OpenATV 6.4 by ciefp
[Image Info]
Model: Vu+ Zero4K
Backup Date: 2019-12-14
Chipset: BCM72604
CPU: Broadcom
Cores: 2
Version: 6.4
Build: 0
Kernel: 4.1.20
Drivers: 2019-04-24
Last update: 2019-12-08
Skin Metrix FULL HD 1920x1080p
Only minor changes in color
and appearance of the skin
extra skin
FHD Blue-L i n e-OE-4ATV
Excelence FHD
Video resolution : 1920x1080p
Timezone : GMT+1
Configuration tuner : Positioner
Network : fixed 192.168.1.100
user: root
pass: ciefp
Change password = menu - setup - system - network - password setup
Mymetrix weather settings: Kisač Serbia( Change to your location )
Plugins > mymetrix lite > weather settings
Channel list:
ciefp-E2-75E-34W-14.12.2019
### Plugins ###
EPG-Importer
E2iPlayer 09.12
AddKey 3.2
BisssFeedAutokey 2.2
File Commander
SubSupport 1.56
Kodi Lite 17.6
HbbTvplayer
HBBTV
IMDB-FNC
Radio FNC
TvToM3u
Openmultiboot
QuickSignal Mod by RAED 6.4
Satvenus panel 7.32
WorldCam 3.1
Weather plugin Kisač Serbia( Change to your location )
Youtube TV
Ice TV
### Softcam ###
Softcamkey by enigma1969
- Abertis hispasat 30w - OK ( astra-sm )
- PowerVU 0.8W - OK
- PowerVU 4.8E - OK
- Tandberg 1.9 Arena sport - OK
- Tandberg 42.0E Fox Network - OK
- Digea,Zadruga biss 3.0E - OK
- ERT,Eurofootball 1,2,3 biss 39E - OK
### softcam instaled ###
softcam-feed-universal_6.Plus_all
OSCam 11546 r798( oscam.server /etc/tuxbox/config )Sky DE ready
OSCam 11572 r798( oscam.server /etc/tuxbox/config )Sky DE ready
cccam 2.3.2 r1 ( CCcam.cfg /etc ) (softcam /usr/keys/SoftCam.Key) Sky DE ready
### Hotkey setup ###
Radio - EPG Importer
TV - Subsupport
PVR - Manual scan,Signal finder,Blind scan
RED - HBBTV player ,HBBTV aplication
TEXT - QuickSignal Mod RAED
REC - IMDB-FNC
Ak by mal niekto zaujem to cele vyskusat tak moze stahovat z https://uploadfiles.io/fbnp6m6h
Backup VU+ Zero4K UpenATV 6.4 - ciefp
Odkaz na stažení Images pro přijímače VU+.
Warder
- Dostal poděkování: 99 poděkování
Re: Backup VU+ Zero4K UpenATV 6.4 - ciefp
Ahoj!
Diky moc! Stazeno, nainstalovano, upraveno (Ip adresa atp) a funguje skvele! Velka uspora casu, po migraci z HDBoxu a Octagonu. S cim trochu bojuju je OSCAM, zda se ze funguje, ale nektere programy kostickuji, kdyz je jedu pres CCCam (nastavil jsem si jej k serveru kde mam pristup), tak to bezi dobre, ale nesmim mit zastrcenou kartu s CI modulem (Smit), pak se to pere a nejake kanaly kostickuji a zamrzaji.
Jeste jednou moc diky!
Zpět na „Odkaz na stažení Images pro přijímače VU+“
