Webmedia
Pluginy a utility pro přijímač Clarke-Tech , Xtrend
Webmedia
Enigma2 Plugin Webmedia.v.3
YouTube
DailyMotion
MyVideo
SVTPlay
TurkWebTV
MetaCafe
ClipFish
ZDFMediathek
ARDMediathek
AdultVideo :
YouPorn
PornRabbit
Tube 8
Zltym tlac. - config nastavte priecinok pre vyrovnavajucu pamat. Mozete nastavit aj ci sa ma zastavit stahovanie pri zatvoreni pluginu.
Test v image Open PLi 2.1 - OK.
Thx pcd
Re: Webmedia Enigma2 Plugin
Plugin Webmedia.v4.0
Change log v.4.0 :
Crash (GS) problems corrected.
New sites - Pro 7, TV2dk, NRK-nett
Updated/improved - German sites Rtl, Vox, Sat1, Clipfish
Youtube - Favourites enabled, many more videos (thanks to kalehrl from ihad)
Turkwebtv - urls updated (thanks to niendorfer from turkeyforum.com)
Adult Videos(18+) - Parental Control possible
The following items are included :-
YouTube
DailyMotion
ZDFMediathek
ARDMediathek
Rtl-Now
Vox-Now
Sat.1
Pro 7
MyVideo
TurkWebTV
MetaCafe
ClipFish
SVTPlay
Tv2
Nrk
AdultVideo :
YouPorn
PornRabbit
Tube 8
YoupornAlt
Most videos can be played or cached. Except :
* Play only
** (1) Download - (2) Play
*** Enable Adult Video icon with MENU button. To view - Parental Control PIN required'
**** Vlcplayer required.
Please use MENU button in the first screen to configure cache folder. You can also configure if download should stop at Exit from the plugin.
Downloads will be in folder webmedia inside cache folder. For SVTPlay - the download will be in folder svt inside cachefolder.
If not installed- the plugin will ask for gst-plugin-flv.
Attached is the new version (v7.0) of the plugin Webmedia.
New in this version :-
SuperRTLNow
RTL2Now
DasErste
Oxotube - now plays direct
Updated : RTLNow, VOXNow, Turkweb etc.
The plugin is of different format now (Screenshot 1). All channels are now downloaded as plugins. It makes it easier to add new channels and update existing ones. So - please test and report any problems.
Install Method :-
Telnet command : opkg remove *******-plugin-extensions-webmedia
Check that the folder /usr/lib/*******/python/Plugins/Extensions/WebMedia is deleted.
Ftp the attached plugin to /tmp and telnet command :
opkg install /tmp/*.ipk
Buttons :-
Yellow - Configure plugin
Blue - Install or update plugins
Red - Remove plugins
Green - Select plugin to start.
Plugins available :-
ARD
Clipfish
Dailymotion
DasErste
Kontor
MDR
Metacafe
Myvideo
Nrk
Orf
Pro7
RTL2Now
RTLNow
Sat1
SuperRTL
SVT
Turktube
Tv2
VOXNow
Youtube
ZDF
Adult (18+)
YouPorn
PornRabbit
Bild Erotik
YoupornAlt
Redtube
Xhamster
Oxotube
Some images may not include a required file /usr/lib/python2.6/htmlentitydefs.py. It is attached below. Delete .txt from the name and ftp it to folder /usr/lib/python2.6.
Also - if not installed- the plugin will ask for gst-plugin-flv.
Regards, pcd.
Re: Webmedia_plugin
Plugin WebMedia 8.0
Hi,
Attached is the new version (v8.0) of the plugin Webmedia for OE 1.6 images.
Install Method :-
Telnet command : opkg remove enigma2-plugin-extensions-webmedia
Check that the folder /usr/lib/enigma2/python/Plugins/Extensions/WebMedia is deleted.
Also please install these two attached files (in rtmp_1.6 zip) :-
librtmp.so.0 -> /usr/lib (chmod 755)
rtmpdump -> /usr/bin (chmod 755)
Buttons :-
Red - Exit plugin
Green - Select to start.
Plugins available (hopefully more will be added after checking) :-
Clipfish
Dailymotion
DasErste
Kontor
MDR
Metacafe
Orf
RTL2Now
RTLNow
SuperRTL
Turktube
VOXNow
Youtube
ZDF
Adult (18+)
PornRabbit
Bild Erotik
YoupornAlt
Redtube
Xhamster
Oxotube
Also - if not installed- please install gst-plugin-flv.
Openpli-2.1 based images
enigma2-plugin-extensions-webmedia_8.0_1.6_all.ipk
Openpli-3 based images
enigma2-plugin-extensions-webmedia_8.0_all.ipk
Re: Webmedia_plugin
WebMedia 8.1 for Openpli 3
NEW
Many sites updated. Myvideo with Sat1 and Pro7 Serien added.
