fw 1.08.26
tommix Slovakia
fw 1.08.26
Příspěvek od tommix »
http://www.sapro.cz/ftp/index.php?PHPSE ... ory=HD-BOX
Changes :
- STB hang-up when aging fix.
--> SSeveral optimisations in main SW !
- No signal when AC power Off/On fix.
- Move finction problem in service list manager fix.
- Timer : UI when setting the timer and if duplicate with the previous timer - Improved
- New Function in Timer Settings Menu :
--> Menu - System Tools - Timer Setting : Blue Button - Delete All
- Playlist (Playback) EPG Info durch INFO Taste
--> [INFO] button excute in recording file - improved : EPG, Time & REC file details
- Samba Turkish char support (8859-9 default)
- Turksat (42E), latest TP List - Updated
- Incorrect channel number display in REC info bar when recording fix.
- Incorrect recording time in recording file fix. (Trick Mode Problem)
- OSD message box - Improved
- SAT Name add. by Service Search Mode
- New Function in Infobar :
--> Menu - Configuration - Display Setting :
--> Info Box Event Name : present event with time, present and follow event
- Volume Control in TXT Mode (Volume v+ v-) add.
- BISS + DCW input (keymanager) adjusted
--> Menu 8282 ...DCW key new functions add.
--> SID ONID TSID . & SID PMTPID ECMPID
AZBOX Premium
Tuner B : motor SG 2100
Tuner C : DVB-T
Re: fw 1.08.26
V Menu - Obnovenie systemu pribudla polozka - Delete stored position . Kto bol na workshope, vie o com hovorim - je to moznost zmazania "prednastaveneho defaultu" , ktory robil problem pri nahodnom preplneni pamate- dalsi start boxu bol prave v tomto "vyrobnom defaulte" a o svoje tazko usporiadne programy tak uzivatel prisiel . Teda, ak si to cloveke nestihol zalohovat - vacsinou nie. Takze- skutocne prazdny prijimac sa da spravit zmazanim obsahu /var/ a pouzitim funkcie "delete stored position" .
Jerry973 Slovakia
Re: fw 1.08.26
Příspěvek od Jerry973 »
ja len dodám, že táto funkcia nie je nová, bola už aj v predchádzajúcej verzii 22 ... Večer budem testovať nový soft ... :-)
HD-BOX 9200
Re: fw 1.08.26
aspon vidno ,ako casto chodim do tej casti menu :)
mam to v boxe , ladim programy z roznych pozicii , aby som zistil ci epg cache robi stale problem . zatial sa tvari ze nie . Uvidime .
messo
Re: fw 1.08.26
Příspěvek od messo »
ma vsetko to co 1.8.22 ? Je to pouzitelny FW? Dufam ze nie ako 1.8.16 :D
Test 1.8.26 bude az pri najblizsom zavahani stroja (1.8.22) alebo za tyzden,
Overujem si problem s padanim 1.8.22
Ale prosim piste sem co najviac postrehov.
Re: fw 1.08.26
ma vsetko, teda aj Menu 8282 funguje. Zatial ide stabilne , zajtra uvidim ,ci sa nespomali .
Jerry973 Slovakia
Re: fw 1.08.26
u mna spokojnost, myslim, ze je lepsi ako 22, uz len preto, ze mi ide prehravat divix (nie jeden, robilo mi to z cca z 4), ktory mal oneskoreny zvuk v 22 cca o 2 sekundy-nepozeratelne. Stabilita zatial u mna OK, plugin a secko ostatne maka na jednotku. Este budem skusat nahravanie, lebo sa mi stal jeden problem, ze som si dal nahrat nieco z HBO HD a on mi nahravku sice spravil, ale z Nova HD ...
HD-BOX 9200
messo
Re: fw 1.08.26
Prosim piste aj porovnanie voci 1.8.22 , hlavne ty ktory mali problem s 1.8.22 zo stabilitou a s citanim/zapisom na karty (cslink atdl). Dakujem
jerry
Re: fw 1.08.26
Příspěvek od jerry »
Oproti .22 je hlavne poriesene zapraskanie systemu pri dlhsom pouzivani vratane nemoznosti vypnutia sposobeneho tymto problemom.
Ine zasadnejsie zmeny som nezbadal.
messo
Re: fw 1.08.26
tak to je posledna vec co ma naozaj trapy na hdboxe, heskyyyy,
este doladit par musiek, a a konecne som spokojny.
Karta od 1.8.22 nevypadla ani pri prepinany zakodovanych/fta/uz neexistujucich s frekvenciou 600programov/hod (nova karta skylink), potom ma trapilo uz len padanie systemu.
Je tam este bug s pretacanim skokom, ale to uz je prehliadnutelne.
Asi predsa ostanem u HDBOXU :)
messo
Re: fw 1.08.26
Tak neodolal som a mam prve vysledky
- Znova je problem s transponderom 23,5°E 12109 DVB-S2 H 9/10 27500 (sekanie HD nahravok) (viewtopic.php?f=169&t=5303)
- Box mi zamrzol asi 1min po fleshovani, nedavam tomu velky doraz, uvidim neskor.
- cas je posunuty o -2h (namiesto 20:39 je v boxe 18:39) - problem rovnaku ako 1.8.22 (prikaz date a uptime v terminali)
- zrychlena praca s nahravkami
- pridalo sa oramovanie dialogovych okien
- zrychlila sa praca v EPG (subjektivny pohlad)
- elegantne riesenie rozporu pri nahravani a la Magio.
- Problem co nahlasil Jerry973, sa zatial neprejavil, nahrate to co bolo planovane
(.... ze som si dal nahrat nieco z HBO HD a on mi nahravku sice spravil, ale z Nova HD ...)
Testujem stabilitu FW, zatial mi to nepripada pohyb vpred.
Stanovisko zajtra.
Naposledy upravil(a) messo dne 11 čer 2010, 22:43, celkem upraveno 1 x.
Jerry973 Slovakia
Re: fw 1.08.26
messo píše:Prosim piste aj porovnanie voci 1.8.22 , hlavne ty ktory mali problem s 1.8.22 zo stabilitou a s citanim/zapisom na karty (cslink atdl). Dakujem
Aby bolo jasne, toto nie je vlakno len o tom, ze aky je rozdiel medzi fw 22 a 26, ale celkovo o fw 26, tak sa toho prosim drzte a piste vsetky postrehy, ktore stoja za zmienku. U mna stabilita zatial v poriadku, vypadok som nepostrehol ani zamrznutie, ani nic podobne ...
HD-BOX 9200
messo
Re: fw 1.08.26
islo mi o to, ze niekomu 1.8.22 nepadala, no mne kazde 2-3dni a nebol som sam, proste kto nahraval tomu to padalo.
Staci spomenut len v skratke, lepsie, horsie. O to my slo
vakov
Re: fw 1.08.26
Příspěvek od vakov »
Tak jedna chyba ve verzi 1.08.26: nejde kopírování z HDD na USB2 (jiné kombinace jsem nezkoušel).
Ve verzi 1.08.22 bylo kopírování OK.
Re: fw 1.08.26
Příspěvek od marsim21 »
messo píše:islo mi o to, ze niekomu 1.8.22 nepadala, no mne kazde 2-3dni a nebol som sam, proste kto nahraval tomu to padalo.
Mám fw 22 skoro každý den 1 i 2 nahrávky manželce.Používám Xcam .Přijímač je bez karty a zamrzl mi za tu dobu jednou. :89:
