Xcam pre fw 1.08.75 a vyšší
- update : XcamClient & XcamConfigure
--> Adjustment tp Plugin API v1.05
--> Please use SW V10875 !
--> CONAX bug fix.
--> CONAX bug fix.
Re: Xcam pre fw 1.08.75 a vyšší
--> Stability imporved
--> Minor bugs fix.
--> Xcam.prio imporved
--> DRE (drecrypt) adjustment
--> Minor bugs fix.
--> Seca- Mediaguard bug fix.
--> Viaccess bug fix.
--> Plugin API V1.07 (V10894)
- security check error problem fixed
--> Small bugs fixed
--> Prio function improved
--> Cccam imporved
--> Cccam imporved
--> Timeshift improved
--> Trick Mode improved
--> Minor bugs fix
--> Minor bugs fix
úprava pre API 1.10 - používajte vo fw 1.09.35 a vyššom
--> 0 Button bug fix.
--> Pls use with SW min. V10935 or higher version !
--> Font problem fix.
--> When setting auto start in live mode - no text displayed in xcam infobar (bug fix.)
--> Button "0" Function in Live TV Mode improved
--> ignore.list support add. (/etc/ignore.list)
--> Example file add. : (/var/etc/CCcam.cfg)
--> Example file add. : (/var/keys/newcamd.list)
--> Adaption to Plugin API 1.12
--> Plugin Priority up
--> Minor bugs fix.
--> Minor bugs fix.
--> Tricolor improved
--> DreCrypt improved
--> Cryptoworks improved
--> Minor bugs fix.
--> Enter C line PW : 0000
--> Minor bugs fix.
