fw 1.09.35
fw 1.09.35
Ver 1.09.35
Common Issue
1. fdu & plugin files server upgrade (fdu only currently) : Supported
2. ST codec MP3 Player : Supported
3. Mosaic screen broken issue : Amended
4. Press recall key during booting display "Run..." mode : Deactivate plugin Auto Start
HD 7xxx & 8xxx
1. Play YouTube video : Available
2. Persian TTX : Added
3. Can not reverse font color in the specific menu with OSD color 2 : Amended
<Free TV+>
1. Free TV+ bugs : Amended
- Change Youporn's parental control default : Amended (default is Lock)
- Download status bar disappearing when changing full screen : Amended
- Hang up intermittently when moving cursor in downloaded video list: Amended
- Initializing setting value after installing addon : Amended
- Setting Pop-up window broken : Amended
- Can not renewal the screen : Amended
- Showing the message box if Free TV+ is not access network : Added
- Disappearing the cursor in the movie list : Amended
- Hang up when changing the service SVT to Youtube : Amended
- Screen Resoultion : Supported
- Information for movie duration : Supported (if available)
- Showing up the message if there is any proper storage : Added
- Changing only full screen enlarged over the PIG during PIG movie play if press the V.FORMAT button : Amended
- Fashion TV added : Added
- Metacafe content : Available to add
- Hang up when choosing F parties category in Fashion TV service : Amended
- List up only 4 when choosing the specific category in YouTube service : Amended
- Hang up when changing specific category in Fashion TV
- letter is disappeared when user inputs the wrong PIN code : Amended
- Setting OSD boards are blinded with more than 7 server list : Amended
- PIG screen crushed with not complete download contents : Amended
2. Addon Version : Updated
- Working with only v1.01
- Addon should be installed newly and previous version will not be working
** Addon works with only compatible Free TV+ version. If incompatible version of addon is installed with Free TV+, it will not be updated on the addon list.
9300 :arrow: Tu klikni pre stiahnutie
9200 :arrow: Tu klikni pre stiahnutie
dpabox Slovakia
fw 1.09.35 / doplnky
Příspěvek od dpabox »
Fw nainstalovany bez zjavnych problemov. Box mam pripojeny na internet .... modre tlacitko v doplnkoch nie je funkcne. Platia doplnky, ktore boli zverejnene pre 9105 aj pre 9200 ? / Free Tv+ addony / alebo to bude riesene inak ? Vdaka
Re: fw 1.09.35
Len pre 9105
SuiVanOrton
Re: fw 1.09.35
Příspěvek od SuiVanOrton »
Má to smysl tenhle fw zkoušet ???
A funguje to vůbec, co to přepínání programů co nefungovalo v předchozí verzi ???
HD-BOX 9200, karta Skylink (Irdeto výměna)
HDD Samsung Story Station Plus 1TB (připojeno přes eSata)
TV Panasonic TX-L42E30E
Re: fw 1.09.35
Příspěvek od marsim21 »
HDBox tovární nastavení přijímač vyčištěný utilitou HDBClean. Opět tovární nastavení.Vytvořený nový setting poskládaný dle představ,až poté nainstalovaný plugin Xcam.Přijímač zatím šlape jek hodinky.První pozice settingu zatím také OK.Žádná hláška zakódováno. :87:
gombi
Re: fw 1.09.35
Příspěvek od gombi »
marsim21 píše:HDBox tovární nastavení přijímač vyčištěný utilitou HDBClean. Opět tovární nastavení.Vytvořený nový setting poskládaný dle představ,až poté nainstalovaný plugin Xcam.Přijímač zatím šlape jek hodinky.První pozice settingu zatím také OK.Žádná hláška zakódováno. :87:
Môže byť aj Mcas??? Dík G.
Openbox X-770CIPVR
Re: fw 1.09.35
Môže. Najlepšie posledný
gombi
Re: fw 1.09.35
dempsey píše:Môže. Najlepšie posledný
Ďakujem vyskúšam. G.
Openbox X-770CIPVR
Jerry973 Slovakia
Re: fw 1.09.35
Příspěvek od Jerry973 »
No dnes idem do toho, som zvedavy, co nam majstrovia nachystali ...
HD-BOX 9200
Old Master
Re: fw 1.09.35
Příspěvek od Old Master »
fw 1.09.35/MCAS z 14.7.
Tak a je to tady znova!
Na první pozici (program zakodován) :107:
dym1 Slovakia
Re: fw 1.09.35
Příspěvek od dym1 »
To vam potom robi mcas alebo nepouzivate favoritne ulozene programy.Ja pouzivam oscam alebo xcam a este sa mi to nestalo,takze fw to nebude.
Old Master
Re: fw 1.09.35
Ten OSCAM bych taky rád použil.Naposledy 3/4 roku zpátky jsem jej používal ale dnes je v něm hotovej guláš.A už jsem zapoměl konfiguravat.
Potřebuji pro horní čtečku 0D70(Skylink-modrá) a spodní 0D03(TandT).Většinou je všude paskvil pro 0D96 (ICE Skylink).
Jsem už z toho opravdu dost otrávenej a uvízl jsem na MCASu :57:
gatecomputers
Re: fw 1.09.35
Příspěvek od gatecomputers »
Uz druhy den testuji novy firmware a zatim OK - zakladni funkce - s oscamem bez problemu, prepinani rychle, zadne sekani ... myslim, ze se da vcelku dobre nasadit a pouzivat
prco007
Re: fw 1.09.35
Příspěvek od prco007 »
Ako to vyzera so stabilitou tohoto fw? Mozem nan prejst aj z v1.08.44?
Bude treba menit aj loader alebo sa zmeni sam pri zmene fw?
HD-BOX FS-9100 - fw v1.10.13
7andy7
Re: fw 1.09.35
Příspěvek od 7andy7 »
Zdravim,
na FS 9200 som isiel updatnut tento fw, vymazal Var backupol vsetko, cisty start, zabudol som Facory reset,
po flashi sa box rebootuje - maxiboot - flash - booting.
nepodarilo sa mi ho flashnut cez aaf recovery - ked sa pripojim na serial, recovery tool spadne
porter sa ani nechyti - waiting for request
putty vypisuje hovadiny:
ü4·jHJ 9XÞwðIø8C¤èùÿ7öøàá
òC,¤Ì+÷½yÝ?º/MnÄö¤¼^YBçí8C%McKpâT/þL¬q|¶ZicSfZ7ùkz<Râÿb
BTBB\
ë¤Íiø8BUöÿÿ7öøàíW ßCXÂýRöÒÙ/ºkæ3©hóSéGJ
öøû.×±BiLkcjæq
qbªghbQÂ3ÿ4ÏÅLbeâegðIø8Býýÿn3ÃÂï%ÅRÄÞ¬¯c» ý¢yf¦÷¦¿SNB}o2v®:Ç
û¦çgÎþL¬q|¶ZicSf^7
óÅJBHâÿb*ãSC¤OÚìïÇÿiø8BUöÿ2ö6þ
any ideas? pomooc
Andy
