fw 1.08.16
fw 1.08.16
tak skusajte, testujte.
Xcam , mcas a newcs - primarne urcene pre karty.
staznosti na mgcamd su neopodstatnene!!!!
9200 :arrow: http://www.sapro.cz/download/hdbox/__do ... 0Apr30.zip
9300 :arrow: http://www.sapro.cz/download/hdbox/__do ... 0Apr30.zip
- v1.08.16 / 2010. 04. 30 / Build Version : 2962
[Function Added / Improved]
1. WIFI function modified : ssid scan function and simplificated. Monitoring function (Auto setup when re-plug/link)
2. mkv supported. Hangup or not able to play the mkv
- Most of the files are able to play but specific file break while play.
3. Blocking problem if network link disconnected when using the net driver. (Not possible while recording)
4. TS recording / decoding speed. (Break problem when HD decoding / recording)
5. Font size adjustable when using User font.
[Bug fixed]
1. Hangup problem when delete the folder in Play List.
2. Local offset and summer time not support after factory reset.
3. Unicable bug when standby
4. DVB Subtitle - subtitle display size problem on the screen when data is as HD video size.
5. When plugin auto start, USB detect problem if remove the USB then insert again after rebooting the STB with USB inserted.
6. Hangup when move the folder which contains ts file.
7. Not able to process if network drive folder name has space.
8. Channel data deletes when user area format.
9. Hangup when mp3 file play on WIFI WPAPSK mode.
10. time not updating in timer setting menu.
11. Single tuner model : 2 channels(Same TP) recording by timer or EPG support.
12. When only plugin folder is exist in Data Transfer menu, not able to open the firmware box.
bery2
Re: fw 1.08.16
Příspěvek od bery2 »
Opět nefunguje vypnutí čtečky.
zuchnet
Re: fw 1.08.16
Příspěvek od zuchnet »
that will be corrected very close transponders ? dammit
The receiver is weird, people from the software are blind ?
Re: fw 1.08.16
:arrow: zuchnet Unfortunately our region has other problems...
Na moznost vypnutia citacky sa nespoliehajte - vzdy treba najskor spravit kontrola typu sw - Menu 8282 - ide editovat kluce ?
ak nie - je bez emu .
SuiVanOrton
Re: fw 1.08.16
Příspěvek od SuiVanOrton »
Tak jsem to nakonec vyzkoušel a tady jsou moje postřehy:
- v menu opět není položka plugin (stejně jako v 1.08.09)
- při přepnutí infobox problikne (jako by naskočil a znovu se načetl)
- nejde nahrávat přímo tzn. zapnutím ovladačem - napíše to záznam selhal :-( (když nastavím nahrávání přes EPG tak to jde)
- přehrávání nahraných HD programů z předchozích verzí stále kostičkuje a zasekává se (stejně jako v předchozích verzích)
- přehrávání nahraných HD programů z této verze fw stále zadrhává (ale je to lepší než předtím, zadrhne se to a rozkostičkuje méně častěji než u předchozích verzích) - zkoušeno na Nova HD
- při sledování HBO HD mi jednou přístroj ouplně zatuhl - ani ovladačem nešel vypnout, musel jsem ho vypnout a zapnout vzadu sítovým vypínačem
- některé položky které byli počeštěné jsou tedka zase anglicky (front - přední, rear - zadní, atd.), malá chybička v překladu u "Nastavení zvuku" (žlutý čudlík) je napsáno "Natavení zvuku"
Update 1:
Rychlost USB HDD - změřeno přes menu - správce zařízení: 134 MBits/S
- k tomu jedna poznámka - vysledoval jsem že když zkusím tento test rychlosti poprvé po zapnutí přístroje, je to třeba jenom 80 nebo i 39 MBits/s, každý další test už vždycky vyhodí kolem těch 130 a výš. Divný.
Update 2:
To co dělal fw 1.08.09 - že to hlásilo "program zakodován" (většinou při přechodu z nekodovaných na kodované programy) to tento fw na mojí kartě skylink nedělá. Tzn. funguje OK.
No vrátil jsem se k 1.08.01.
Naposledy upravil(a) SuiVanOrton dne 01 kvě 2010, 22:38, celkem upraveno 4 x.
HD-BOX 9200, karta Skylink (Irdeto výměna)
HDD Samsung Story Station Plus 1TB (připojeno přes eSata)
TV Panasonic TX-L42E30E
Re: fw 1.08.16
Tato verzia fw je bez podpory sw emulacie. Momentalne jedine co ma zaujima je to, ci idu karty Conax a vsetky Cryptoworks karty. Ma niekto problem s nejakou konkretnou kartou ? (okrem financneho... :) )
Re: fw 1.08.16
Pri uvadzani problemov s nahravanim HD programov, prosim uvedte aj rychlost disku - da sa skontrolovat priamo v menu prijimaca.
mmirousek
Re: fw 1.08.16
Příspěvek od mmirousek »
no já toho moc neotestuju když nejde EMU ani mgcamd :D a dám si teď další pivíčko
, hrát se budu až budu striezlí nebo jak je to po slovensky :D :D
Jerry973 Slovakia
Re: fw 1.08.16
Příspěvek od Jerry973 »
mmirousek píše:no já toho moc neotestuju když nejde EMU ani mgcamd :D a dám si teď další pivíčko
Taketo prispevky nam nepomozu, poprosim sa vyjadrovat k veci ...
HD-BOX 9200
MartinK. Czech Republic
Re: fw 1.08.16
Příspěvek od MartinK. »
Karta TNK (conax) vypisu vadná karta a stroj zatuhne až po vytažení karty se rozjede.
V menu cas po vložení karty naskočí CONAX a dokonce jde i vyčíst zápisy na kartě.
maximální spokojenost
Re: fw 1.08.16
sprav log terminalom - teda co sa deje po vlozeni karty a posli na reviservis@reviservis.sk
messo
Re: fw 1.08.16
Příspěvek od messo »
Moje poznatky z tohto firmweru: 1.08.16
Resetoval som data po nahrati FW,
+ Karta SKYLINK za 2h testovania nevypadla
- Pocas flashovania, pri druhom reboote ostal BOX mrtvy, nepomohlo ani zapnut a vypnut z elektriky. Ked som vypol na 2min z elektriky, potom sa rozbehol a znova nahral FW do pamate.
- nemohol som vyskusat HD nahravku, kedze som nemohol nic nahrat.
- nejde nahravat, len cez EPG
- nejde timeshift
- chcelo po mne format disku, no nahravky ostali, to je divne
- EPG: info o filme zobrazuje od polovice
Vratil som sa k 1.08.01
zuchnet
Re: fw 1.08.16
I see that the most important thing of HDbox is EMU :51:
It is a pity because the receiver is not suitable for basic things
petans
Re: fw 1.08.16
Příspěvek od petans »
zuchnet píše:I see that the most important thing of HDbox is EMU :51:
naprosty souhlas ... :87:
OCTAGON SF 1018 HD 500GB / OCTAGON SF 1008 HD
fw 1.09.94-A, E2 PKT HAARP v3a
messo
Re: fw 1.08.16
1.08.16 zatial u mna najhorsia verzia FW, neviem mozno robim nieco zle, ale 1.07.97 a 1.08.01 idu bez problemov. A odvtedy cim novsi tym horsi.
Maju FW nejale pravidlo? Stabilne, nestabilne verzie ako v linuxe? (parne = vyvojove, neparne = stabilne)
