fw 1.09.20
fw 1.09.20
--> Plugin is capable to download from one's web server
--> Menü - Utilities - Plugin : Blue Button - Download
--> Server URL : Menu - Installation - Network Setting : Firmware upgrade Server
--> Multipicture mosaic funtion bug : Amended (Blue Button)
--> Blind Scan search wrong : Amended
--> Duplicated channel or other bugs in Blind scan : Solved
--> Sky portal CH problem : Solved
--> Hang-up when make 10 min pause during playback rec file : Solved
--> EPG Daily Recording Bug : Solved
--> Working Screen saver during Radio service playback : Solved
--> Can not delete specific Rec file Bug(file name include / or special character) : Solve
--> Unstable Signal Quality : Solved
--> Background black issue in the info Banner's event name : Solved
--> Recording name saved as previous event name in event scheduled recording : Solved
--> Hang-up issue after Factory reset : Solved
--> Hang-up by Data Transfer Menu : Solved
--> When changing service up/down, loop supported in one tuner : Supported
--> Logical channel number (LCN) function off : Amended
--> Audio click noise : Solved
--> Lost descramble in Recording of the specific channel : Solved
--> Can not Recording in Service nemed in Turkish : Solved
--> Service find option in Service list manager : Added (Yellow Button)
--> Menu display spilit or broken : Solved
--> Screen Turns into Black&White in Resolution change mode : Solved
--> Flickering and spot in the screen with Scart in Resolution change mode : Solved
--> 2hours before EPG DATA screened out once open the EPG DATA stored in HDD : Solved
Pozor: Pred aktualizáciou zastavte všetky spustené pluginy v menu a po aktualizácii urobte továrenské nastavenie
http://reviservis.sk/fw/9200/FAC.HD%20B ... 1Jun17.ird
http://reviservis.sk/fw/9300/FAC.HD%20B ... 1Jun17.ird
- SuiVanOrton
Re: fw 1.09.20
Tak jsem ho zkusil nahodit a hned první poznatek ... problém "zakodovanej program na první pozici" v podstatě pořád, zkoušel jsem vypnout a zase zapnout, pustítm to, mcas jede, čt1 (na první pozici) jede přepnu někam jinam a zase zpět a už je zakodovanej a mám po čt1.
Update: zkusil jsem to vypnout úplně zadním vypínačem, nechal jsem to chvilku a zase zapnul a už to běží .... tak snad to bude o.k.
HD-BOX 9200, karta Skylink (Irdeto výměna)
HDD Samsung Story Station Plus 1TB (připojeno přes eSata)
TV Panasonic TX-L42E30E
vokrinek
Re: fw 1.09.20
mám stejnej problém .. ale už to bylo i u fw 1083 a 10909. Zapnu přijímač, a program je zakodován, stačí restartovat. Nejlepe to vyřešilo, když jsem dal modul. Ale ve čtečce jsou problémy. Ted mám 10909 a mcas poslední. Dokud jsem nepoužíval mcas, např fw 10844, tak vše šlapalo.
Re: fw 1.09.20
do auroun.sh si uprav start mcasu . pridaj pred prikaz sleep 5
Re: fw 1.09.20
Ak budete na 9200 a 9300 testovat nahravanie HD programu a sledovanie ineho hd programu, tak pred vyslovenim nespokojnosti si skontrolujte rychlost zapisu na disk ! - ci vobec umoznuje cosi take. V spravcovi zariadeni a test rychlosti. tam presne vypise moznosti Vasho datoveho uloziska.
vokrinek
magi
Re: fw 1.09.20
Zdravím všetkých. Prosím o pomoc. Pred dvomi hodinami som nahral nový FW 1.09.20 do HD 9200 pomocou USB./predtým som pozastavil OSCAM/.
