To čo sa udialo za posledne 3 dny
enigma2: 4.3.1r7
- allow to downscale with factors up to 225
- eMediaDatabase/DatabasePlaylist: allow to presizing cover arts, use 300x300 as default
- fixed linked and "satpos depend" tuner handling
- fixed motor turning with enabled power measurement
(broken since 4.3.1r5)
enigma2: 4.3.1r6
- fixed DVB-T(2) namespace problem
- fixed satfinder crash on change from predefined to manuel transponder
introduced in 4.3.1r5
- allow to input DVB-S(2) frequencies with one decimal place
needed to lock transponders with very low symbol rates
enigma2: 4.3.1r5
* updated all translations to latest pootle (2017-05-18)
* fixed ATSC DDP (AC3+) detection (IPTV streams)
* Scan/Tuners
- fixed DVB-S2 FEC selection in manual scan
- fixed some issues with DVB-S2 MIS/PLS code/mode handling
- show auto FEC, auto modulation, PLS, MIS settings in satfinder and positioner setup
- don't show DVB-S2 PLS/MIS settings/infos when the tuner does not support it
- fixed tuning on APSK16/32 transponders in some cases
- fixed DVB-T(2) 5V handling for combo tuners
- added "rotor turning speed in degree" option for motor-driven antennas
and use it for blindscan (to avoid foreign sat locks)
- allow the same service on different frequencies for DVB-T(2)
(for regions with multiple transmitters in reach)
dreambox-dvb-modules: update hardware drivers for dm900, dm820, dm7080
- silabs based tuners:
- improved combo tuner detection (dm820/dm7080)
- longer tune timeout when the symbolrate is lower 1000 (DVB-S/S2)
only interesting for channel searching
- dont return outdated SNR values until demod has no carrier lock
- add debug output for carried/final lock and timeout
- PositionerSetup: fixed crash when no transponder is tuned
* CeC: added very tiny vendor handler for Philips
* Movie Player: added a minimum treshold before we consider resuming playback (configurable)
* fixed broken IPv6 manual configuration
* fixed database based cover arts not showing up in MediaCenter/Audio
* fixed crash in MediaCenter/Video when switching between movies quickly (need some feedback on this)
For Developers:
* eServiceReference: fixed some issues with parsing of additional headers
* stop generating and using the index-meta files in favor of building a full index on (softwaremanager) startup based on all available plugin meta files
