Mnigma Wetek Play
Odkaz pro stažení firmware Enigma2 a diskuze k firmware.
Moderátor: matchboxx
matchboxx
Mnigma Wetek Play
Příspěvek od matchboxx »
balkanska verze Enigmy pro Wetek play
Experimental release of PLi based Enigma2 for WeTekPlay.
Initial boot takes some time to prepare micro SD card for E2 and Kodi.
By default (might change in the future and for NAND version), recording and timeshift are set to use micro SD card partition.
EPG data uses /hdd as well as E2 Picons. All the above is adjustable from System Menu.
In general, it is preferable to use faster media for recording. Your new USB stick might be (much) faster than micro SD card and vice versa.
Tested with Wetek E2 remote control.
OElec RC support still limited, but should work after selecting Elec remote from Menu-Setup-System-WeTekRC select
and loading OElec keymap from Menu-Setup-System-Keymap.
******-latest update only binaries, leaving your settings intact.
Until fixed, please do NOT mount (or use in any other way) kernel partition from Setup-System-Device Mount Manager. It is a small, FAT16
partition (Shown 1st, with =?=) and is not of much use except for kernel.
RC buttons assignemts were done in good faith, please feel free to change as per your pleasure in Hotkeys.
Radio mode supported. Note that some channel lists do not include DVB-S radio (ciefp).
E2 based playback of recorded material with REW/FF (numercal keys; 1, 4, 7 rewind in var speeds, 3, 6, 9 do FF).
Mnigma's native skins are MetropolisHD in two variants Dark and Light. Three native PLi skins are included as well (full HD is NOT an option for now).
Wetek System Menu includes a tool for fine tuning AV sync. Default settings are likely to be agreeable for most cases.
verze z 13.1.1016
ke stazeni http://mnigma.zapto.org/Mnigma/WeTekPla ... sdcard.zip
https://PrivateLadyEscorts.com - Secret Local Dating - No Verify - Anonymous Sex Dating - Best Private Lady Chat
dpabox Slovakia
Re: Mnigma Wetek Play
Příspěvek od dpabox »
vdaka za sprostredkovanu 0.10 verziu MNIGMA E2 pre Wetek .
Instalacia pre pouzitie vo Wetek Play na 2GB mirroSD kartu bez problemov za 5 minut vcetne posledneho oscamu .
Verzia sa javi ako velmi svizna. Ostavam na dalsom testovani
matchboxx píše:balkanska verze Enigmy pro Wetek play
verze z 13.1.1016
matchboxx
Mnigma 15012016
15.1.2016
- Increase compability with OEA type skins, like KravenHD etc.
dpabox Slovakia
kedže inštalácia je časove nenáročná / 5 minút/ nainštaloval som na 2GB microSD kartu. Zistená nepríjemná chyba - nedá sa nahrávať , prehrávať už nahraté súbory na iných verziách E2 pre Wetek.
Mnigma 0.10 potrebuje odstrániť chyby, ktoré mali aj iné verzie E2 pre Wetek vo svojich počiatkoch.
matchboxx píše:Mnigma 15012016
15.1.2016
matchboxx
WeTekPlay MNIGMA-0.1 SDcard 16.01.2016
ke stazeni
http://mnigma.zapto.org/Mnigma/WeTek...116_sdcard.zip
Changelog :
16.1.2016
- E2 misc changes.
- gst misc changes.
- fixed Kodi backup.
- NFS daemon fixes
- new kernel.
Includes latest patches, but for sake of simpler upgrade, held the old name.
Improved DVB playback, notably on 16E and 30W
NOTE: To avoid re flashing, although it IS recommnended, first do a normal on line update thru SW Manager, go to PPanel-Mnigma's Little Helper and choose Kernel Upgrade. Reboot thru Menu.
matchboxx
20.1.2016
- Major rewrite of Enigma-Wetek kernel module. Few items still need fixing. Hopefully soon.
- Reflashing recommended due to the nature of changes. As backup/restore seems to work fine for Kodi and other stuff,
does not seem dramatic.
- As the new image has a sign 'Beware: fresh paint', you might consider waiting a bit, especially if the current image works fine for you.
ke stazeni
matchboxx
22.1.2016
22.1.2016
Low level:
- New kernel drivers E2-wetek
- New AML media libraries
- Probably fixed DVB-T2 problem. 'Probably' as in 'can't test it'.
E2 level:
- Restore of backup fixes some confusion with softcams
- Improved handling of http streams
- Feeds updated
- Some translations
Note: As ever, be aware. This is a rolling release, crucial drivers and libraries were renewed.
This spells; probable benefits as well as possible problems.
On-line update from the last release with the new kernel ist OK.
matchboxx
matchboxx
30.1.2016
Low level:
- New kernel
- New E2 drivers for wetek
- New DVB drivers
E2 level:
- FR, NR, LV translations
- Parental controls
- DVB-C fixes
- AML playback
Reflash recommended, although you could update kernel from PPanel, do not reboot but do update from SW manager, reboot.
matchboxx
31.1.2016
- GR translation
- misc E2 fixes
- skin realted stuff refactored
Zpět na „Odkaz pro stažení firmware Enigma2 a diskuze k firmware“