Prijímač štandardne nainštaloval FW, zapísal FW na 100%, ale po reštartovaní sa "zasekol". Na displeji mi stále svieti
LOADER 1.19 a HDBOX už nereaguje na nič. Skúšal som ho aj viac krát odpojiť zo siete, ale stále sa dostane iba po ten
istý LOADER...HDBOX mám už dva roky, ale toto sa mi ešte nestalo.
- tulino
Re: fw 1.09.20
edituj vo vhodnom programe subor autorun.shvokrinek píše:jak ?grantec píše:do auroun.sh si uprav start mcasu . pridaj pred prikaz sleep 5
vysledok ma byt nasledovny:
sleep 5
var/bin/Mcas.
- tulino
Re: fw 1.09.20
ak si uz skusil vsetko na ozivenie, tak potom - sekcia RADY A NAVODY - nie je tu zbytocne:magi píše:Zdravím všetkých. Prosím o pomoc. Pred dvomi hodinami som nahral nový FW 1.09.20 do HD 9200 pomocou USB./predtým som pozastavil OSCAM/.
viewtopic.php?f=166&t=6834
fefe88
Re: fw 1.09.20
Problem je v tom, ze mas stary LOADER a novy FW potrebuje LOADER 1.54. Aby si sa ukludnil, pokus sa o jednoduche riesenie:magi píše:Zdravím všetkých. Prosím o pomoc. Pred dvomi hodinami som nahral nový FW 1.09.20 do HD 9200 pomocou USB./predtým som pozastavil OSCAM/.
1) Na cistu USB flashku si nahraj starsiu verziu FW (napr. 1.09.09).
2) Vypni BOX vzadu vypinacom
3) Do USB portu vloz flashku s FW
4) Na prednom panelu drz tlacitko CH UP a zapni BOX zadnym vypinacom
5) Na displeji za zobrazi myslim USB SCAN az potom mozes pustit CH UP
6) Prebehne vymazanie stareho a nahratie FW z kluca
7) Uspesne nahratie prebehne blikanim INSTALL COMPLITE
8) Mozes vypnut BOX
Malo by to zabrat, inak budes musiet pouzit krizeny RS232 kabel.
Zajtra poradim, ako jednoducho upgradovat na novy LOADER a nahrat novy FW.
- tulino
Re: fw 1.09.20
Mam sice Octagon, ale stary loader 1.19 a bez akychkolvek problemov som 1.09.20 (pre moj Octagon) naistaloval a na prvy krat
Na nemeckom fore to riesili, nedosledoval som to, ale posledne co som videl bolo, ze to nefunguje na maxiboote a niekto spominal aj preflashovane boxy na ine ID
a spominali chyby ERR 0x71 aj na loaderoch 1.23 aj 1.52
Mozno zhoda nahod, mozno ochrana pred Anakundami :-)
Re: fw 1.09.20
treba pouzit starsiu verziu Maxiuboot - tam to funguje - pozuivam stary boot a ide na nom aj novy fw.
kury32
Re: fw 1.09.20
Ahoj grantec. Tak se musím, také připojit a napsat tady, že mám ten samí problém: u nahrávek dvou programů a přepnu někam jinám, opak se vrátim tak se mi už nezobrazuje obraz. ( program je zakodován ).
Firmware mám 1.09.09 tip 9200 pvr. Skoušel jsem i ten postup:
var/bin/autorun.sh - upravit.
1 /sleep 5
2 /var/bin/Mcas
3 /var/bin/coconut
Je to správně? Dík za pomoc, kury32.
1 /sleep 5
2 /var/bin/Mcas
3 /var/bin/coconut
kury32
Re: fw 1.09.20
Nemůžu si pomoci, ale stále chyba přetrváva i po upravě. Tak jak jsem to nahoře uvedl.kury32.
roboton2
Re: fw 1.09.20
Takze pluginy sa daju stahovat uz priamo cez internet modrym tlacitkom... Nastavuje sa niekde URL na to, alebo sa to da len z tej, ktora je nastavena na stahovanie noveho fw?
Aka je syntax a struktura adresarov na nahratie pluginov na server?
dik
dik