New design first screen - many thanks to @CoolST for the icons.
PLUGIN METHOD
General:
Check that the file /usr/lib/gstreamer-0.10/libgstflv.so exists. Otherwise install gst-plugin-flv.
Page 1 is shown in Pic1. Scroll down for Adult in page 2.
WebMedia config:
At Page 1 - press yellow button for config screen Pic2. If you want video downloading to continue after exit from plugin - select No in "Stop download....". Configure cache folder. Select Yes to watch Adult videos.
Adult:
To watch Adult videos - select Yes in webMedia config screen. Also at start of Adult channel - enter the Parental key (or select No in Menu->Setup->Parental control).
Youtube :
Configure screen shown in Pic3. If a video is not working - lower the picture quality. All youtube videos are not in the hd quality.
Youtube, Dailymotion, ZDF, MDR, Metacafe, Kontor, Turktube, Bild, Clipfish, Adult:
After selecting a video - you see options as in Pic4. Download is optional. You can either Play the video or Download.
DasErste, RTLNow, RTL2Now, SuperRTL, VOXNow, Myvideo, Orf:
After selecting a video - you see options as in Pic5. Here you must (1) Download then (2) Play.
When you select Download - you see a screen like Pic6. If you see "In Progress" it is working ok. If not the video is not available. if you see "Waiting" - another video is downloading.
If you see "In Progress" - press Blue button to continue downloading. You then go back to Pic5 screen. Now you can Stop Download or Exit the plugin and watch tv while downloading the video.
INSTALL METHOD
Also please install these two attached files (in rtmp.zip) :-
Buttons :-
Red - Exit plugin
Clipfish
Dailymotion
DasErste
Kontor
MDR
Metacafe
Myvideo (with Sat1, Pro7 serien)
Orf
RTL2Now
RTLNow
SuperRTL
Turktube
VOXNow
Youtube
ZDF
Adult (18+)
PornRabbit
Bild Erotik
YoupornAlt
Redtube
Xhamster
Oxotube
thx pcd.
WebMedia 8.1 for Openpli 2 and XT v5.0
NEW
PLUGIN METHOD
General:
WebMedia config:
Adult:
Youtube :
INSTALL METHOD
Buttons :-
Red - Exit plugin
Clipfish
Dailymotion
DasErste
Kontor
MDR
Metacafe
Orf
RTL2Now
RTLNow
SuperRTL
Turktube
VOXNow
Youtube
ZDF
Adult (18+)
PornRabbit
Bild Erotik
YoupornAlt
Redtube
Xhamster
Oxotube
thx pcd.
Re: Webmedia_plugin
WebMedia 9.0 for Openpli 3.0
webmedia_9.0_oe2.0
Re: Webmedia_plugin
WebMedia 9.2 Update for the Festive Season
New update WebMedia 9.2 update 20121211 for Openpli-3 images
Includes :-
 Myvideo.de Top 100 Categories
 Karaoke channel
 Seasonal Greetings
NEW v.9.2_r0
 New version attached.
 New items :-
 SF (needs python-simplejson - attached)
 DMAX (needs pyamf - attached)
 Arte.Fr
 RAI.It (needs vlcplayer - attached- works with vlc 2.0.2)
 Balkanika
 MelodyArabia
 MusicItalia
 Clipfish - patched
 Playlist action for DMAX and Youtube user-bouquets
 Oxotube fixed (needs vlcplayer - attached- works with vlc 2.0.2)
 The channel list can be changed (change order or number) in plugin.py.
 List :-
 Youtube
 Dailymotion
 ZDF
 DasErste
 BR
 WDR
 MDR
 RTLNow
 RTL2Now
 SuperRTL
 VOXNow
 Pro7
 Sat1
 Sixx
 Kabel1
 MUZU
 Metacafe
 Kontor
 Turktube
 Orf
 Clipfish
 SF
 DMAX
 ARTE.Fr
 RAI.It
 Melody
 MusicItalia
 Balkanika
 Adult(18+ Parental PIN)
 -PornRabbit
 -Bild Erotik
 -YoupornAlt
 -Redtube
 -Xhamster
 -Oxotube
 @skinners - now you can mod Webmedia screens is in skin.xml.
 Requires gst-plugins-good-flv.
Update 20121102
 New ZDF.pyo attached.
NEW v.9.1_r1:
 Attached below. Ftp -> /tmp and telnet command opkg install /tmp/*.ipk
 Non-working channels working.
 New channel Kabel1
 Errors corrected.
thx pcd
Re: Webmedia
Plugin WebMedia 10 for Openpli-3
- pre imgs oe2.0
Zpět na „Clarke-Tech , Xtrend Pluginy a utility“
