dm 500S cccam+newcs server
- dzambo2302
ahojte , nemá niekto skúsenosti s dm 500s nastavením duálneho servera cccam a newcs ? , cccam som si nastavil a dal som režim addonov cccam2.0.11+newcs1.XX a cccam ide jak švajčiarske hodinky , ale zato newcs , ked dám do browsera ip: 192.168.2.101:1001 tak ako keby aj niečo chcelo naskočit , ale nenaskočí , vyzerá to ako keby sa zacyklil ...
Neviete mi niekto pomôct , ako to dotiahnut do konca ? :)
a Samozrejme mi nečíta kartu ...
- dzambo2302
Re: dm 500S cccam+newcs server
skúšal som sa riadit týmto návodom http://www.sat-television.com/showthrea ... e-a-server , ale čítačku ani newcs som stále neoživil
Spusť v DCC telnet a napíš ps
Potom enter a skopíruj to sem
Inak port v tom newcs nebude 1001 ale 8080
- dzambo2302
PID  Uid     VmSize Stat Command
1 root 540 S init
2 root SWN [ksoftirqd/0]
3 root SW< [events/0]
4 root SW< [khelper]
5 root SW< [kblockd/0]
6 root SW [pdflush]
7 root SW [pdflush]
9 root SW< [aio/0]
8 root SW [kswapd0]
10 root SW [cifsoplockd]
11 root SW [cifsdnotifyd]
12 root SW [mtdblockd]
14 root 540 S init
15 root 552 S /bin/sh /etc/init.d/rcS
23 root SW< [fe_thread]
32 root SWN [jffs2_gcd_mtd1]
55 root 592 S /sbin/inetd
150 root 444 S /bin/gdaemon
151 root 12532 S /bin/enigma
152 root 12532 S N /bin/enigma
160 root 12532 S /bin/enigma
184 root 12532 S N /bin/enigma
187 root 12532 S /bin/enigma
250 root 12532 S N /bin/enigma
203 root 516 S /bin/udhcpc --hostname=dreambox --foreground
360 root 2132 S /var/bin/newcs_1.66
361 root 2132 S /var/bin/newcs_1.66
362 root 2132 S /var/bin/newcs_1.66
363 root 2132 S /var/bin/newcs_1.66
370 root 1964 S /var/bin/CCcam_2.0.11
371 root 1964 S /var/bin/CCcam_2.0.11
372 root 1964 S /var/bin/CCcam_2.0.11
373 root 1964 S /var/bin/CCcam_2.0.11
374 root 1964 S /var/bin/CCcam_2.0.11
375 root 1964 S /var/bin/CCcam_2.0.11
376 root 1964 S /var/bin/CCcam_2.0.11
377 root 1964 S /var/bin/CCcam_2.0.11
378 root 1964 S /var/bin/CCcam_2.0.11
481 root 416 S telnetd
482 root 692 S -sh
483 nobody 764 S in.ftpd
486 root 864 S in.ftpd
487 nobody 764 S in.ftpd
489 root 808 S in.ftpd
492 root 632 R ps
root@dreambox:~>
						1 root 540 S init
6 root SW [pdflush]
7 root SW [pdflush]
9 root SW< [aio/0]
8 root SW [kswapd0]
14 root 540 S init
482 root 692 S -sh
492 root 632 R ps
root@dreambox:~>
Takže newcs Ti beží. Skúsil si dať do prehliadača port 8080 ?
http://192.168.2.101:8080
- dzambo2302
- dzambo2302
newcs beží , ale kartu mi nečíta ... nebude to tým že si nevie inicializovat kartu ? ... mam staru T&T skylink CAID: 0D03
						- dzambo2302
Takýto je môj newcs.xml :
<?xml version="1.0"?>
For setup-issues, look in readme.txt!
If there are other troubles, try different forums or irc channels around :o)
The configfile are NOT case-sensitive, and shouldnt care about dos/unix cr/lf.
