Prosím o kontrolu mg_cfg
PetrT30 Czech Republic
Příspěvek od PetrT30 »
Server: newcs - IPBox 250 s kartou Skylink (0D03)
Klient: mgcamd - HDBox 9200
Domnívám se, že mám asi blbě nastavený mg_cfg. Po pár minutách na CT HD se kousne. Z kraje se kousne jen program, ale pokud to nechám déle puštěny na tom programu tak zamrzne celý box.
FW mám nejnovější (1.08.31)
# EMM messages
#    00 don't show any EMMs (default)
#    01 show only valid EMMs
#    02 show valid and bad EMMs with complete data display
M: { 01 }
# ECM messages
#    00 don't show anything about ecm
#    01 normal mode, show pids processed, decoded ecm and cw
#    02 verbose mode, show valid and bad ECMs with data
C: { 01 }
# AU
#    00 disable, no emm pids processed
#    01 enable, emm pids always processed for soft-au and shared cards
#    02 auto, emm started only if channel cant be decoded
#    03 process emm pids for network cards update only
A: { 00 }
# key update (sum 01 or 02 with 04)
#    01 update only new keys, default setting
#    02 update all keys (used for valid PMK checking)
#    04 enable TPS au
#    + tps au pid
U: { 02 }
# config files folder (softcam, autoroll, ignore/priority)
#    00 files in /var/keys
#    01 files in /tmp
T: { 00 }
# network mode, use summ for several clients
#    00 no network (default)
#    01 newcamd netclient
#    02 radegast netclient
#    04 camd3 netclient
#    08 gbox netclient
#    32	cccamd netclient, card list saved as /tmp/cccamd.info
#    	(ECM only, supported server version up to 2.1.1, later not work)
G: { 33 }
# network retry, use summ for several options
#    00 disable
#    01 retry every new ecm
#    02 try to connect to offline shares every Q: seconds
#    04 try to detect and fast reconnect to lost (and not used atm) server
#    + XX messages number and YY seconds to reconnect
#    mg will reconnect to server, if no answer to last XX ecm/keepalive or
#    if no answer for last ecm or keepalive sent for YY seconds
#    set to 0 to disable
#N: { 01 } 5 30
# network ecm timeout in seconds
K: { 05 }
# newcamd dead routes connect retry, sec
Q: { 600 }
# network shares priority
# 00 gbox, newcamd, cccamd, radegast, camd3 (default)
# 01 camd3, radegast, cccamd, gbox, newcamd
# 02 cccamd, newcamd, camd3, gbox, radegast
P: { 00 }
# on screen display type
#    00 No OSD (default)
#    01 neutrino
#    02 enigma
#    03 relook
#    + user password for http auth
O: { 00 } root newcs
# on screen display Options, summ of:
#    01 show emu ecm
#    02 show network shares messages
#    04 show decoding failed / fta
#    08 show emm keys update
#    + web port to use for osd
S: { 01 } 8080
# Log option, summ of:
#    00 off
#    01 network udp log
#    02 log to console
#    04 file, appended ! delete it by yourself, before it eat all your hdd
#    + IP udp-port log-file-name
L: { 01 } 127.0.0.1 28007 /tmp/mgc.log
# keep ecm cache, seconds
# every cache entry takes 28 bytes, so 24h cache will take *only* 240-400kb of memory,
# for openbox/elanvision users with remote shares make sense to set it higher than default value,
# to not hammer cards while timeshifting or playing crypted recordings.
E: { 15 }
# cache option, summ of:
#    00 Off (default)
#    01 Ecm pids cache, store pids used to decode in /tmp/ca_cache.list at exit, load at startup, same syntax as restore.list
#    02 Ecm data cache, remember CW for (E:) time
#    04 Emm cache for network cards, do not resend the same emm twice, cache not cleared until restart
H: { 02 }
# reread files, summ of:
#    00 No (default)
#    01 reread config file on channel change (including priority and ignore, but not replace/cache)
#    02 reread SoftCam.Key on channel change
#    04 reread SoftCam.Key if file changed
R: { 04 }
# debug, summ of
# 00 off (default)
# 01 debug ecm
# 02 debug emm
# 04 debug network ecm
# 08 debug network emm
# 16 debug network login
# 32 show mem/cpu stats every 1 min
# 64 add timestamp to log messages
D: { 00 }
# box type
# 00 autodetect, change only if you think wrong type detected.
# 01 dbox2
# 02 dreambox
# 03 triple-dragon
# 04 relook
# 05 openbox
# 06 dreambox/mips
# 08 stapi/kathrein
# 09 stapi/ipbox
# 11 stapi/openbox
B: { 12 }
# map all 180x nagra caids to 1801
# default is 01
F: { 01 }
AZBox Premium-E2
Re: Prosím o kontrolu mg_cfg
jasne - server je newcs alebo cccam ?
Pisu vyse server newcs. Tak teda newcs!
AZBox Premium-E2
to je mozne, ja zas vsetko necitam - zblaznil by som sa.
G: { 01 }
A: { 02 }
a logovanie si vypni -aj tak to nepouzivas (v logu by si videl presne v com je chyba) a zbytocne obsadzuje pamat.
L: { 00 } 127.0.0.1 28007 /tmp/mgc.log
a nezabudni si do ignore.list dat nagru na UPC - myslim ze 1815 ? neviem- kukni v ecm logu (je v /tmp/)
Díky.
V tempu ignore.list (HDBox) nemám a není ani ve var/keys.
Ve var/keys jsem našel jen priority.list, který mám takto:
V: { 02 07 10 }
#X: { 0D 0F }
X: { 0D 03 }
#X: { 0D 70 }
#X: { 0D 00 }
#X: { 0D 02 }
AZBox Premium-E2
jasne, tak si potom v priority odkomentuj 0D02 - mas to zakomentovane.
takto:
V: { 02 07 10 }
#X: { 0D 0F }
#X: { 0D 03 }
#X: { 0D 70 }
#X: { 0D 00 }
X: { 0D 02 }
onisud
Příspěvek od onisud »
grantec píše:jasne, tak si potom v priority odkomentuj 0D02
Ak mas kartu 0D03, tak by som skor odkomentoval tu ... Podla mna si to mal dobre, ci to zle chapem ?
presne - vedla som odpovedal an UPC , preto som mu UPC napisal. Takze to mal dobre. Problem je, ze davno zname veci sa tu teraz pretriasaju . Pri zdielani treba pouzivat mozog. Nic ine netreba. Zdielanie nepojde, kym dva mesiace nebude studovat. :)
onisud
Ja teraz testujem ako klienta HD box 9100 s mgcamd na server newcs postaveny na DM500, zatial to vraj vypadlo iba raz, mam tam v mg_cfg oproti tu zverejnenemu myslim este tieto nastavenia:
N: { 07 } 5 30 (treba odkomentovat), K: { 00 }, P: { 02 }, H: { 07 } ... treba skusat, mozno zaberie.
Priority a ignore list neviem teraz porovnat, myslim ale, ze v ignore som mal 0624, 0D70 aj 0D96.
To nastavení pro UPC jsem ignoroval, jelikož jsem tušil, že grantec čte mezi řádky :106:
Nicméně je dobré to sem napsat kdyby se na UPC někdy přecházelo.
Díky.
AZBox Premium-E2
Jsem z toho nějakej zmatenej :92:
Pokud použiju toto nastavení v local sítí jede vše OK. Box máká bez sebemenšího zaváhání celej , přepínání v poho - no prostě se chová jako ideál.
Jenže:
Stroj odenesu "ven", zapnu a box nepravidelně (dost často) zamrzá a píše zakódováno snad i na free programech.
Mám podezření na setting, nebo nastavení antény, jelikož doma mám jen jen JEDEN koax do JEDNOHO tuneru - koax => diseqc => 2x LNB.
"Venku" to je jinak - 2x koax do OBOU tunerů => diseqc => 3xLNB.
Může to být také špatně nastaveným sdílením, ale nevím. To se mi zdá OK. Pro kontrolu dávám výpis s newcamd.list.
mg_cfg jsem dal výše.
V priority.list jsem ZAkomentoval vše kromě 0D03, což odpovídá skutečnosti.
CWS_KEEPALIVE = 20
CWS_INCOMING_PORT = 12000
CWS = gorogoro.dyndns.org 10001 jmeno heslo 01 02 03 04 05 06 07 08 09 10 11 12 13 14
Port je dobře (vyčteno z newcs.xml).
Co je to CWS_KEEPALIVE ? Mám nechat 20?
Co může být ještě příčinou, že v localu jede share OK a "venku" ne?
AZBox Premium-E2
ping z vonku ? aku mas priemernu hodnotu ?
z mobilu: AVG 344ms.
Od "klienta" jsem zatim nezkousel.
AZBox Premium-E2
hroza.
Takže jsem se po delší odmlce dostal k tomutu přístroji. Stále jde jen pár vteřin.
Ping z místa kde je HDBox je kolem 100. Což není bůhvíco, ale myslím, že by mělo stačit.
Jen pro připomenutí:
Klient je mgcamd, mg_cfg + priority.list jsem popsal výše a myslím, že jej mám správně (karta 0D03). Server je NewCS
Na co se ještě zaměřit?
AZBox Premium-E2
