:44:08 448413D5 c   (reader) freesatD [cryptoworks] EMM: shared emm (assembled):
2024/03/24 07:44:08 448413D5 c   (reader)   84 70 5F A9 FF 00 12 58 26 00 00 56 80 04 00 12
2024/03/24 07:44:08 448413D5 c   (reader)   58 26 83 01 04 84 01 00 C0 3E 02 58 26 00 00 38
2024/03/24 07:44:08 448413D5 c   (reader)   85 EC 5B ED 3E C4 60 FB A2 DD CF E4 6A 94 38 92
2024/03/24 07:44:08 448413D5 c   (reader)   D0 6E 4D A3 86 2B 7C D5 18 FD BA D7 28 87 36 EF
2024/03/24 07:44:08 448413D5 c   (reader)   A7 10 A5 6A B3 35 88 3C 34 AF 92 88 DC 7D CE 7E
2024/03/24 07:44:08 448413D5 c   (reader)   FD 55 01 56 30 BC 9E 1E DF 08 50 D4 C6 07 88 CB
2024/03/24 07:44:08 448413D5 c   (reader)   25 19
2024/03/24 07:44:08 448413D5 c   (reader) freesatD [cryptoworks] EMM: emmtype shared. Reader serial ################.
2024/03/24 07:44:08 448413D5 c   (reader) freesatD [cryptoworks] EMM: emm UA/SA: ################.
2024/03/24 07:44:08 448413D5 c   (reader) freesatD [cryptoworks] EMM: emm is being sent to reader
2024/03/24 07:44:08 2A524054 r   (reader) freesatD [cryptoworks] local emmtype=shared, len=95 (hex: 0x5F), cnt=0: written (150 ms)
2024/03/24 07:44:09 448413D5 c      (emm) emm:
2024/03/24 07:44:09 448413D5 c      (emm)   86 70 08 A9 FF 83 01 04 84 01 00
2024/03/24 07:44:09 448413D5 c   (reader) freesatD [cryptoworks] EMM: reader 0D97 match since emmpid has no provid -> SEND!
2024/03/24 07:44:09 448413D5 c   (reader) freesatD [cryptoworks] EMM: Entered cryptoworks_get_emm_type ep->emm[0]=86
2024/03/24 07:44:09 448413D5 c   (reader) freesatD [cryptoworks] EMM: SHARED (Header)
2024/03/24 07:44:09 448413D5 c   (reader) freesatD [cryptoworks] EMM: shared emm (EMM-SB)
2024/03/24 07:44:11 448413D5 c      (emm) emm:
2024/03/24 07:44:11 448413D5 c      (emm)   86 70 08 A9 FF 83 01 04 84 01 00
2024/03/24 07:44:11 448413D5 c   (reader) freesatD [cryptoworks] EMM: reader 0D97 match since emmpid has no provid -> SEND!
2024/03/24 07:44:11 448413D5 c   (reader) freesatD [cryptoworks] EMM: Entered cryptoworks_get_emm_type ep->emm[0]=86
2024/03/24 07:44:11 448413D5 c   (reader) freesatD [cryptoworks] EMM: SHARED (Header)
2024/03/24 07:44:11 448413D5 c   (reader) freesatD [cryptoworks] EMM: shared emm (EMM-SB)
2024/03/24 07:44:11 448413D5 c   (dvbapi) Demuxer 0 no enabled matching ecmpids -> decoding is waiting for matching readers!
2024/03/24 07:44:12 448413D5 c      (emm) emm:
2024/03/24 07:44:12 448413D5 c      (emm)   86 70 08 A9 FF 83 01 04 84 01 00
2024/03/24 07:44:12 448413D5 c   (reader) freesatD [cryptoworks] EMM: reader 0D97 match since emmpid has no provid -> SEND!
2024/03/24 07:44:12 448413D5 c   (reader) freesatD [cryptoworks] EMM: Entered cryptoworks_get_emm_type ep->emm[0]=86
2024/03/24 07:44:12 448413D5 c   (reader) freesatD [cryptoworks] EMM: SHARED (Header)
2024/03/24 07:44:12 448413D5 c   (reader) freesatD [cryptoworks] EMM: shared emm (EMM-SB)
2024/03/24 07:44:14 448413D5 c      (emm) emm:
2024/03/24 07:44:14 448413D5 c      (emm)   86 70 08 A9 FF 83 01 04 84 01 00
2024/03/24 07:44:14 448413D5 c   (reader) freesatD [cryptoworks] EMM: reader 0D97 match since emmpid has no provid -> SEND!
2024/03/24 07:44:14 448413D5 c   (reader) freesatD [cryptoworks] EMM: Entered cryptoworks_get_emm_type ep->emm[0]=86
2024/03/24 07:44:14 448413D5 c   (reader) freesatD [cryptoworks] EMM: SHARED (Header)
2024/03/24 07:44:14 448413D5 c   (reader) freesatD [cryptoworks] EMM: shared emm (EMM-SB)
005jon Slovakia
Re: Oscam L2B
Příspěvek od 005jon »
Zbytočne sa trápiš L2B na 0,8W tam žiadne zabezpečenie neje.
JOJ 24 funguje aj pod 0D97
(ecm) local (0D97@000004/0000/271F/80:B9D0D4170C425B5E099F05B09E1BF21F): found (126 ms) by UPC - JOJ 24 HD
maxmanpc Slovakia
Re: Oscam L2B
Takže mi stačí len pridať 0D97 do konfiguráku a malo by to ísť?
maxmanpc Slovakia
Re: Oscam L2B
Do oscam.server som pridal caid 0D97 a do oscam.dvbapi P:0D97, ale aj tak mi to nefunguje. Pri naladenom JOJ 24/24HD mi v logu nepribudne ani riadok a je len tma. Proste oscam nič vtedy nerobí.
Warder Slovakia
Dostal poděkování: 99 poděkování
Re: Oscam L2B
Příspěvek od Warder »
Daj si tam "spravny" Oscam a pojde ti to v pohode, aj s caid 0653. ;)
:89:
maxmanpc Slovakia
Re: Oscam L2B
A ktorý je ten správny oscam?
S verziou r11715 mi ide caid 0653, ale neviem v ňom rozbehať aj 0D97.
Pozeral som aj tu na fóre, ale neviem sa dopátrať k tej "správnej" verzii
Warder Slovakia
Re: Oscam L2B
Vyprdni sa na nejaky stary Cryptoworks - 0D97, ten ti je k nicomu. Hladaj napriklad Oscam od Samur -a, posledna verzia je r11750-800.
:89:
happy66 Czech Republic
Re: Oscam L2B
Příspěvek od happy66 »
Poslední Oscam od Samur najdeš zde: https://forum.satdigitalne.cz/viewtopic ... 64#p126664
Funguje s tímto zápisem readeru:
[reader]
label = skylink_l2b
protocol = internal
device = /dev/sci0
caid = 0624
force_irdeto = 1
needsemmfirst = 1
detect = cd
mhz = 500
group = 1
blockemm-unknown = 1
disablecrccws = 1
Není potřeba rsakeys ani boxkeys
Octagon 8008 4K
OpenATV 6.4 Oscam Samur 11784-801
AB Cryptobox 800UHD
Zpět na „Oscam“