** This is the example file for Dreambox/TD etc. that use SCI interfaces.
<newCSconfig>
<readers name="Card Readers">
<device>
<name>lower</name>
<type>sci</type>
<mhz>500</mhz>
<node>/dev/sci0</node>
<parity>odd</parity>
<reset>normal</reset>
<export>Yes</export>
<enabled>Yes</enabled>
<blocksa>No</blocksa>
<blockua>No</blockua>
<blockga>No</blockga>
<!-- <boxkey>0000000000</boxkey> -->
<!-- <rsa>0000000000</rsa> -->
<irdeto-camkey>0000000000000000</irdeto-camkey>
<irdeto-camkey-data>000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000</irdeto-camkey-data>
<crypto-special>No</crypto-special>
<ipk>000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000</ipk>
<ucpk>00000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 000000000000</ucpk>
<PTShandshake>No</PTShandshake>
<carddetect>yes</carddetect>
<newcamd_port>34000</newcamd_port>
<autosid>Yes</autosid>
<Seca-PPV>no</Seca-PPV>
<pincode>0000</pincode>
<priority>round</priority>
</device>
</readers>
<radegastserver>
<enabled>No</enabled>
<port>16000</port>
<allow>
<hostname>localhost</hostname>
</allow>
</radegastserver>
<cache>
<emm>20</emm>
<ecm>-1</ecm>
</cache>
<httpd>
<server> <!-- Port to accept connections on -->
<port>8080</port>
<enabled>no</enabled>
</server>
<user>
<!-- valid value for userfile are:
Any username you'd like - Used for browser to logon (its case sensitive). -->
<name>username</name>
<!-- valid value for password are:
Any password you'd like - Used for browser to logon (its case sensitive). -->
<password>password</password>
<!-- valid value for accesslevel are:
admin, stats - Define what rights the user has in the web-console -->
<accesslevel>admin</accesslevel>
</user>
</httpd>
<debug>
<level>normal</level>
<type>init</type>
<output>console,tcp</output>
<console_options>normal,init</console_options>
<tcp_port>1001</tcp_port>
<tcp_options>normal,init</tcp_options>
</debug>
<newcamdserver>
<name>newcs</name>
<deskey>01 02 03 04 05 06 07 08 09 10 11 12 13 14</deskey>
<user>
<name>client1</name>
<password>password1</password>
<port>34000</port>
<au>on</au>
<sidoverride>on</sidoverride>
<spider>yes</spider>
<rate>2</rate>
</user>
<user>
<name>client2</name>
<password>password2</password>
<port>34000</port>
<au>on</au>
<rate>2</rate>
</user>
<user>
<name>client3</name>
<password>password3</password>
<port>34000</port>
<au>on</au>
<sidoverride>off</sidoverride>
<spider>No</spider>
<rate>2</rate>
</user>
<user>
<name>Client4</name>
<password>password4</password>
<port>34000</port>
<au>on</au>
<spider>No</spider>
<rate>2</rate>
</user>
<user>
<name>client5</name>
<password>password5</password>
<port>12000</port>
<au>on</au>
<spider>No</spider>
<rate>2</rate>
</user>
</newcamdserver>
</newCSconfig>
<newCSconfig>
<device>
<name>lower</name>
<type>sci</type>
<mhz>500</mhz>
</device>
</readers>
<radegastserver>
<port>16000</port>
<allow>
</allow>
</radegastserver>
<cache>
<emm>20</emm>
<ecm>-1</ecm>
</cache>
<httpd>
<port>8080</port>
</server>
<user>
</user>
</httpd>
<debug>
<type>init</type>
</debug>
<newcamdserver>
<name>newcs</name>
<user>
<port>34000</port>
<au>on</au>
<rate>2</rate>
</user>
<user>
<port>34000</port>
<au>on</au>
<rate>2</rate>
</user>
<user>
<port>34000</port>
<au>on</au>
<spider>No</spider>
<rate>2</rate>
</user>
<user>
<port>34000</port>
<au>on</au>
<spider>No</spider>
<rate>2</rate>
</user>
<user>
<port>12000</port>
<au>on</au>
<spider>No</spider>
<rate>2</rate>
</user>
</newcamdserver>
</newCSconfig>
- dzambo2302
problem vyriešeny :) , siahol som na nesprávny návod , keď som obnovil pôvodny súbor všetko ide ok :)
